    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • KrassK
      Krass
      hello, yes, as I can remember
      Krass
      • pixelcruncherP
        I created a hotfix for a crash and updated to version 0.9.68 Beta - please ensure you get that one.
        Hey, Rayscaper users!
        A new release, with some cool stuff!
        Rayscaper 0.9.68 Beta is available in the SketchUcation store. As
        I recommend upgrading to the latest version.
        What Changed?
        • Support for SketchUp 2026.
        • Draw overlays for the lights in the viewport. This allows the user to select the lights in the viewport directly. You can enable
          or disable the overlay in the viewport toolbar.
        • Save the layout and position of the Rayscaper window between sessions. You can reset the layout via the menu "File >
          Reset Window Layout".
        • Fix a crash when minimizing the Rayscaper window.
        Here's the light overlay feature in action:
        Help Me Build the Community 👍
        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
        and helps me showcase its capabilities to new users.
        Follow me on X.
        Happy Rendering!
        Mike AmosM 1 Reply Last reply
        • KrassK
          Krass
          Thanks, very usefull function
          Krass
            Mike Amos @pixelcruncher
            @pixelcruncher
            I am getting a crash when minimising or closing Rayscaper latest version.
            Also this. Setpoint error, graphic did not save. The crash of Sketchup is repeatable.
            pixelcruncherP 2 Replies Last reply
            • pixelcruncherP
              pixelcruncher Extension Creator @Mike Amos
              @Mike-Amos Thank for reporting. Sorry about that!
              I can reproduce the crash on minimizing, not on closing the Rayscaper window, though. Working on a fix.
              • pixelcruncherP
                @Mike-Amos Version 0.9.68 is out now, can you confirm that it fixes the crash you saw earlier today? Thanks!
                  Sorry, confirm that the crash still happens.
                  • KrassK
                    Krass
                    Hello, if I leave Rayscaper open and import a texture directly onto a face (with the import tool) it crashes
                    Krass
                    • KrassK
                      Krass
                      I can't create an emissive material with an image, if I increase the power the image disappears and the texture is white. I can't make a monitor screen. Can someone help me?
                      Krass
                      • KrassK
                        Krass
                        crash again, I wasn't doing anything special... Sketchup 2024 and Rayscaper 9.6.8
                        Krass
                        • KrassK
                          Krass
                          Another crash when reopening RS and trying to apply a texture
                          Krass
                            I can confirm that with the models I had issues with in Sketchup V2024, crash occurs when minimising Rayscaper. After that last build they ceased when closing Rayscaper. In Sketchup 2026, No crash on minimising or closing Rayscaper no matter which model is in use. Other apps also function better, faster, cleanup for example would freeze. NOT in Sketchup V2026.
                            • KrassK
                              Krass
                              I came back to 9.64 version for test
                              Krass
                              • KrassK
                                Krass
                                quelle galère
                                Krass
                                  Rich O Brien Moderator @Krass
                                  @Krass said in Rayscaper New Releases:
                                  quelle galère
                                  Patience is a virtue. Having an app have backwards compatibility along with supporting multiple different GPUs and CPUs etc is challenging for a single developer.
                                  Reply Quote 2
                                    Mike Amos @Rich O Brien
                                    @Rich-O-Brien
                                    Agreed, getting this far this fast as a one man band, part time. Wow.
                                    Being in beta still, imperfection is a given but the ride is still good and hoping I am contributing sufficiently.
                                    • KrassK
                                      Krass
                                      Yes! Indeed
                                      Krass
                                      • pixelcruncherP
                                        Hey guys,
                                        Looking into the crashes.
                                        Was this on the first texture, or after multiple imports?
                                        Currently, Rayscaper doesn't support emission with a texture. Which image are you talking about? Maybe a screenshot of your setup helps me understand it better.
                                        Looking into the crashes, I think (I hope) I found the root cause.
                                        I understand the frustrations, and I appreciate your help in making the software a lot better!
                                        Cheers,
                                        Thomas
                                        KrassK 1 Reply Last reply
                                        • KrassK
                                          Krass @pixelcruncher
                                          Nice render Mike!
                                          @pixelcruncher said in Rayscaper New Releases:
                                          I created a surface and imported a texture
                                          I found a solution to make an image emissive: for example for PC screens on the following images I make a copy of the face that must receive the image and I place it in front 2 or 3 millimeters of the initial face to which I applied an emissive. On this copy of the face I put my image as texture and I increase the Transmission slider, and it works well. (I just discovered this feature!)
                                          ci-dessous 3 rendus avec un upscale KREA.AI
                                          Krass
                                          • KrassK
                                            Krass
                                            for the record, all the furniture is really at my house, but I tried to see in these images what I could fit into this apartment that I could buy....
                                            the character is not contractual, I have a shaved head!
                                            Krass
                                            • 11
                                            • 12
                                            • 37
                                            • 38
                                            • 10 / 38
