    [Plugin] Pic2Shape - v1.3a - 17 Dec 25 (Image Contouring)
    45 Posts 15 Posters 12.2k Views 16 Watching
    • fredo6F
      You can do smoothing of curves afterwards, with dedicated tools. It's difficult to do it appropriately when extracting contours from the image, because there are too many situations.
      And of course, without the plugin, you can always draw over the image with arcs, splines and lines....
        Feel free to cannibalize parts of my ImageTrimmer, which smooths jaggedness...
        You pass the edges' collected vertex points, and set an epsilon factor... thus.
              ### epsilon is a float perhaps < 0.2
              ### perhaps it's set by the user ? experiment for best default...
              ### the vertices are collected from the current outline[s]
              points = vertices.collect{|v| v.position }
              simplified_curve = douglas_peucker(points, epsilon) ### might return []
              simplified_curve << simplified_curve[0] if simplified_curve[0]  ### so it 'loops'
              edges = some_entities.add_curve(simplified_curve) if simplified_curve[0]
              ### sort out edges' faces, hide edges etc as desired
        the 'douglas_peucker()' method is this...
          ### http://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
          ### http://en.wiki.mcneel.com/default.aspx/McNeel/
                                                PolylineSimplification.html
          def douglas_peucker(points, epsilon)
            return points if points.length < 3
            ### Find the point with the maximum distance
            dmax = 0
            index = 0
            line = [points.first,  points.last]
            1.upto(points.length - 2) { |i|
               d = points[i].distance_to_line(line)
               if d > dmax
                 index = i
                 dmax = d
            ### If max distance is greater than epsilon, recursively simplify
            result = []
            if dmax >= epsilon
              ### Recursive call
              recResults1 = ImageTrimmer.douglas_peucker(points[0..index], epsilon)
              recResults2 = ImageTrimmer.douglas_peucker(points[index...points.length], epsilon)
              ### Build the result list
              result = recResults1[0...-1] + recResults2
            else
              result = [points.first, points.last]
            end#if
            return result
          end #def
        • fredo6F
          Thanks TIG.
          Pic2Shape already includes a simplify method, more sophisticated that the Douglas Peucker algorithm.
          The real issue is that the smooting is a matter of mixing local and global scale, but also boundaries of pixels, which itself is not always clean.
            rv1974
            it'd be interesting to process this fence in free inkscape for comparison
            • fredo6F
              Please do it and report.
              DXF conversion is likely to give better results.
              • kimgaK
                kimga
                I was about to try this extension out - using SketchUp 2025 Pro, but the extension doesn’t seem to process the image. Image size 155x50 mm / 300 pixel/inch.
                After 10 minutes still at Initialization…
                Is there any guideline on max/ recommended picture size?
                I tried it with a smaller resolution image, but I still can not get through Initialization....
                Thank you
                • kimgaK
                  kimga
                  update: I succeeded with the plugin, when I opened the image in a new file.
                  The original image was on a bent plane. I suppose that was the problem…
                  R N 2 Replies Last reply
                    rv1974 @kimga
                    @kimga Are you going to to have trees with this amount of edges per leaf ) ?
                    • N
                      nasmrtcz @kimga
                      @kimga @TIG Hi. I also have this issue. It works really great in the picture, but after applying it on a textured face, it freezes like the leaf.
                      • fredo6F
                        Do you have the model for me to explore the issue.
                          schramdesigns
                          I installed Fredo6 Pic2Shape but can not find it anywhere to use it. What gives?
                            Rich O Brien Moderator @schramdesigns
                            @schramdesigns Have you met the requirements in the top post?
                              schramdesigns
                              I installed this and cant find it to use it.
                                That suggests you either haven't installed Libfredo or you have not restarted SketchUp. But since you are omitting lots of info to help us understand fully its hard to say.
                                • fredo6F
                                  NEW RELEASE: Pic2Shape v1.2a - 13 Oct 25
                                  Requirements
                                  • LibFredo6: v15.2a or above
                                  • Sketchup version: SU2018 and above
                                  Pic2Shape 1.2a is a maintenance release including:
                                  • Bug fixing
                                  Home Page of Pic2Shape for information and Download.
                                  Main post of this Pic2Shape thread.
                                  1 Reply Last reply 👍
                                  • fredo6F
                                    NEW RELEASE: Pic2Shape v1.2b - 13 Oct 25
                                    Requirements
                                    Pic2Shape 1.2b is a maintenance release including:
                                    • Bug fixing (one remaining from Pic2Shape v1.2a)
                                    Reply Quote 2
                                    • TutorialsUpT
                                      TutorialsUp
                                      Amazing tool! Thanks, Fredo 😍
                                      Just uploaded a new tutorial on YouTube!
                                      Reply Quote 2
                                      • V
                                        VR123 Newcomers
                                        Hello, this is an amazing tool—thank you very much. I use it mainly for landscape architecture to create plant shadows. I was wondering why the tool doesn't work with some plants. Quite a lot of plants don't work with this tool; for example, grasses, slightly blue plants, and delicate trees (like the tamarisk tree) seem to produce an open contour which creates a ghost image. I tried editing the PNG and adding a contour or changing the contrast in Photoshop—even adding a very dark black line—and changing the settings of the tool, but nothing seems to work. I wonder if you could have a look at that. I will upload some examples of plants that just don't work with the tool.
                                        ex grass.
                                        https://stock.adobe.com/uk/search?k=nassella+tenuissima&search_type=usertyped&asset_id=1758902289
                                        Tamarix trees:
                                        adobe.com
                                        (stock.adobe.com)
                                        adobe.com
                                        (stock.adobe.com)
                                        • fredo6F
                                          The herbs are to thin to be valuably contoured by Pic2Shape.
                                          Again, you can do proper contouring in specialized software like PhotoShop. Pic2Shape is only there for simple shapes.
                                          • Z
                                            ZG53 Newcomers @fredo6
                                            I use Sketchup 2022 with Twilight render 2.0 Pro. A few days ago I upgraded LibFredo6 and PictoShape to the latest version, After that it started to go bad, the Shapes on the images I make with face to camera after rendering are black (as with the alpha mask), while the imported images in png format without PictoShape are visible OK after rendering.
                                            After rendering in the attached image
                                            Left shape - obtained from png imported image after PiCtoShape
                                            Right shape - imported png and "raised" by 90°
                                            • 1 / 3
