    Sketchucation Tools 5.0...
    176 Posts 30 Posters 70.8k Views 28 Watching
      slbaumgartner @TIG
      @TIG
      I am running SketchUp 26.0.428, as stated in my first post. I haven't run SU 2019 in years! My computer is an elderly 2019 MacBook Pro, but it is up to date on the latest macOS and SketchUp versions.
      • fredo6F
        Joining the thread...
        So, it's not Sketchucation Tools nor SCFLicense, but FredoTools.
        A few questions:
        • Do you launch Sketchup on a custom template or the default template?
        • Which Mac version?
        S 1 Reply Last reply
          slbaumgartner @fredo6
          @fredo6 said in Sketchucation Tools 5.0.3:
          A few questions:
          I use a minimally customized template, though this is happening both when opening an existing file last saved from SU 2026 and also when starting a new file from my template.
          As stated before, macOS 26.0.1 on a 2019 MacBook Pro 16"
            So at the moment you have SketchUcation toolset v5.0.3 OK, the SCF licensing OK and most of Fredo's extensions OK.
            BUT Fredo'sTools must be disabled for this to get everything else working.
            So the issue lies with FredoTools.
            Have you tried reinstalling FredoTools from a newly downloaded RBZ ?
            • fredo6F
              FredoTools does not rely on SCF License. All tools are free.
              @slbaumgartner
              It might be related to MacOS 26 (Tahoe), which is recent, although recently announced as supported by Sketchup 2026. Especially if you still use an old MackBook on Intel. I don't have Tahoe on my Mac, just Sequoia. So difficult to judge.
              1. When you installed to SU2026, did you migrate the plugins with the SU installation?
              2. If you get a bugsplat on startup, did you try to send the report to Sketchup? If so, did you get any feedback?
                @fredo6
                @TIG
                @Rich-O-Brien
                It just got weirder!
                I was shuffling various combinations of extensions in and out in an attempt to track down possible conflicts. This time TIG's split extensions (donut, sausage, splitTools) needed to be excluded to avoid a spin but Fredo_Tools can be present. I am sure that earlier I did not have those TIG tools installed when it spun on Fredo_Tools! They are quite old and I don't use them much, so I can live without them.
                Further, when I got it launched with those TIG extensions off and Fredo_Tools on, I opened the SketchUcation Plugin Store extension to see when they were last updated and as soon as the store window opened, SketchUp went into spin!
                Something is seriously unstable but I don't know what! Every other extension I had in 2025 is installed and, when SU manages to get running, they appear to work correctly.
                To answer your questions,
                I had let the new migration manager move extensions across from 2025. Then I used Fredo's check for updates to verify that his were up to date (needed the newer LibFredo6). I haven't tried reinstalling other extensions where I appear to have the latest versions - which I would have to do by going to the Plugin Store via the browser rather than the Plugin Store extension. I'll try that to see what happens.
                • OK, I tried downloading and installing the latest Fredo_Tools, and SketchUp is spinning on launch again! Stopped the spin when I removed Fredo_Tools again. Could something corrupt be getting stuck in a cache somewhere? Maybe a corrupted json file?
                I don't think it is licenses because Fredo's checker reports the correct ones. Why would that be right yet somehow be causing a spin?
                I have not gotten any BugSplats.
                • fredo6F
                  Just in case, there is a menu Window > LibFredo6 Settings... > Trace Log files.
                  This allows to see the latest traces for loading my plugins.
                  If you get the spin, then
                  • hard exit Sketchup
                  • relaunch with a configuration that does not spin
                  • get the trace log file corresponding to the spin session (so not the last one, but the one before).
                  • send it to me.
                  • Z
                    zsolarewicz @Mike Amos
                    @Mike-Amos said in Sketchucation Tools 5.0.3:
                    Last free version of Sketchup is V17.
                    Hey, thats a news ๐Ÿ˜‰
                    Hi, thats a news ๐Ÿ˜‰
                    You sure about that? -mean ill give it a chance anyway
                    but lived so far convinced v8 was last owned by Google, before being sold to Trimble?
                    Btw where Sketchucation 5.0.3 is to be found?
                    cheers,
                    ZS
                      Rich O Brien Moderator @zsolarewicz
                      @zsolarewicz said in Sketchucation Tools 5.0.3:
                      Sketchucation Tools | SketchUcation
                      (sketchucation.com)
                      Z 1 Reply Last reply
                        @fredo6
                        I reinstalled Fredo6_Tools to get a spin. Took it back out and relaunched without spin. This is the trace log from the previous session
                        LibFredo6Trace_26_1760445486517.txt
                        Another strange effect of note: in the log viewer window, when I export TXT, that worked and a popup opened asking if I want to open the file. I clicked YES, and SketchUp went into a spin! This seems the same as how the Plugin Store window hangs...
                        fredo6F 1 Reply Last reply
                          A condition on sale from google to trimble was a couple (Five?) years maintaining Sketchup with a free version. V17 was the last.
                            jackybe67 @TIG
                            @TIG
                            Thank You !!
                            • fredo6F
                              fredo6 @slbaumgartner
                              @slbaumgartner
                              More and more puzzling. There seems to be something corrupted in the way Sketchup handles external files, including Ruby script files.
                              In the trace file, I see that you have just LibFredo6, other of my plugins installed. The trace indicates that their startup sequences did perform well. So, the crash occurs after the plugins are loaded.
                              • Z
                                zsolarewicz @Rich O Brien
                                @Rich-O-Brien said in Sketchucation Tools 5.0.3:
                                (sketchucation.com)
                                Thx a lot, I meant: for download but 1st post just points to that w/out a version number though.
                                Btw v 5.0.3 stiil DOES NOT work with SKP 2017.
                                cheers,
                                  @fredo6
                                  I'm pretty sure I tried with nothing but your extensions in the Plugins folder, otherwise this would raise the possibility of a conflict with something that loads after them. I'll try that again tomorrow just to make sure.
                                  Several times, after force quitting a spin, I have had to try multiple times before SketchUp will launch cleanly again. That makes me wonder if some aspect of state is being saved in a corrupted way that disrupts SketchUp. But diagnosing that is above my pay grade.
                                  • fredo6F
                                    @slbaumgartner
                                    By chance, do you use the new graphic engine? If so, can you try with the classic engine.
                                      slbaumgartner
                                      Yes, I use the new graphics engine. For whatever reason, this morning SketchUp is launching without spin with all fredo6 extensions and all su_ extensions active. So right now, changing to the old graphics wouldn't prove anything. The whack-a-mole on this is getting very annoying!
                                        A lot of the issues I have with V2024 have been cured by moving to V2026, lots of random crashes and bugsplats.
                                        Even the cleanup tool is better behaved.
                                          slbaumgartner
                                          @fredo6
                                          In another forum, Dan Rathbun pointed out that the onExtensionsLoaded method of AppObserver is called right after the extensions are loaded. I found several extensions that have a derived AppObserver class. I'm not sure how to determine if any of them may be to blame or may be somehow interacting with Fredo_Tools.
                                          • W
                                            Wantao
                                            After upgrading SketchUcationTools to version 5.0.3, the Extension Store toolbar keeps appearing in the same spot every time I launch the softwareโ€”even after I close it. Is there a way to fix this?
                                            ![alt text](image url)![alt text](image url)
                                            • 6 / 9
