    Sketchucation Tools 5.0...
    176 Posts 30 Posters 70.7k Views 28 Watching
      slbaumgartner @TIG
      @TIG said in Sketchucation Tools 5.0.3:
      Are you still running v2019
      Is this directed to me or to Fredo? I am running macOS 26.0.1
      S TIGT 2 Replies Last reply
        slbaumgartner @slbaumgartner
        Hmm...If I remove all the extensions except SketchUcation Tools, SketchUp will start without spinning. If I then restore all of Fredo6's extensions, it spins on launch again!
        S 1 Reply Last reply
          Homing in on it. I left the SketchUcation Tools installed, removed half of Fredo6's extensions. This time it launched ok. Here is the report:
          Fredo6 Plugins Information on 2025-10-13 12:20:34 -0400
          • Platform: x86_64-darwin - Ruby: 3.2.2
          • Sketchup: 26.0.428
          • LibFredo6: v15.5a
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 5.0.3
          • SCFLicense: v7.1a - 72
          • Fredo6 Plugins
            Curviloft v2.0a - licensed FULL: 29405 - CV1627251325.0G
            Curvizard v2.5a - licensed FULL: 29408 - CV1627251325.0G
            FredoCorner v2.7a - licensed FULL: 20072 - CV1627251325.0G
            FredoScale v3.6a - licensed FULL: 29406 - CV1627251325.0G
            FredoSpline v2.6a - licensed FULL: 20074 - CV1627251325.0G
            Signature File: 2021-07-25 18:15:25 -0400
            Curviloft: 2025-07-25 09:21:13 -0400
            Curvizard: 2025-07-25 09:21:31 -0400
            FlatText: 2024-10-04 09:57:56 -0400
            FredoCorner: 2021-03-27 15:12:28 -0400
            FredoScale: 2022-03-02 09:04:10 -0500
            FredoSpline: 2023-03-14 17:08:26 -0400
            JointPushPull: 2025-04-02 18:14:32 -0400
            RoundCorner: 2022-03-02 09:05:06 -0500
            ToolsOnSurface: 2022-03-02 09:05:26 -0500
            TopoShaper: 2025-07-25 09:22:24 -0400
            VisuHole: 2024-04-17 11:29:50 -0400
            Took out Fredo6_FredoTools and it launched ok.
            • LibFredo6: v15.5a
            • Fredo6 Plugins
              JointPushPull v4.9a - licensed FULL: 29404 - CV1627251325.0G
              RoundCorner v3.4a - licensed FULL: 29403 - CV1627251325.0G
              And one more test that seems to identify the culprit: If I restore all of Fredo6's stuff except Fredo6_FredoTools, SketchUp launches without spinning.
              Fredo6 Plugins Information on 2025-10-13 12:35:51 -0400
              • LibFredo6: v15.5a
              • Fredo6 Plugins
                ToolsOnSurface v2.6a - licensed FULL: 29410 - CV1627251325.0G
                TopoShaper v2.7a - licensed FULL: 29407 - CV1627251325.0G
                VisuHole v1.5a - licensed FULL: 29409 - CV1627251325.0G
                TIG Moderator @slbaumgartner
                @slbaumgartner
                I meant the SUp version.
                I suspect that most users will have newer SUp versions ?
                The reason I cited @fredo6 is that he is instrumental in the licensing coding, and I am inviting his input...
                  That's really helpful. Thanks. We've made Fredo aware
                    slbaumgartner @TIG
                    @TIG
                    I am running SketchUp 26.0.428, as stated in my first post. I haven't run SU 2019 in years! My computer is an elderly 2019 MacBook Pro, but it is up to date on the latest macOS and SketchUp versions.
                    • fredo6F
                      Joining the thread...
                      So, it's not Sketchucation Tools nor SCFLicense, but FredoTools.
                      A few questions:
                      • Do you launch Sketchup on a custom template or the default template?
                      • Which Mac version?
                        slbaumgartner @fredo6
                        @fredo6 said in Sketchucation Tools 5.0.3:
                        A few questions:
                        I use a minimally customized template, though this is happening both when opening an existing file last saved from SU 2026 and also when starting a new file from my template.
                        As stated before, macOS 26.0.1 on a 2019 MacBook Pro 16"
                          So at the moment you have SketchUcation toolset v5.0.3 OK, the SCF licensing OK and most of Fredo's extensions OK.
                          BUT Fredo'sTools must be disabled for this to get everything else working.
                          So the issue lies with FredoTools.
                          Have you tried reinstalling FredoTools from a newly downloaded RBZ ?
                          • fredo6F
                            FredoTools does not rely on SCF License. All tools are free.
                            @slbaumgartner
                            It might be related to MacOS 26 (Tahoe), which is recent, although recently announced as supported by Sketchup 2026. Especially if you still use an old MackBook on Intel. I don't have Tahoe on my Mac, just Sequoia. So difficult to judge.
                            1. When you installed to SU2026, did you migrate the plugins with the SU installation?
                            2. If you get a bugsplat on startup, did you try to send the report to Sketchup? If so, did you get any feedback?
                              @fredo6
                              @TIG
                              @Rich-O-Brien
                              It just got weirder!
                              I was shuffling various combinations of extensions in and out in an attempt to track down possible conflicts. This time TIG's split extensions (donut, sausage, splitTools) needed to be excluded to avoid a spin but Fredo_Tools can be present. I am sure that earlier I did not have those TIG tools installed when it spun on Fredo_Tools! They are quite old and I don't use them much, so I can live without them.
                              Further, when I got it launched with those TIG extensions off and Fredo_Tools on, I opened the SketchUcation Plugin Store extension to see when they were last updated and as soon as the store window opened, SketchUp went into spin!
                              Something is seriously unstable but I don't know what! Every other extension I had in 2025 is installed and, when SU manages to get running, they appear to work correctly.
                              To answer your questions,
                              I had let the new migration manager move extensions across from 2025. Then I used Fredo's check for updates to verify that his were up to date (needed the newer LibFredo6). I haven't tried reinstalling other extensions where I appear to have the latest versions - which I would have to do by going to the Plugin Store via the browser rather than the Plugin Store extension. I'll try that to see what happens.
                              • OK, I tried downloading and installing the latest Fredo_Tools, and SketchUp is spinning on launch again! Stopped the spin when I removed Fredo_Tools again. Could something corrupt be getting stuck in a cache somewhere? Maybe a corrupted json file?
                              I don't think it is licenses because Fredo's checker reports the correct ones. Why would that be right yet somehow be causing a spin?
                              I have not gotten any BugSplats.
                              • fredo6F
                                Just in case, there is a menu Window > LibFredo6 Settings... > Trace Log files.
                                This allows to see the latest traces for loading my plugins.
                                If you get the spin, then
                                • hard exit Sketchup
                                • relaunch with a configuration that does not spin
                                • get the trace log file corresponding to the spin session (so not the last one, but the one before).
                                • send it to me.
                                • Z
                                  zsolarewicz @Mike Amos
                                  @Mike-Amos said in Sketchucation Tools 5.0.3:
                                  Last free version of Sketchup is V17.
                                  Hey, thats a news πŸ˜‰
                                  Hi, thats a news πŸ˜‰
                                  You sure about that? -mean ill give it a chance anyway
                                  but lived so far convinced v8 was last owned by Google, before being sold to Trimble?
                                  Btw where Sketchucation 5.0.3 is to be found?
                                  cheers,
                                  ZS
                                    Rich O Brien Moderator @zsolarewicz
                                    @zsolarewicz said in Sketchucation Tools 5.0.3:
                                    Sketchucation Tools | SketchUcation
                                    (sketchucation.com)
                                    Z 1 Reply Last reply
                                      @fredo6
                                      I reinstalled Fredo6_Tools to get a spin. Took it back out and relaunched without spin. This is the trace log from the previous session
                                      LibFredo6Trace_26_1760445486517.txt
                                      Another strange effect of note: in the log viewer window, when I export TXT, that worked and a popup opened asking if I want to open the file. I clicked YES, and SketchUp went into a spin! This seems the same as how the Plugin Store window hangs...
                                      fredo6F 1 Reply Last reply
                                        A condition on sale from google to trimble was a couple (Five?) years maintaining Sketchup with a free version. V17 was the last.
                                          jackybe67 @TIG
                                          @TIG
                                          Thank You !!
                                          • fredo6F
                                            fredo6 @slbaumgartner
                                            @slbaumgartner
                                            More and more puzzling. There seems to be something corrupted in the way Sketchup handles external files, including Ruby script files.
                                            In the trace file, I see that you have just LibFredo6, other of my plugins installed. The trace indicates that their startup sequences did perform well. So, the crash occurs after the plugins are loaded.
                                            • 6 / 9
