    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
    • KrassK
      Krass
      Be careful, Comfy UI requires a large graphics card and lots of free disk space, and a lot of patience.
      Krass
      • pixelcruncherP
        Hey, Rayscaper users!
        Another release!
        Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
        always, I recommend upgrading to the latest version.
        What Changed?
        • Fix weird artifacts in the interactive render viewport.
        • Fix the upside-down images when saving.
        • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
        • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp
          light component again.
        • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
        • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
        Help Me Build the Community 👍
        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
        and helps me showcase its capabilities to new users.
        Follow me on Twitter.
        Happy Rendering!
        • KrassK
          Krass
          thanks Pix, but no change for the lights component name with this version 9.64 If I rename the lights componant all lights go down
          Krass
          • pixelcruncherP
            @Krass, just as a sanity check, you are not changing the name right, and not the component definition name?
            • KrassK
              Krass
              ok, sorry, Indeed, I changed the component name and the instance name... thanks. Perfect, I'll test it.
              However, I don't understand. I set the HDR definition to 8k, and it seems that it doesn't take this definition into account. I'll redo the rendering after downloading the map from the site.
              Krass
              • KrassK
                Krass
                before/after: rayscaper project/Nano banana+Magnific upscale
                Krass
                Reply Quote 3
                  You are THE man, Sir. I am in awe of your rendering talents. Unless they are photographs in which case. Pptttttttttttttttttht!
                  Change a thing and you get a call from sister carol. Not something for the faint hearted.....
                  • pixelcruncherP
                    @Krass
                    To clarify, updating the PolyHaven HDRI size will change the size of the textures after a restart:
                    I will not update the HDRI images/textures you are currently using in your scene. You can check the actual size here, but I should also display the HDRI size more prominently in the UI.
                    If you want to use the larger size, reapply the HDRI later.
                    I hope that clarifies things!
                    Regards,
                    Thomas
                    • pixelcruncherP
                      @Krass Wow, that's jaw-dropping. Congratulations. Great work!
                      KrassK 1 Reply Last reply
                      • KrassK
                        Krass @pixelcruncher
                        Mike Amos Thanks,
                        I'll have a hard time understanding your joke "Change one thing and you get a call from Sister Carol. Not something for the faint-hearted..." because I'm French and my level of English is limited. But thank you for this feedback.
                        It's true that the result of "arranged" renderings ends up producing standardized photographic images (I'm thinking of this couple in this image; it looks like an advertising brochure for real estate development), but it's perfect for my clients.
                        I'm very happy, thanks to AI, to be able to use Rayscaper as a complete rendering engine (characters and vegetation). I find the quality of the rendering engine equal to Vray, but simpler.
                        Krass
                        • KrassK
                          Krass @Krass
                          pixelcruncher
                          Thanks for the details
                          In truth, I think I'm on the wrong line for the choice of HDRI size definition. I'm confusing it with the size of the textures... sorry for the messages above
                          Krass
                          • KrassK
                            Krass
                            Here's a version with an HDRI map background
                            But I'm trying to make a "studio" render for a friend, and Sketchup crashes when I change the image resolution during rendering. I set it to 300x400 and double-scaled it twice, and it crashed both times. Should I send a crash report?
                            https://jskup.fr/wp-content/uploads/2025/09/rocking-chair-3-Phil94.jpg
                            Krass
                            • KrassK
                              Krass
                              I paused the rendering and changed the definition, and it didn't crash... "studio" version raw rayscaper
                              alt text
                              Krass
                              • pixelcruncherP
                                @Krass said in Rayscaper New Releases:
                                Making sure I understood you correctly. Just changing the resolution (of the rendered image) in Rayscaper made the software crash?
                                alt text
                                Nice render, it doesn't seem to have the correct tags in the forum post because the picture is not visible for me immediately.
                                • KrassK
                                  Krass
                                  hello, yes, as I can remember
                                  Krass
                                  • pixelcruncherP
                                    I created a hotfix for a crash and updated to version 0.9.68 Beta - please ensure you get that one.
                                    A new release, with some cool stuff!
                                    Rayscaper 0.9.68 Beta is available in the SketchUcation store. As
                                    What Changed?
                                    • Support for SketchUp 2026.
                                    • Draw overlays for the lights in the viewport. This allows the user to select the lights in the viewport directly. You can enable
                                      or disable the overlay in the viewport toolbar.
                                    • Save the layout and position of the Rayscaper window between sessions. You can reset the layout via the menu "File >
                                      Reset Window Layout".
                                    • Fix a crash when minimizing the Rayscaper window.
                                    Here's the light overlay feature in action:
                                    Follow me on X.
                                    Happy Rendering!
                                    Mike AmosM 1 Reply Last reply
                                    • KrassK
                                      Krass
                                      Thanks, very usefull function
                                      Krass
                                        Mike Amos @pixelcruncher
                                        @pixelcruncher
                                        I am getting a crash when minimising or closing Rayscaper latest version.
                                        Also this. Setpoint error, graphic did not save. The crash of Sketchup is repeatable.
                                        pixelcruncherP 2 Replies Last reply
                                        • pixelcruncherP
                                          pixelcruncher Extension Creator @Mike Amos
                                          @Mike-Amos Thank for reporting. Sorry about that!
                                          I can reproduce the crash on minimizing, not on closing the Rayscaper window, though. Working on a fix.
                                          • pixelcruncherP
                                            @Mike-Amos Version 0.9.68 is out now, can you confirm that it fixes the crash you saw earlier today? Thanks!
                                            • 11
                                            • 26
                                            • 27
                                            • 9 / 27
