    Kitchen/breakfast bar
    14 Posts 5 Posters 1.6k Views 4 Watching
    • gullfoG Offline
      gullfo
      also, my plates are never that shiny πŸ™‚ what do you wash them with? πŸ˜‰
      seriously though, spend a bit of time setting the reflections. almost everything in the room seems to reflect... leverage settings like blurred reflection on surfaces which are not polished. and in general, i'd just turn down a bunch of the reflection levels.
      Glenn
      http://www.runnel.com
        One of the issues with reflection settings is, you cannot go lower than 0.
        Mike AmosM Rich O BrienR 2 Replies Last reply Reply Quote 0
          Mike Amos @Mike Amos
          OK, I have a habit of adding an emitter 'face' which infills any missing light and helps considerably.
          Dealing with a new health issues (Diabetes secondary to Crohn's) which is complicating life's already complex harmony.
          Sorry for my perfidity. 5 1000s 2081 x 1160  912945 tri 2m 01s GPU  Post pro increased exposure to 1.75.png Still need to adjust this.
            Hey Mike,
            I hope you are doing well. That scene already looks a lot better-lit.
            I'm not sure which material you are using, but you can control the roughness of the material:
            Feel free to screenshot your material settings, which helps us understand your setup better.
            Also, whatever @Rich-O-Brien says goes; he's the number one Rayscaper expert in the world. And I'm saying this without irony.
            Regards,
            Thomas
              @Mike-Amos said in Kitchen/breakfast bar:
              Roughness is a 0 to 1 slider.
              • 0 = 0% roughness therefore 100% reflection (Black)
              • 1 = 100% roughness therefore 0% reflection (White)
              The values actually represent Black to White which is why when you plug greyscale roughness maps you create some very nice results.
                Rich O Brien Moderator @pixelcruncher
                @pixelcruncher said in Kitchen/breakfast bar:
                Metallic value = 0
                P 1 Reply Last reply Reply Quote 1
                  pixelcruncher Extension Creator @Rich O Brien
                  @Rich-O-Brien Oof, good one. Took a while to sink in.
                      Nice, the lighting is a lot better than the initial render. The glasses on the table are still missing some refraction.
                        Thanks, yes, the infill lighting I had forgotten is present and accounted for. Essentially a large low power light source (A simple face lit by colour emmission setting) which can be angled however I need to depending on where I want it to focus. 2 watts and 5k temp. Something I started using with Twilight. All of the original textures which failed have been replaced and work as advertised.
                        tuna1957T 1 Reply Last reply Reply Quote 1
                        • tuna1957T Offline
                          tuna1957 @Mike Amos
                          @Mike-Amos Keep after it. You’re making good progress. πŸ‘
