    2.1k Posts 465 Posters 655.0k Views 470 Watching
      Rich O Brien Moderator @da800429
      @da800429 In this post your licensing version is 6.1a - 72
      Now its 6.4a -74 so that suggest you've updated Sketchucation Tools to 4.4.0
      What happens now if you license using your license file/s at https://sketchucation.com/webshop/my-licences.php ?
      Please follow this guide for activation instructions
      D Rich O BrienR 2 Replies Last reply Reply Quote 0
        da800429 Newcomers @Rich O Brien
        @Rich-O-Brien
        I've updated to the latest version.
        My license is permanent, do I need to purchase it again?
          Rich O Brien Moderator @Rich O Brien
          Can you provide us info on these steps above?
          @da800429 said in SCFLicense: Extension Licensing on Sketchucation:
          No
          D 1 Reply Last reply Reply Quote 0
            antoniopedromolinari
            Cant find where to instal the latest version of "Sketchucation Store Extension"
            When I click, it takes me nowhere I can find the "download" button.
            TIGT Rich O BrienR 2 Replies Last reply Reply Quote 0
              @Rich-O-Brien
              How to send videos to you?
              Why does everyone have to have problems after updating?
              Makes me feel angry!
                TIG Moderator @antoniopedromolinari
                An extension is an RBZ archive [like a ZIP file], it contains all of the files and subfolders needed for the code to work.
                You install an RBZ file using the native Extensions > Extension Manager > dialog > install... button.
                Find the RBZ file when prompted and it gets installed.
                Restart SketchUp afterwards to sync everything.
                Once you have the SketchUcation toolset installed you can manager your plugins/extensions and auto-install any available extensions direct from the ExtensionStore³ dialog, sidestepping the RBZ download etc.
                There's also an Archive installer in the SketchUcation submenu items than will install RBZ & ZIP files for you...
                  @da800429 you can email support@sketchucation.com or you can provide here.
                  You have yet to provide us info. What happens if you license an extension using your license file/s at https://sketchucation.com/webshop/my-licences.php ?
                  If you can't get it to work then we can refund but I would like an answer to my query above.
                    Rich O Brien Moderator @antoniopedromolinari
                    @antoniopedromolinari said in SCFLicense: Extension Licensing on Sketchucation:
                    ExtensionStore | SketchUcation
                    (sketchucation.com)
                      @Rich-O-Brien
                      I don't want a refund
                      I just want to solve the problem with you
                      I sent the video to support@sketchucation.com
                        @da800429 I replied via email. But for others I'll post here.
                        The error was a communication issue with our server. This occurs when either the network environment your device is connected has strict rules or you are running some piece of software that detects something with SketchUp is trying to connect to a server.
                        The remedy is to whitelist our server by either using the following address
                        *.sketchucation.com
                        Or using our IP addresses
                        178.63.47.155
                        144.76.69.227
                          @Rich-O-Brien
                          My network uses WIFI. I turned off the firewall and couldn't add the license normally.
                          I don't know how to join the whitelist, can you teach me?
                            @da800429 It is likely there is hardware or software running protective measures that see the licensing system as a threat.
                            Your other option is to tether your device to your phone's network and try that.
                            For whitelisting if you are running Defender you could try adding a custom rule
                            https://answers.microsoft.com/en-us/windows/forum/all/add-ip-address-and-url-to-windows-defender/5a96cd4c-aa36-414d-aa7a-2d14b6a6dc79
                            Have you tried repairing your SketchUp install?
                            Just a moment...
                            (help.sketchup.com)
                            In some instances that may cause the error.
                            If none of the above fix it then we will refund.
                              LOAR @Rich O Brien
                              @Rich-O-Brien @da800429 I had this same error, which was quite frustrating for a while. Eventually I closed all the sketchup windows I had open and only opened one model. Then the validation worked. So maybe it's something to do with multiple models being open that gets in the way of validation? Hope this helps
                              • V Offline
                                vitalisvitalis Newcomers
                                hi,I just brought a fredo scaLE but bit aasks for license,what to do?
                                  Rich O Brien Moderator @vitalisvitalis
                                  @vitalisvitalis said in SCFLicense: Extension Licensing on Sketchucation:
                                  Following activation guide https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                    g_petinati
                                    Hi Fredo. I'm having an issue with my FREDO CORNER license.
                                    I get the message that "License Seats Exceeded".
                                    I reinstalled Sketchup, and did not release the license from the old installation. Is there a way to correct this issue?
                                    Thank you.
                                      labaruss
                                      Hi Fredo and others. Since I change the name of my computer the license fail of your tools. What shuld I do ? Thank you.
                                      fredo6F 1 Reply Last reply Reply Quote 0
                                        labaruss
                                        This post is deleted!
                                        • fredo6F Offline
                                          fredo6 @labaruss
                                          @labaruss
                                          You can manage your licenses at this page, My Licenses at Sketchucation.
                                            titty456
                                            @Rich-O-Brien
                                            I have purchased curviloft, but I encounter a problem with A04. How to solve it?
                                            Fredo6 Plugins Information on 2024-05-03 18:38:51 +0800
                                            • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                            • Sketchup: 23.0.397
                                            • LibFredo6: v14.3d
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: 4.4.1
                                            • SCFLicense: v6.4a - 74
                                            • Fredo6 Plugins
                                              Curviloft v1.9b
                                              JointPushPull v4.4e
                                              Signature File: 2024-05-03 18:31:59 +0800
                                            TIGT 1 Reply Last reply Reply Quote 0
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 105
                                            • 106
                                            • 92 / 106
