    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F Offline
      With Animator v4.5a, I cannot reproduce the issue, whether in interactive mode or when generation the video.
      Could you be more precise and tell me where you set the speed factor.
      J 1 Reply Last reply Reply Quote 0
        jamesmeng @fredo6
        @fredo6
        Please see above image. for previous verisons (before v4.4) for example if you choose 0.75 (frame tate I choose 45f/s I don't know if it affects the speed), and if your video last 100 seconds, then the video generated will be 133seconds, that mean 100/133=0.75 (this is exactly the factor you choose).
        however after I install v4.4 version, and choose the 0.75 factor, the generated video will last 241seconds, and even I input 0.95 factor, the video last 170seconds around. I think maybe there is something you can adjust in your program. to make the speed factor back to normal.
        • fredo6F Offline
          I released v4.5a. Did you try with this version?
          J 2 Replies Last reply Reply Quote 0
            jamesmeng @fredo6
            @fredo6 Yes I tried v4.5a but same problem.
              jamesmeng @fredo6
              @fredo6
              you can see my version now is v4.5a
              I just created one 36 seconds video and choose 0.75 with 45p/s I finally get 1 minute and 26second video:
              • fionmacoolF Offline
                fionmacool
                I love this plugin, but I find the elements get moved due to some glitch- What often happens is that an element gets repositioned to the end of it's path. This means that it will travel the right direction and distance but start and end at incorrect positions. Is there a simple way to correct an element position? The plugin doesn't seem to like it if I manually move an element.
                My workaround is to copy all the elements in one sketchup file and paste them into another file so that I can start re-building the animation timeline again.
                Please excuse me if this has been answered elsewhere. Thanks.
                Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                • fredo6F Offline
                  It is better to use the Positioner to save position of objects.
                  fionmacoolF 1 Reply Last reply Reply Quote 0
                    fionmacool @fredo6
                    @fredo6 Thanks Fredo. Much appreciated.
                      jamesmeng
                      hi Fredo, I want to buy the license but it say that I need to install sektchucation extensionstore v3.1.
                      how to install it?
                        jamesmeng
                        I get it, the plugin name is "SketchUcationTools" not extensionstore. better change the name on the tip. because most people search for extensionstore and get nothing.
                          jamesmeng
                          hi Fredo,
                          I find timer's possible reason. when I use the computer with old CPU (I7 4790), the video's time will be slow when you set 0.75 factor. however when I use the computer with relative new version CPU, the time will be normal.
                          • fredo6F Offline
                            New Release: Animator - v4.6a - 18 Dec 25
                            Requirement: LibFredo6 v15.6
                            Animator 4.6a is a maintenance release for:
                            • Extension of validity
                            See plugin home page of Animator for Download of RBZ from the PluginStore.
                            See Main Post of the Animator thread for more information.
                            • ntxdaveN Offline
                              ntxdave
                              I would like to create an animation that looks like I am writing something or drawing something. Is there a way to do that with Animator?
                              Press F1...thank me later
                              • ntxdaveN Offline
                                ntxdave @ntxdave
                                I am suddenly having interface problems. I cannot control how the timeline looks/is located and some other user information is not all visible for me.
                                Here is a view of the timeline, and no matter which thing I click on, I cannot get the timeline to show up vertically (which used to be the default and the way I like it the best). Here is a view of how it currently looks: Screenshot 2026-01-03 095627.png
                                Here is another image that shows the Animator default settings. Notice that at the bottom, not everything is showing (at least as far as I can tell) and there is no option for me to scroll so that I can see what is below (if anything). Screenshot 2026-01-03 095301.png
                                I also have been having a problem trying to select multiple items to make part of a clip (or how to add things to an existing clip).
                                I have tried shutting down SketchUp and Animator multiple times to see if restarting or selecting models where I had some existing Animator animations to see if that would have any effect and it did not. I have also reported these problems (at least some of them). in this thread https://community.sketchucation.com/topic/164682/scene-animation-with-animator/29
                                OK, I just went back to SU 2025 and tried to create a new Animator file with 2025 and am having the same issues with the Animator UI. I first had to update Animator in 2025 and then I restarted SU and as I just said, I am seeing the same issue with the Animator UI.
                                What the heck am I/have I done wrong?
                                • Rich O BrienR Online
                                  Please hover these UI buttons:
                                  These allow you to position the UI
                                  • ntxdaveN Offline
                                    ntxdave @Rich O Brien
                                    @Rich-O-Brien Thanks, @rich-o-brien, clicking on the yellow bar solved the problem for me. πŸ‘ πŸ‘
                                    Now I have to solve the problem of how to combine multiple sequences (movements) into a single Clip. When I try to use the shift key to select multiple items and put them into a clip, it does not work. Also, if I have a clip, how to I add additional items to it?
                                    I watched @fredo6 tutorial (Tutorial 1), I thought I understood how to combine items, but I must be missing something. I think (at least for now) figuring this issue out will help me make a lot of progress to where I want to do.
                                    As I have said before (in multiple threads/posts), I appreciate the feedback and patience from you. I have tried to watch videos and read some stuff to understand these issues on my own. Maybe I am just getting to old learn how to do things. 😲
                                    DUH I just figured out the combining issue. I used the Ctrl key to select multiple items instead of the shift key a LALa, it worked. πŸ‘
                                    1 Reply Last reply Reply Quote -1
                                    • ntxdaveN Offline
                                      ntxdave
                                      OK, I think I have finally figured out all of the tricks I need to make a video with Animator.
                                      Here is an example
                                      Model View.mp4
                                      Yes the video/model is pretty basic but through it, I think I have learned how to accomplish the things I want for some upcoming Animator generated videos.
                                      I just have one last silly question; how do I set the location for where the video is created (folder name and location).?
                                      • ntxdaveN Offline
                                        ntxdave
                                        Is it possible to start a new thread or category for asking "how to" questions for Animator. I think I have recently learned a lot of very useful information, but I still have a number of questions that I have not been able to find answers to. Yes, I can do a lot of testing but there are topics where other users might be able to provide good feedback/advice for.
                                        • ntxdaveN Offline
                                          ntxdave
                                          I am suddenly getting a message that my license expired on 23 Jan 2026 and I do not know how to update/get it working again. Right now I cannot use Animator.
                                          • ntxdaveN Offline
                                            ntxdave @ntxdave
                                            I am suddenly having a problem generating a video. When I click on the link to generate a video, nothing is happening.
                                            Here is the file I am trying to use to generate a video. Hope someone can either generate a video for me, or look at my file and tell me what is happening.
                                            3 Scene Animator.skp
                                            fredo6F 1 Reply Last reply Reply Quote 0
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
