    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
      Mae50 Newcomers
      Good morning,
      I am a daily user of this plugin.
      I just installed SKP 2024 and FredoScale - v3.6a on my new machine. The license is active but when I click on the tool nothing happens.
      Can you help me?
      Bonjour,
      je suis une utilisatrice quotidienne de ce plugin.
      Je viens d'installer SKP 2024 et FredoScale - v3.6a sur ma nouvelle machine. La licence est active mais quand je clique sur l'outil rien ne se passe.
      Est-ce que vous pouvez m'aider ?
      • Rich O BrienR Online
        @Mae50
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          Mae50 Newcomers
          @Rich-O-Brien
          Thanks for your support !
          Fredo6 Plugins Information on 2025-03-04 09:59:17 +0100
          • Sketchup: 24.0.594
          • LibFredo6: v15.1a
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 4.4.1
          • SCFLicense: v6.4a - 74
          • Fredo6 Plugins
            FredoScale v3.6a - licensed FULL
            Signature File: 2025-02-24 16:52:48 +0100
            FredoScale: 2025-03-04 09:56:38 +0100
            @Mae50 That looks good.
            Can you explain in more detail what is happening?
            If you open the Ruby Console via Extensions > Developer > Ruby Console and click on a toolbar icons you see errors in the console?
            If your SketchUp install does not have the correct privileges you can repair the SketchUp installation by downloading the installer and right clicking and choosing Run as Admin
            When prompted choose Repair.
              Mae50 Newcomers
              @Rich-O-Brien
              When I click on a tool Ruby Console says :
              • LibFredo6: v15.1a
              • Fredo6 Plugins
                Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in initialize' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in open'
                c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in write_to_file' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:150:in store'
                c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1474:in usage_use' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1462:in command_invoke'
                c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in block (2 levels) in build_config_commands' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1490:in block in add_command'
                Yes, that looks like your SketchUp install is missing the correct permissions. Following my instructions to Repair should rectify it.
                Or go to C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir and delete the LibFredo6_all_defaults.dat file and start SketchUp
                I'd recommend the top option to ensure you don't encounter other issues related to permissions.
                  Mae50 Newcomers
                  Thanks I do the first option, but it's not ok .
                  Console Ruby :
                    Mae50 Newcomers
                    @Rich-O-Brien
                    I just try the second option
                    and it's ok.
                    Thank you very very much for your support
                    • N Offline
                      NetJaro
                      Hi!
                      I think I found bug.
                      Sometimes, when I rotate my element i change dimensons there is a error with area of my component.
                      Look at this video: 2025-03-11 16 06 21.mp4
                      Someone can help me?
                      Marcin.
                      • fredo6F Offline
                        I would need to have the model to understand, especially because the video is unclear about what exactly you do to the cube with the rotation.
                        Also, can you turn on 'Show Hidden geometry', just in case there are hidden elements in the group.
                        N 1 Reply Last reply Reply Quote 0
                        • F Offline
                          FlorinAp
                          Box Stretching options has a bug - it does correctly only the first level of components nesting, starting with the second level, it doesn't make unique on the first run (it messes up all your components in the model.!), and if you hit Ctrl+Z (only ONCE.!) it reverses the modification, and after that they remain unique and you can modify...
                          Very disturbing.!
                          Curic Stretch works flawlessly, but it is not so handy and fast to use, so is the last option. I use it only when what I want to modify is much too heavy (loaded with many faces and edges... usually organic shapes, but also cabinets with more then 3 drawers because it freezes calculating) because it can handle much more amount of geometry, in these situations, Fredo Scale does only half the job and you end up seeing that only a few pieces have been modified.
                          • N Offline
                            NetJaro @fredo6
                            [@fredo6 thanks for your answer and thank you for what you do for Sketchup ๐Ÿ™‚
                            I include my model.
                            One object (on the left) is original, second object (on the right) is after rotate by Sketchup official rotate function.
                            The bug doesn't show always in first time - try rotate left object, when its good (without bug) - use "undo" and try again.
                            bug.skp
                            Thanks for you help!
                            Regards,
                            Marcin
                            • fredo6F Offline
                              What is the relation with FredoScale then?
                              Note that I tried to rotate both objects, with Undo and try again. I did not find any issue
                              • N Offline
                                NetJaro @fredo6
                                @fredo6 Hi!
                                The problem with area of the object is only when I use a FredoScale.
                                Below I include a longer video with problem.
                                Image 002.mp4
                                E 1 Reply Last reply Reply Quote 0
                                • fredo6F Offline
                                  I cannot reproduce the issue with the Stretch tool followed by a SU Rotate.
                                  Do you have it on any object or just this one ?
                                  By the way, it looks like you component is a Dynamic component, or at least was a dynamic component.
                                  • N Offline
                                    noseno002
                                    Bundle of 8 plugins are compatible with SketchUp 2025?
                                    I'm interested in the Fredo scale, RoundCorner, and others.
                                      Dave R @noseno002
                                      @noseno002 yes. They all work with SketchUp 2025.
                                      • E Offline
                                        elfis @NetJaro
                                        I'm using this plugin for ears, but this has always been the case. It's not a big problemโ€”when the cursor highlights the edge like in your video, just press it, and the bounding box will align.
                                        @NetJaro said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                        @fredo6 Hi!
                                        Image 002.mp4
                                        • E Offline
                                          elfis
                                          I have problem, divide do not work on sketchup 2025 I'm alone with this ?
                                          Are you planning to make any changes, upgrades, or new features?
                                          • A new UI, like the Flip tool
                                          • Displaying the size of the selected object when the tool is active
                                          • Upgrading the stretch target
                                          • Holding proportions when scaling
                                            Dave R @elfis
                                            @elfis said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                            Well, it works for me in SketchUp 2025.
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 54 / 57
