    Sketchucation Tools 5.0...
    178 Posts 30 Posters 77.8k Views 28 Watching
    • fredo6F
      FredoTools does not rely on SCF License. All tools are free.
      @slbaumgartner
      It might be related to MacOS 26 (Tahoe), which is recent, although recently announced as supported by Sketchup 2026. Especially if you still use an old MackBook on Intel. I don't have Tahoe on my Mac, just Sequoia. So difficult to judge.
      1. When you installed to SU2026, did you migrate the plugins with the SU installation?
      2. If you get a bugsplat on startup, did you try to send the report to Sketchup? If so, did you get any feedback?
      S 1 Reply Last reply
        slbaumgartner @fredo6
        @fredo6
        @TIG
        @Rich-O-Brien
        It just got weirder!
        I was shuffling various combinations of extensions in and out in an attempt to track down possible conflicts. This time TIG's split extensions (donut, sausage, splitTools) needed to be excluded to avoid a spin but Fredo_Tools can be present. I am sure that earlier I did not have those TIG tools installed when it spun on Fredo_Tools! They are quite old and I don't use them much, so I can live without them.
        Further, when I got it launched with those TIG extensions off and Fredo_Tools on, I opened the SketchUcation Plugin Store extension to see when they were last updated and as soon as the store window opened, SketchUp went into spin!
        Something is seriously unstable but I don't know what! Every other extension I had in 2025 is installed and, when SU manages to get running, they appear to work correctly.
        To answer your questions,
        I had let the new migration manager move extensions across from 2025. Then I used Fredo's check for updates to verify that his were up to date (needed the newer LibFredo6). I haven't tried reinstalling other extensions where I appear to have the latest versions - which I would have to do by going to the Plugin Store via the browser rather than the Plugin Store extension. I'll try that to see what happens.
        • OK, I tried downloading and installing the latest Fredo_Tools, and SketchUp is spinning on launch again! Stopped the spin when I removed Fredo_Tools again. Could something corrupt be getting stuck in a cache somewhere? Maybe a corrupted json file?
        I don't think it is licenses because Fredo's checker reports the correct ones. Why would that be right yet somehow be causing a spin?
        I have not gotten any BugSplats.
        • fredo6F
          Just in case, there is a menu Window > LibFredo6 Settings... > Trace Log files.
          This allows to see the latest traces for loading my plugins.
          If you get the spin, then
          • hard exit Sketchup
          • relaunch with a configuration that does not spin
          • get the trace log file corresponding to the spin session (so not the last one, but the one before).
          • send it to me.
          • Z
            zsolarewicz @Mike Amos
            @Mike-Amos said in Sketchucation Tools 5.0.3:
            Last free version of Sketchup is V17.
            Hey, thats a news 😉
            Hi, thats a news 😉
            You sure about that? -mean ill give it a chance anyway
            but lived so far convinced v8 was last owned by Google, before being sold to Trimble?
            Btw where Sketchucation 5.0.3 is to be found?
            cheers,
            ZS
              Rich O Brien Moderator @zsolarewicz
              @zsolarewicz said in Sketchucation Tools 5.0.3:
              Sketchucation Tools | SketchUcation
              (sketchucation.com)
              Z 1 Reply Last reply
                @fredo6
                I reinstalled Fredo6_Tools to get a spin. Took it back out and relaunched without spin. This is the trace log from the previous session
                LibFredo6Trace_26_1760445486517.txt
                Another strange effect of note: in the log viewer window, when I export TXT, that worked and a popup opened asking if I want to open the file. I clicked YES, and SketchUp went into a spin! This seems the same as how the Plugin Store window hangs...
                fredo6F 1 Reply Last reply
                  A condition on sale from google to trimble was a couple (Five?) years maintaining Sketchup with a free version. V17 was the last.
                    jackybe67 @TIG
                    @TIG
                    Thank You !!
                    • fredo6F
                      fredo6 @slbaumgartner
                      @slbaumgartner
                      More and more puzzling. There seems to be something corrupted in the way Sketchup handles external files, including Ruby script files.
                      In the trace file, I see that you have just LibFredo6, other of my plugins installed. The trace indicates that their startup sequences did perform well. So, the crash occurs after the plugins are loaded.
                      • Z
                        zsolarewicz @Rich O Brien
                        @Rich-O-Brien said in Sketchucation Tools 5.0.3:
                        (sketchucation.com)
                        Thx a lot, I meant: for download but 1st post just points to that w/out a version number though.
                        Btw v 5.0.3 stiil DOES NOT work with SKP 2017.
                        cheers,
                          @fredo6
                          I'm pretty sure I tried with nothing but your extensions in the Plugins folder, otherwise this would raise the possibility of a conflict with something that loads after them. I'll try that again tomorrow just to make sure.
                          Several times, after force quitting a spin, I have had to try multiple times before SketchUp will launch cleanly again. That makes me wonder if some aspect of state is being saved in a corrupted way that disrupts SketchUp. But diagnosing that is above my pay grade.
                          • fredo6F
                            @slbaumgartner
                            By chance, do you use the new graphic engine? If so, can you try with the classic engine.
                              slbaumgartner
                              Yes, I use the new graphics engine. For whatever reason, this morning SketchUp is launching without spin with all fredo6 extensions and all su_ extensions active. So right now, changing to the old graphics wouldn't prove anything. The whack-a-mole on this is getting very annoying!
                                A lot of the issues I have with V2024 have been cured by moving to V2026, lots of random crashes and bugsplats.
                                Even the cleanup tool is better behaved.
                                  slbaumgartner
                                  @fredo6
                                  In another forum, Dan Rathbun pointed out that the onExtensionsLoaded method of AppObserver is called right after the extensions are loaded. I found several extensions that have a derived AppObserver class. I'm not sure how to determine if any of them may be to blame or may be somehow interacting with Fredo_Tools.
                                  • W
                                    Wantao
                                    After upgrading SketchUcationTools to version 5.0.3, the Extension Store toolbar keeps appearing in the same spot every time I launch the software—even after I close it. Is there a way to fix this?
                                    ![alt text](image url)![alt text](image url)
                                    • W
                                      Wantao
                                      TIGT 1 Reply Last reply
                                        TIG Moderator @Wantao
                                        @Wantao
                                        The red dot on the toolbar button shows shows that updates are available.
                                        If updates are available then the toolbar shows up by default even if you have closed it previously. This is to ensure you see the availability.
                                        However there are two options in the Extensions > SketchUcation submenu, covering the toolbar close/open status. The first is the same as opening/closing the toolbar manually with the update-availability auto-opening it later if appropriate, but the second one let's you close it and then ignore update alerts, it you choose that you need to manually check for updates by opening the toolbar or ExtensionStore dialog.
                                          Moving all toolbars in a new project (No model) and saving as a template usually works for me New tools, new template.
                                          • RTCoolR
                                            RTCool
                                            I'm using SketchUcation Store 5.0.3 in SU 2026 and it seems flaky. It reports that everything in my library needs updating even though that's not correct. Also, clicking on Settings gets me this Update list. What's it supposed to look like when you click Settings?
                                            • 6 / 9
