    2.3k Posts 515 Posters 2.3m Views 520 Watching
      da800429 Newcomers @TIG
      There is a paid purchase serial number
      It was usable for a few days but suddenly unavailable.
      The above content appears after I log in again
      @TIG 1713108206236.jpg ![alt text](![image url](1713108238265.jpg image url))
        Rich O Brien Moderator @da800429
        @da800429
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
        D 1 Reply Last reply Reply Quote 0
          da800429 Newcomers @Rich O Brien
          @Rich-O-Brien
          Is this what you are referring to?
          Fredo6 Plugins Information on 2024-04-15 02:03:34 +0800
          • Platform: x64-mswin64_140 - Ruby: 2.7.2
          • Sketchup: 22.0.316
          • LibFredo6: v14.3b
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 4.4.0
          • SCFLicense: v6.4a - 74
          • Fredo6 Plugins
            Curviloft v2.0a
            Curvizard v2.5a
            FredoCorner v2.7a
            FredoScale v3.6a
            FredoSpline v2.6a
            FredoTools v4.5a
            JointPushPull v4.8a
            RoundCorner v3.4a
            ToolsOnSurface v2.6a
            TopoShaper v2.7a
            VisuHole v1.5a
            Signature File: 2023-08-22 06:52:55 +0800
            @da800429 In this post your licensing version is 6.1a - 72
            Now its 6.4a -74 so that suggest you've updated Sketchucation Tools to 4.4.0
            What happens now if you license using your license file/s at https://sketchucation.com/webshop/my-licences.php ?
            Please follow this guide for activation instructions
            D Rich O BrienR 2 Replies Last reply Reply Quote 0
              @Rich-O-Brien
              I've updated to the latest version.
              My license is permanent, do I need to purchase it again?
                Rich O Brien Moderator @Rich O Brien
                Can you provide us info on these steps above?
                @da800429 said in SCFLicense: Extension Licensing on Sketchucation:
                No
                  antoniopedromolinari
                  Cant find where to instal the latest version of "Sketchucation Store Extension"
                  When I click, it takes me nowhere I can find the "download" button.
                  TIGT Rich O BrienR 2 Replies Last reply Reply Quote 0
                    @Rich-O-Brien
                    How to send videos to you?
                    Why does everyone have to have problems after updating?
                    Makes me feel angry!
                      TIG Moderator @antoniopedromolinari
                      An extension is an RBZ archive [like a ZIP file], it contains all of the files and subfolders needed for the code to work.
                      You install an RBZ file using the native Extensions > Extension Manager > dialog > install... button.
                      Find the RBZ file when prompted and it gets installed.
                      Restart SketchUp afterwards to sync everything.
                      Once you have the SketchUcation toolset installed you can manager your plugins/extensions and auto-install any available extensions direct from the ExtensionStoreยณ dialog, sidestepping the RBZ download etc.
                      There's also an Archive installer in the SketchUcation submenu items than will install RBZ & ZIP files for you...
                        @da800429 you can email support@sketchucation.com or you can provide here.
                        You have yet to provide us info. What happens if you license an extension using your license file/s at https://sketchucation.com/webshop/my-licences.php ?
                        If you can't get it to work then we can refund but I would like an answer to my query above.
                          Rich O Brien Moderator @antoniopedromolinari
                          @antoniopedromolinari said in SCFLicense: Extension Licensing on Sketchucation:
                          Sketchucation Tools | SketchUcation
                          (sketchucation.com)
                            @Rich-O-Brien
                            I don't want a refund
                            I just want to solve the problem with you
                            I sent the video to support@sketchucation.com
                              @da800429 I replied via email. But for others I'll post here.
                              The error was a communication issue with our server. This occurs when either the network environment your device is connected has strict rules or you are running some piece of software that detects something with SketchUp is trying to connect to a server.
                              The remedy is to whitelist our server by either using the following address
                              *.sketchucation.com
                              Or using our IP addresses
                              178.63.47.155
                              144.76.69.227
                                @Rich-O-Brien
                                My network uses WIFI. I turned off the firewall and couldn't add the license normally.
                                I don't know how to join the whitelist, can you teach me?
                                  @da800429 It is likely there is hardware or software running protective measures that see the licensing system as a threat.
                                  Your other option is to tether your device to your phone's network and try that.
                                  For whitelisting if you are running Defender you could try adding a custom rule
                                  https://answers.microsoft.com/en-us/windows/forum/all/add-ip-address-and-url-to-windows-defender/5a96cd4c-aa36-414d-aa7a-2d14b6a6dc79
                                  Have you tried repairing your SketchUp install?
                                  Uninstalling or Repairing SketchUp
                                  UninstallTo uninstall SketchUp, please see Uninstalling SketchUp where you can find step-by-step instructions for both Windows and Mac users.RepairWindows users can run SketchUp's Repair option to help with missing or corrupt files, broken shortcuts, or registry errors.Note: A repair option is not available to iOS users.To repair your installation of SketchUp, follow these steps:
                                  (help.sketchup.com)
                                  In some instances that may cause the error.
                                  If none of the above fix it then we will refund.
                                    LOAR @Rich O Brien
                                    @Rich-O-Brien @da800429 I had this same error, which was quite frustrating for a while. Eventually I closed all the sketchup windows I had open and only opened one model. Then the validation worked. So maybe it's something to do with multiple models being open that gets in the way of validation? Hope this helps
                                    • V Offline
                                      vitalisvitalis Newcomers
                                      hi,I just brought a fredo scaLE but bit aasks for license,what to do?
                                        Rich O Brien Moderator @vitalisvitalis
                                        @vitalisvitalis said in SCFLicense: Extension Licensing on Sketchucation:
                                        Following activation guide https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                          g_petinati
                                          Hi Fredo. I'm having an issue with my FREDO CORNER license.
                                          I get the message that "License Seats Exceeded".
                                          I reinstalled Sketchup, and did not release the license from the old installation. Is there a way to correct this issue?
                                          Thank you.
                                            labaruss
                                            Hi Fredo and others. Since I change the name of my computer the license fail of your tools. What shuld I do ? Thank you.
                                            fredo6F 1 Reply Last reply Reply Quote 0
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 115
                                            • 116
                                            • 92 / 116
