    Rayscaper render Living room with a cold view.
    42 Posts 7 Posters 3.0k Views 7 Watching
      I can make the texture 'brighter' and give the illusion of light but that's all and depends on the quality of the transparencey. I believe the best bet would bethe image within a light which was posted on the Twilight forum but it's down now so I cannot actually reference it. Darn it.
        OK, flat plane with fire texture applied.
        Projector light 26" x 24" 12" behind the flat plane.
        Fire texture set to 'thin curtain'.
        The projector light set to project the 'flame texture, 400 x the efficacy of the light source of 100Watts.
        There needs to be a certain degree of adjustment which might work.
        Fed the Badgers and the cat and I am giving up for the time being, 00:30 in the AM.
          Mike Amos @Mike Amos
          OK, I am fixated on the target, checking the idea about size of the projected image. 46" x 44". I think I am right, might also need to ramp up the power some more.
            56" x 54" and 200 watts, I have NOT messed with exposure and render time with the one light source was 32m which is on the long side but no doubt additional light sources will alter render times.
            Something I also mucked about with is distance from projector light source tp the target plane which in this instance is 12".
            tuna1957T 1 Reply Last reply Reply Quote 0
              It's hard to decipher what going on as it is only a rendered image. There's no spotlight values or a raw SketchUp image showing the setup.
                Not a scene, just playing with 'projector light' settings in Twilight render. I might try with a full scene to see where adjustment gets me. Not very far in previous attempts.
                • tuna1957T Offline
                  tuna1957 @Mike Amos
                  @Mike-Amos Couldn’t help myself. Experiments with Twilight. Very quick test of the whole scene. On the dark side, didn’t want to mess in post pro just for a test. Included images showing placement of flame .png image, point lights and their values.
                  • tuna1957T Offline
                    tuna1957
                    Mike, The testing is far from done. Need to mess about with light placement and power some more.
                    • tuna1957T Offline
                      tuna1957
                      Mike, here’s another flame .png image you might like.
                        Mike Amos @tuna1957
                        @tuna1957
                        I like the render, under the weather a bit so not had the chance to chuck a proper go at this.
                        In this render, another image and it has three 'round' or area lights with three images turned about the centre point.
                        tuna1957T 1 Reply Last reply Reply Quote 1
                        • tuna1957T Offline
                          tuna1957 @Mike Amos
                          @Mike-Amos Making good progress. Keep it up your heading forward. Hope you get feeling better. 👍
                            Ta mate, base over apex when the cut got under my feet.........
                            • 2 / 3
