    I’ve Been “Boxed”
    56 Posts 7 Posters 8.1k Views 6 Watching
    • tuna1957T
      tuna1957
      Dug into another old practice model. Minimal number of parts. Additional skills garnered from Box’s gif’s.
      ntxdaveN 1 Reply Last reply
      Reply Quote 2
        Very sharp, completely lost me there but, it's thursday so.........
        tuna1957T 1 Reply Last reply
        • tuna1957T
          tuna1957 @Mike Amos
          @Mike-Amos Assuming the minimal parts sounds confusing? Basically only four components in each basket. The top ring, the twisted vertical bar and a two piece base.
          • tuna1957T
            tuna1957 @ntxdave
            @ntxdave Thank you sir. I’d suggest starting with simple shapes and practice the various techniques. In particular copy/array around a circle. As you get comfortable slowly add to the complexity. 👍
            • ntxdaveN
              ntxdave @tuna1957
              @tuna1957 I have been trying that but so far am not doing very well (making me feel pretty dumb). 🤪
              On thing I do have a little problem with in the videos is that he obviously enters info in the text boxes that you cannot see in the video. I will continue watching and figure things out. Maybe this is what happens as we age and are away for a while. 😀
              Press F1...thank me later
              tuna1957T BoxB 2 Replies Last reply
              • tuna1957T
                tuna1957 @ntxdave
                @ntxdave Don’t feel dumb. At least you’re trying. That’s more than a lot of people. A shame you don’t live down the street. You could drop over and see in real time how I struggle with this stuff. 😬
                  Rich O Brien Moderator @Box
                  @Box said in I’ve Been “Boxed”:
                  Then Dave or Rich will split the relevant post out of this one and into the new one.
                  @ntxdave @Box
                  let me know by tagging me in that new thread and I'll move this sidebar.
                  @tuna1957
                  loving these shares!
                  • tuna1957T
                    tuna1957
                    Another odd object. Experimented with a bunch of different effects for the material on the globe when rendering.😎
                    • ntxdaveN
                      ntxdave
                      I thought I saw a video somewhere using the quad face tool plugin to draw something like a fancy btacelet but I cannot fing it anymore. Does anyone know where I can find it?
                      • tuna1957T
                        tuna1957
                        Another odd little thing. Pulled some parts from an early practice model and ended up with this…😎
                        Reply Quote 2
                        • tuna1957T
                          tuna1957
                          Dug up an old file. I’d been practicing twisting stuff. Copied out one of the rings and here’s the result. Playing around with this stuff is fun. 😎 Including a pic of the proxy.
                          • ntxdaveN
                            ntxdave
                            I would like to learn more about how to do stuff like this. Here is my most recent trial/practice.
                            I did not use anything like FredoScale. Can you share with me how to use a tool like that to twist something? Also, did you do this with SU 2025? If so, how do you get a glass/glossy look to the interior part of you model?
                            • tuna1957T
                              tuna1957 @ntxdave
                              @ntxdave I use SU Pro15 and 18. The finished image was rendered in Twilight. The glass has a “Flint Glass” template applied in Twilight. To my understanding even with the added PBR materials in SU25 if you want true realism your going to have to use a render software.
                                Very bloudy sharp, Sir. Inspirational.
                                • tuna1957T
                                  tuna1957 @Mike Amos
                                  @Mike-Amos Thank you Mr. Mike
                                  • ntxdaveN
                                    ntxdave @tuna1957
                                    @tuna1957 OK, I just messed around with the FredoScale tool and some additional messing around with things in 2025 and here is my latest trial.
                                    So, I think to your suggestion of the FredoScale tool and messing around I have made some more progress. 😀
                                    • L
                                      I love where you are heading with this, very cool stuff, you have been very boxed indeed👍
                                      • tuna1957T
                                        tuna1957 @L i am
                                        @L-i-am Thank you sir. ✌️
                                        • tuna1957T
                                          tuna1957
                                          More fun time stuff. Only three components. Drew the path for the upper twists directly on the globe. Fredo’s Tools on Surface makes short work of it. The most time was spent on the render side. Played in Twilight’s Deep Material Editor to get the effect on the globe. 😎
                                          • ntxdaveN
                                            ntxdave @tuna1957
                                            @tuna1957 said in I’ve Been “Boxed”:
                                            I need to understand how you drew the path.
                                            • 2 / 3
