    I’ve Been “Boxed”
    54 Posts 7 Posters 6.4k Views 6 Watching
    • tuna1957T
      tuna1957
      Dug up an old file. I’d been practicing twisting stuff. Copied out one of the rings and here’s the result. Playing around with this stuff is fun. 😎 Including a pic of the proxy.
      ntxdaveN 1 Reply Last reply
      • ntxdaveN
        ntxdave
        I would like to learn more about how to do stuff like this. Here is my most recent trial/practice.
        I did not use anything like FredoScale. Can you share with me how to use a tool like that to twist something? Also, did you do this with SU 2025? If so, how do you get a glass/glossy look to the interior part of you model?
        Press F1...thank me later
        tuna1957T 1 Reply Last reply
        • tuna1957T
          tuna1957 @ntxdave
          @ntxdave I use SU Pro15 and 18. The finished image was rendered in Twilight. The glass has a “Flint Glass” template applied in Twilight. To my understanding even with the added PBR materials in SU25 if you want true realism your going to have to use a render software.
            Very bloudy sharp, Sir. Inspirational.
            • tuna1957T
              tuna1957 @Mike Amos
              @Mike-Amos Thank you Mr. Mike
              • ntxdaveN
                ntxdave @tuna1957
                @tuna1957 OK, I just messed around with the FredoScale tool and some additional messing around with things in 2025 and here is my latest trial.
                So, I think to your suggestion of the FredoScale tool and messing around I have made some more progress. 😀
                • L
                  I love where you are heading with this, very cool stuff, you have been very boxed indeed👍
                  • tuna1957T
                    tuna1957 @L i am
                    @L-i-am Thank you sir. ✌️
                    • tuna1957T
                      tuna1957
                      More fun time stuff. Only three components. Drew the path for the upper twists directly on the globe. Fredo’s Tools on Surface makes short work of it. The most time was spent on the render side. Played in Twilight’s Deep Material Editor to get the effect on the globe. 😎
                      • ntxdaveN
                        ntxdave @tuna1957
                        @tuna1957 said in I’ve Been “Boxed”:
                        I need to understand how you drew the path.
                        • tuna1957T
                          tuna1957 @ntxdave
                          @ntxdave “Tools on Surface” allows you to draw on curved surfaces. Turned on hidden geometry which helps to keep things aligned. You just have to play and experiment to get used to how it works. The upper twists are 24 copies of one component.
                          • ntxdaveN
                            ntxdave @tuna1957
                            OK, I just installed Tools on Surface but I am having problems trying to figure out how to draw things like you did. Any advice as to any tutorials or places to learn how to use the tool?
                            • tuna1957T
                              tuna1957 @ntxdave
                              @ntxdave check here
                              https://community.sketchucation.com/topic/105258/plugin-tools-on-surface-v2-6a-01-apr-24
                              • ntxdaveN
                                ntxdave @tuna1957
                                @tuna1957 Well, I am beginning to learn but I have a LONG way to go. 😁
                                • tuna1957T
                                  tuna1957
                                  More late night twisty things. 😎
                                  Reply Quote 5
                                  • L
                                    You have been very boxed, nice work mate
                                      It's muddy brilliant...
                                      • tuna1957T
                                        tuna1957
                                        Thanks gentlemen.
                                        • Bryan KB
                                          Excellent work!
                                          • 3 / 3
