    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
      You are THE man, Sir. I am in awe of your rendering talents. Unless they are photographs in which case. Pptttttttttttttttttht!
      Change a thing and you get a call from sister carol. Not something for the faint hearted.....
      • pixelcruncherP
        @Krass
        To clarify, updating the PolyHaven HDRI size will change the size of the textures after a restart:
        I will not update the HDRI images/textures you are currently using in your scene. You can check the actual size here, but I should also display the HDRI size more prominently in the UI.
        If you want to use the larger size, reapply the HDRI later.
        I hope that clarifies things!
        Regards,
        Thomas
        • pixelcruncherP
          @Krass Wow, that's jaw-dropping. Congratulations. Great work!
          KrassK 1 Reply Last reply
          • KrassK
            Krass @pixelcruncher
            Mike Amos Thanks,
            I'll have a hard time understanding your joke "Change one thing and you get a call from Sister Carol. Not something for the faint-hearted..." because I'm French and my level of English is limited. But thank you for this feedback.
            It's true that the result of "arranged" renderings ends up producing standardized photographic images (I'm thinking of this couple in this image; it looks like an advertising brochure for real estate development), but it's perfect for my clients.
            I'm very happy, thanks to AI, to be able to use Rayscaper as a complete rendering engine (characters and vegetation). I find the quality of the rendering engine equal to Vray, but simpler.
            Krass
            • KrassK
              Krass @Krass
              pixelcruncher
              Thanks for the details
              In truth, I think I'm on the wrong line for the choice of HDRI size definition. I'm confusing it with the size of the textures... sorry for the messages above
              Krass
              • KrassK
                Krass
                Here's a version with an HDRI map background
                But I'm trying to make a "studio" render for a friend, and Sketchup crashes when I change the image resolution during rendering. I set it to 300x400 and double-scaled it twice, and it crashed both times. Should I send a crash report?
                https://jskup.fr/wp-content/uploads/2025/09/rocking-chair-3-Phil94.jpg
                Krass
                • KrassK
                  Krass
                  I paused the rendering and changed the definition, and it didn't crash... "studio" version raw rayscaper
                  alt text
                  Krass
                  • pixelcruncherP
                    @Krass said in Rayscaper New Releases:
                    Making sure I understood you correctly. Just changing the resolution (of the rendered image) in Rayscaper made the software crash?
                    alt text
                    Nice render, it doesn't seem to have the correct tags in the forum post because the picture is not visible for me immediately.
                    • KrassK
                      Krass
                      hello, yes, as I can remember
                      Krass
                      • pixelcruncherP
                        I created a hotfix for a crash and updated to version 0.9.68 Beta - please ensure you get that one.
                        Hey, Rayscaper users!
                        A new release, with some cool stuff!
                        Rayscaper 0.9.68 Beta is available in the SketchUcation store. As
                        I recommend upgrading to the latest version.
                        What Changed?
                        • Support for SketchUp 2026.
                        • Draw overlays for the lights in the viewport. This allows the user to select the lights in the viewport directly. You can enable
                          or disable the overlay in the viewport toolbar.
                        • Save the layout and position of the Rayscaper window between sessions. You can reset the layout via the menu "File >
                          Reset Window Layout".
                        • Fix a crash when minimizing the Rayscaper window.
                        Here's the light overlay feature in action:
                        Help Me Build the Community 👍
                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                        and helps me showcase its capabilities to new users.
                        Follow me on X.
                        Happy Rendering!
                        Mike AmosM 1 Reply Last reply
                        • KrassK
                          Krass
                          Thanks, very usefull function
                          Krass
                            Mike Amos @pixelcruncher
                            @pixelcruncher
                            I am getting a crash when minimising or closing Rayscaper latest version.
                            Also this. Setpoint error, graphic did not save. The crash of Sketchup is repeatable.
                            pixelcruncherP 2 Replies Last reply
                            • pixelcruncherP
                              pixelcruncher Extension Creator @Mike Amos
                              @Mike-Amos Thank for reporting. Sorry about that!
                              I can reproduce the crash on minimizing, not on closing the Rayscaper window, though. Working on a fix.
                              • pixelcruncherP
                                @Mike-Amos Version 0.9.68 is out now, can you confirm that it fixes the crash you saw earlier today? Thanks!
                                  Sorry, confirm that the crash still happens.
                                  • KrassK
                                    Krass
                                    Hello, if I leave Rayscaper open and import a texture directly onto a face (with the import tool) it crashes
                                    Krass
                                    • KrassK
                                      Krass
                                      I can't create an emissive material with an image, if I increase the power the image disappears and the texture is white. I can't make a monitor screen. Can someone help me?
                                      Krass
                                      • KrassK
                                        Krass
                                        crash again, I wasn't doing anything special... Sketchup 2024 and Rayscaper 9.6.8
                                        Krass
                                        • KrassK
                                          Krass
                                          Another crash when reopening RS and trying to apply a texture
                                          Krass
                                            I can confirm that with the models I had issues with in Sketchup V2024, crash occurs when minimising Rayscaper. After that last build they ceased when closing Rayscaper. In Sketchup 2026, No crash on minimising or closing Rayscaper no matter which model is in use. Other apps also function better, faster, cleanup for example would freeze. NOT in Sketchup V2026.
                                            • 11
                                            • 26
                                            • 27
                                            • 9 / 27
