    Kitchen/breakfast bar
    14 Posts 5 Posters 1.3k Views 4 Watching
      Well, I think the latest buil;d works well enough. The problem textures have been replaced which seems to fix the non rendered facets issue.
      I have added some flame effect underneath the kettle and adjusted the emmision qualities of the pale yellow texture.
        You need to fix the glass materials. You have Thin checked I think which is only meant to be checked for planar surfaces.
        On curved surfaces it is causing issues because there is no refraction. Uncheck Thin. If the window glass and the glassware share the same material then use a separate material for the glassware Thin unchecked.
        I also think your model is probably completely enclosed with the only entry point for light being the windows. This means the opposite end of the kitchen is struggling and you can see that by the blotchiness on the island counter top, lower cabinets and the backsplash.
        Keep digging in things to understand why this happens. Its the best way to learn.
          This is what I mean by enclosed...
          The interior is really hard to bounce light around and in the real world there would be more internal light paths happening.
          • gullfoG Offline
            gullfo
            also, my plates are never that shiny πŸ™‚ what do you wash them with? πŸ˜‰
            seriously though, spend a bit of time setting the reflections. almost everything in the room seems to reflect... leverage settings like blurred reflection on surfaces which are not polished. and in general, i'd just turn down a bunch of the reflection levels.
            Glenn
            http://www.runnel.com
              One of the issues with reflection settings is, you cannot go lower than 0.
              Mike AmosM Rich O BrienR 2 Replies Last reply Reply Quote 0
                Mike Amos @Mike Amos
                OK, I have a habit of adding an emitter 'face' which infills any missing light and helps considerably.
                Dealing with a new health issues (Diabetes secondary to Crohn's) which is complicating life's already complex harmony.
                Sorry for my perfidity. 5 1000s 2081 x 1160  912945 tri 2m 01s GPU  Post pro increased exposure to 1.75.png Still need to adjust this.
                • P Online
                  Hey Mike,
                  I hope you are doing well. That scene already looks a lot better-lit.
                  I'm not sure which material you are using, but you can control the roughness of the material:
                  Feel free to screenshot your material settings, which helps us understand your setup better.
                  Also, whatever @Rich-O-Brien says goes; he's the number one Rayscaper expert in the world. And I'm saying this without irony.
                  Regards,
                  Thomas
                    @Mike-Amos said in Kitchen/breakfast bar:
                    Roughness is a 0 to 1 slider.
                    • 0 = 0% roughness therefore 100% reflection (Black)
                    • 1 = 100% roughness therefore 0% reflection (White)
                    The values actually represent Black to White which is why when you plug greyscale roughness maps you create some very nice results.
                      Rich O Brien Moderator @pixelcruncher
                      @pixelcruncher said in Kitchen/breakfast bar:
                      Metallic value = 0
                      P 1 Reply Last reply Reply Quote 1
                      • P Online
                        pixelcruncher Extension Creator @Rich O Brien
                        @Rich-O-Brien Oof, good one. Took a while to sink in.
                          • P Online
                            Nice, the lighting is a lot better than the initial render. The glasses on the table are still missing some refraction.
                              Thanks, yes, the infill lighting I had forgotten is present and accounted for. Essentially a large low power light source (A simple face lit by colour emmission setting) which can be angled however I need to depending on where I want it to focus. 2 watts and 5k temp. Something I started using with Twilight. All of the original textures which failed have been replaced and work as advertised.
                              tuna1957T 1 Reply Last reply Reply Quote 1
                              • tuna1957T Offline
                                tuna1957 @Mike Amos
                                @Mike-Amos Keep after it. You’re making good progress. πŸ‘
