    [Plugin] Pic2Shape - v1.3a - 17 Dec 25 (Image Contouring)
    31 Posts 12 Posters 6.4k Views 13 Watching
    • fredo6F Offline
      The information on Pic2Shape is maintained on the Plugin Home Page of Pic2Shape. This is also where you can download the RBZ file.
      • LibFredo6: v15.6a or above
      • Sketchup version: SU2018 and above
      • Usage: Licensed under Sketchucation SCFLicense as of 01 Sep 25
        • Free Trial period (full features): 30 days from activation
        • Perpetual license (3 seats): $15
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      Pic2Shape extracts contours from images as faces / edges geometry.
      The contouring is based on pixel transparency, which can come from the image itself (in PNG), or from filtering in / out colors. The geometry can be generated as:
      • Just contours
      • Faces with default material
      • Faces textured with the image
      • FaceMe component
      No documentation for the time being. Please watch the video
      Overview and Main Concepts
      Z 1 Reply Last reply Reply Quote 4
        This is worthy successor to my oldie ImageTrimmer - much faster and with better in-built toolset...
        Can't wait to try it !
        • fredo6F Offline
          Thanks TIG... Now released
            Very cool! Thank you sir!
              rv1974
              There's a serious problem (based on what I saw in YT video) with jaggedness. the plugin needs some contour refining\smoothing\straightening engine.
              • fredo6F Offline
                You can do smoothing of curves afterwards, with dedicated tools. It's difficult to do it appropriately when extracting contours from the image, because there are too many situations.
                And of course, without the plugin, you can always draw over the image with arcs, splines and lines....
                  Feel free to cannibalize parts of my ImageTrimmer, which smooths jaggedness...
                  You pass the edges' collected vertex points, and set an epsilon factor... thus.
                        ### epsilon is a float perhaps < 0.2
                        ### perhaps it's set by the user ? experiment for best default...
                        ### the vertices are collected from the current outline[s]
                        points = vertices.collect{|v| v.position }
                        simplified_curve = douglas_peucker(points, epsilon) ### might return []
                        simplified_curve << simplified_curve[0] if simplified_curve[0]  ### so it 'loops'
                        edges = some_entities.add_curve(simplified_curve) if simplified_curve[0]
                        ### sort out edges' faces, hide edges etc as desired
                  the 'douglas_peucker()' method is this...
                    ### http://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
                    ### http://en.wiki.mcneel.com/default.aspx/McNeel/
                                                          PolylineSimplification.html
                    def douglas_peucker(points, epsilon)
                      return points if points.length < 3
                      ### Find the point with the maximum distance
                      dmax = 0
                      index = 0
                      line = [points.first,  points.last]
                      1.upto(points.length - 2) { |i|
                         d = points[i].distance_to_line(line)
                         if d > dmax
                           index = i
                           dmax = d
                      ### If max distance is greater than epsilon, recursively simplify
                      result = []
                      if dmax >= epsilon
                        ### Recursive call
                        recResults1 = ImageTrimmer.douglas_peucker(points[0..index], epsilon)
                        recResults2 = ImageTrimmer.douglas_peucker(points[index...points.length], epsilon)
                        ### Build the result list
                        result = recResults1[0...-1] + recResults2
                      else
                        result = [points.first, points.last]
                      end#if
                      return result
                    end #def
                  • fredo6F Offline
                    Thanks TIG.
                    Pic2Shape already includes a simplify method, more sophisticated that the Douglas Peucker algorithm.
                    The real issue is that the smooting is a matter of mixing local and global scale, but also boundaries of pixels, which itself is not always clean.
                      rv1974
                      it'd be interesting to process this fence in free inkscape for comparison
                      • fredo6F Offline
                        Please do it and report.
                        DXF conversion is likely to give better results.
                        • kimgaK Offline
                          kimga
                          I was about to try this extension out - using SketchUp 2025 Pro, but the extension doesn’t seem to process the image. Image size 155x50 mm / 300 pixel/inch.
                          After 10 minutes still at Initialization…
                          Is there any guideline on max/ recommended picture size?
                          I tried it with a smaller resolution image, but I still can not get through Initialization....
                          Thank you
                          • kimgaK Offline
                            kimga
                            update: I succeeded with the plugin, when I opened the image in a new file.
                            The original image was on a bent plane. I suppose that was the problem…
                            R N 2 Replies Last reply Reply Quote 0
                              rv1974 @kimga
                              @kimga Are you going to to have trees with this amount of edges per leaf ) ?
                              • N Offline
                                nasmrtcz @kimga
                                @kimga @TIG Hi. I also have this issue. It works really great in the picture, but after applying it on a textured face, it freezes like the leaf.
                                • fredo6F Offline
                                  Do you have the model for me to explore the issue.
                                    schramdesigns
                                    I installed Fredo6 Pic2Shape but can not find it anywhere to use it. What gives?
                                      Rich O Brien Moderator @schramdesigns
                                      @schramdesigns Have you met the requirements in the top post?
                                        schramdesigns
                                        I installed this and cant find it to use it.
                                          That suggests you either haven't installed Libfredo or you have not restarted SketchUp. But since you are omitting lots of info to help us understand fully its hard to say.
                                          • fredo6F Offline
                                            NEW RELEASE: Pic2Shape v1.2a - 13 Oct 25
                                            Requirements
                                            • LibFredo6: v15.2a or above
                                            Pic2Shape 1.2a is a maintenance release including:
                                            • Bug fixing
                                            Home Page of Pic2Shape for information and Download.
                                            Main post of this Pic2Shape thread.
