    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      Its exactly the same as @Mike-Backman
      It is what referred to as a mention. If you @ someone they are notified of the mention if they have notifications set.
      You cannot DM members because your reputation level is below the minimum threshold. This is a measure to stop spam accounts creating unwanted content.
      If you want help with LOTT just post your issues here:
      https://community.sketchucation.com/post/1581174
      Fredo will read that and respond if he wishes.
      • V Offline
        VoNn3 Newcomers
        Bonjour, j'ai aujourd'hui essayé l'outil fredoscale et merci beaucoup pour votre incroyable travail.
        J'ai cependant un petit problème. J'ai utilisé "boxtapering" pour modifier un ensemble de composant ce qui a marché à merveille. Néanmoin, une fois les pièces modifiés, leurs taille devient imprecise et les pièces ne sont plus reconnues par le plugin "opencutlist" et donc impossible de générer une liste de débit. Je ne sais pas si c'est un problème solutionnable je pose ici le problème.
        Merci encore !
        Hello, I tried the fredoscale tool today and thank you very much for your incredible work.
        However, I have a small problem. I used "boxtapering" to modify a set of components which worked wonderfully. However, once the parts are modified, their size becomes imprecise and the parts are no longer recognized by the "opencutlist" plugin and therefore impossible to generate a cutting list. I do not know if this is a solvable problem, I am asking the problem here.
        Thanks again!
          Mae50 Newcomers
          Good morning,
          I am a daily user of this plugin.
          I just installed SKP 2024 and FredoScale - v3.6a on my new machine. The license is active but when I click on the tool nothing happens.
          Can you help me?
          Bonjour,
          je suis une utilisatrice quotidienne de ce plugin.
          Je viens d'installer SKP 2024 et FredoScale - v3.6a sur ma nouvelle machine. La licence est active mais quand je clique sur l'outil rien ne se passe.
          Est-ce que vous pouvez m'aider ?
            @Mae50
            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
              Mae50 Newcomers
              @Rich-O-Brien
              Thanks for your support !
              Fredo6 Plugins Information on 2025-03-04 09:59:17 +0100
              • Sketchup: 24.0.594
              • LibFredo6: v15.1a
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.1
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                FredoScale v3.6a - licensed FULL
                Signature File: 2025-02-24 16:52:48 +0100
                FredoScale: 2025-03-04 09:56:38 +0100
                @Mae50 That looks good.
                Can you explain in more detail what is happening?
                If you open the Ruby Console via Extensions > Developer > Ruby Console and click on a toolbar icons you see errors in the console?
                If your SketchUp install does not have the correct privileges you can repair the SketchUp installation by downloading the installer and right clicking and choosing Run as Admin
                When prompted choose Repair.
                  Mae50 Newcomers
                  @Rich-O-Brien
                  When I click on a tool Ruby Console says :
                  • LibFredo6: v15.1a
                  • Fredo6 Plugins
                    Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                    c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in initialize' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in open'
                    c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in write_to_file' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:150:in store'
                    c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1474:in usage_use' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1462:in command_invoke'
                    c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in block (2 levels) in build_config_commands' c:/users/julie/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1490:in block in add_command'
                    Yes, that looks like your SketchUp install is missing the correct permissions. Following my instructions to Repair should rectify it.
                    Or go to C:/Users/julie/AppData/Local/LIBFREDO6_DATA_Dir and delete the LibFredo6_all_defaults.dat file and start SketchUp
                    I'd recommend the top option to ensure you don't encounter other issues related to permissions.
                      Mae50 Newcomers
                      Thanks I do the first option, but it's not ok .
                      Console Ruby :
                        Mae50 Newcomers
                        @Rich-O-Brien
                        I just try the second option
                        and it's ok.
                        Thank you very very much for your support
                        • N Offline
                          NetJaro
                          Hi!
                          I think I found bug.
                          Sometimes, when I rotate my element i change dimensons there is a error with area of my component.
                          Look at this video: 2025-03-11 16 06 21.mp4
                          Someone can help me?
                          Marcin.
                          • fredo6F Offline
                            I would need to have the model to understand, especially because the video is unclear about what exactly you do to the cube with the rotation.
                            Also, can you turn on 'Show Hidden geometry', just in case there are hidden elements in the group.
                            N 1 Reply Last reply Reply Quote 0
                            • F Offline
                              FlorinAp
                              Box Stretching options has a bug - it does correctly only the first level of components nesting, starting with the second level, it doesn't make unique on the first run (it messes up all your components in the model.!), and if you hit Ctrl+Z (only ONCE.!) it reverses the modification, and after that they remain unique and you can modify...
                              Very disturbing.!
                              Curic Stretch works flawlessly, but it is not so handy and fast to use, so is the last option. I use it only when what I want to modify is much too heavy (loaded with many faces and edges... usually organic shapes, but also cabinets with more then 3 drawers because it freezes calculating) because it can handle much more amount of geometry, in these situations, Fredo Scale does only half the job and you end up seeing that only a few pieces have been modified.
                              • N Offline
                                NetJaro @fredo6
                                [@fredo6 thanks for your answer and thank you for what you do for Sketchup 🙂
                                I include my model.
                                One object (on the left) is original, second object (on the right) is after rotate by Sketchup official rotate function.
                                The bug doesn't show always in first time - try rotate left object, when its good (without bug) - use "undo" and try again.
                                bug.skp
                                Thanks for you help!
                                Regards,
                                Marcin
                                • fredo6F Offline
                                  What is the relation with FredoScale then?
                                  Note that I tried to rotate both objects, with Undo and try again. I did not find any issue
                                  • N Offline
                                    NetJaro @fredo6
                                    @fredo6 Hi!
                                    The problem with area of the object is only when I use a FredoScale.
                                    Below I include a longer video with problem.
                                    Image 002.mp4
                                    E 1 Reply Last reply Reply Quote 0
                                    • fredo6F Offline
                                      I cannot reproduce the issue with the Stretch tool followed by a SU Rotate.
                                      Do you have it on any object or just this one ?
                                      By the way, it looks like you component is a Dynamic component, or at least was a dynamic component.
                                      • N Offline
                                        noseno002
                                        Bundle of 8 plugins are compatible with SketchUp 2025?
                                        I'm interested in the Fredo scale, RoundCorner, and others.
                                          Dave R @noseno002
                                          @noseno002 yes. They all work with SketchUp 2025.
                                          • E Offline
                                            elfis @NetJaro
                                            I'm using this plugin for ears, but this has always been the case. It's not a big problem—when the cursor highlights the edge like in your video, just press it, and the bounding box will align.
                                            @NetJaro said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                            @fredo6 Hi!
                                            Image 002.mp4
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 56
                                            • 57
                                            • 27 / 57
