    [Plugin] Pic2Shape - v1.3a - 17 Dec 25 (Image Contouring)
    45 Posts 15 Posters 12.2k Views 16 Watching
    • fredo6F
      Thanks TIG... Now released
      Reply Quote 2
        Very cool! Thank you sir!
          rv1974
          There's a serious problem (based on what I saw in YT video) with jaggedness. the plugin needs some contour refining\smoothing\straightening engine.
          • fredo6F
            You can do smoothing of curves afterwards, with dedicated tools. It's difficult to do it appropriately when extracting contours from the image, because there are too many situations.
            And of course, without the plugin, you can always draw over the image with arcs, splines and lines....
              Feel free to cannibalize parts of my ImageTrimmer, which smooths jaggedness...
              You pass the edges' collected vertex points, and set an epsilon factor... thus.
                    ### epsilon is a float perhaps < 0.2
                    ### perhaps it's set by the user ? experiment for best default...
                    ### the vertices are collected from the current outline[s]
                    points = vertices.collect{|v| v.position }
                    simplified_curve = douglas_peucker(points, epsilon) ### might return []
                    simplified_curve << simplified_curve[0] if simplified_curve[0]  ### so it 'loops'
                    edges = some_entities.add_curve(simplified_curve) if simplified_curve[0]
                    ### sort out edges' faces, hide edges etc as desired
              the 'douglas_peucker()' method is this...
                ### http://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
                ### http://en.wiki.mcneel.com/default.aspx/McNeel/
                                                      PolylineSimplification.html
                def douglas_peucker(points, epsilon)
                  return points if points.length < 3
                  ### Find the point with the maximum distance
                  dmax = 0
                  index = 0
                  line = [points.first,  points.last]
                  1.upto(points.length - 2) { |i|
                     d = points[i].distance_to_line(line)
                     if d > dmax
                       index = i
                       dmax = d
                  ### If max distance is greater than epsilon, recursively simplify
                  result = []
                  if dmax >= epsilon
                    ### Recursive call
                    recResults1 = ImageTrimmer.douglas_peucker(points[0..index], epsilon)
                    recResults2 = ImageTrimmer.douglas_peucker(points[index...points.length], epsilon)
                    ### Build the result list
                    result = recResults1[0...-1] + recResults2
                  else
                    result = [points.first, points.last]
                  end#if
                  return result
                end #def
              • fredo6F
                Thanks TIG.
                Pic2Shape already includes a simplify method, more sophisticated that the Douglas Peucker algorithm.
                The real issue is that the smooting is a matter of mixing local and global scale, but also boundaries of pixels, which itself is not always clean.
                  rv1974
                  it'd be interesting to process this fence in free inkscape for comparison
                  • fredo6F
                    Please do it and report.
                    DXF conversion is likely to give better results.
                    • kimgaK
                      kimga
                      I was about to try this extension out - using SketchUp 2025 Pro, but the extension doesn’t seem to process the image. Image size 155x50 mm / 300 pixel/inch.
                      After 10 minutes still at Initialization…
                      Is there any guideline on max/ recommended picture size?
                      I tried it with a smaller resolution image, but I still can not get through Initialization....
                      Thank you
                      • kimgaK
                        kimga
                        update: I succeeded with the plugin, when I opened the image in a new file.
                        The original image was on a bent plane. I suppose that was the problem…
                        R N 2 Replies Last reply
                          rv1974 @kimga
                          @kimga Are you going to to have trees with this amount of edges per leaf ) ?
                          • N
                            nasmrtcz @kimga
                            @kimga @TIG Hi. I also have this issue. It works really great in the picture, but after applying it on a textured face, it freezes like the leaf.
                            • fredo6F
                              Do you have the model for me to explore the issue.
                                schramdesigns
                                I installed Fredo6 Pic2Shape but can not find it anywhere to use it. What gives?
                                  Rich O Brien Moderator @schramdesigns
                                  @schramdesigns Have you met the requirements in the top post?
                                    schramdesigns
                                    I installed this and cant find it to use it.
                                      That suggests you either haven't installed Libfredo or you have not restarted SketchUp. But since you are omitting lots of info to help us understand fully its hard to say.
                                      • fredo6F
                                        NEW RELEASE: Pic2Shape v1.2a - 13 Oct 25
                                        Requirements
                                        • LibFredo6: v15.2a or above
                                        • Sketchup version: SU2018 and above
                                        Pic2Shape 1.2a is a maintenance release including:
                                        • Bug fixing
                                        Home Page of Pic2Shape for information and Download.
                                        Main post of this Pic2Shape thread.
                                        1 Reply Last reply 👍
                                        • fredo6F
                                          NEW RELEASE: Pic2Shape v1.2b - 13 Oct 25
                                          Requirements
                                          Pic2Shape 1.2b is a maintenance release including:
                                          • Bug fixing (one remaining from Pic2Shape v1.2a)
                                          Reply Quote 2
                                          • TutorialsUpT
                                            TutorialsUp
                                            Amazing tool! Thanks, Fredo 😍
                                            Just uploaded a new tutorial on YouTube!
                                            Reply Quote 2
                                            • 1 / 3
