    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Tutorial 59 - Multi-Board Treads and Side Spacers (7:15 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.8.2 - 01.05.2025
        • Added balusters to the stair module for vertical and OTP handrails.
        • Added newel posts to the stair module for vertical and OTP handrails.
        Tutorial 60 - Balusters, Posts and Handrails (16:39)
        design.medeek.com
        • medeekM
          medeek
          Version 3.8.3 - 01.10.2025
          • Added a "deck" profile or option for handrails (with balusters) to the stair module.
          Tutorial 61- Handrails for Decks (8:51 min.)
          design.medeek.com
          • medeekM
            medeek
            Version 3.8.4 - 01.14.2025
            • Added a minimum winder depth parameter for all stair winder types.
            • Adjusted the deck handrail algorithm for narrow cap rails (2x4).
            design.medeek.com
            • medeekM
              medeek
              Version 3.8.5 - 01.21.2025
              • Updated the skirt boards to accommodate open treads.
              • Added tread covers, carpet and stair runners for stairs, landings and winders.
              wall_su905_800.jpg wall_su906_800.jpg wall_su907_800.jpg wall_su908_800.jpg wall_su909_800.jpg wall_su910_800.jpg wall_su911_800.jpg
              design.medeek.com
              • medeekM
                medeek
                Tutorial 63 - Stair Runners and Tread Covers (10:06 min.)
                design.medeek.com
                Reply Quote 2
                • medeekM
                  medeek
                  [b]Version 3.8.6[/b] - 01.25.2025
                  • Added tread covers, carpet and stair runners for T-shaped landings.
                  • Enabled the option for a single stringer (for modern style stairs).
                  • Added an option to disable the placeholder for landing/winder framing.
                  • Added a "GLASS" option for balusters within the built-in baluster materials.
                  • Added a "None" built-in option for the handrail profile parameter.
                  design.medeek.com
                  • medeekM
                    medeek
                    Tutorial 64 - Modern Stairs (12:43 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.8.7 - 01.28.2025
                      • Enabed subtractive geometry for all stair assemblies.
                      • Added the following two parameters to the baluster sub-menus: Baluster Type (Square, Round, Glass, Cable), Baluster Height.
                      • Enabled intermediate posts for both glass and cable railing.
                      • Added the following cable railing options into the Stairs tab of the Global Settings: Cable Railing Spacing, Cable Railing Diameter.
                      • Added a bottom vertical offset parameter for bottom posts of a stair run.
                      wall_su923_800.jpg wall_su924_800.jpg wall_su925_800.jpg wall_su926_800.jpg wall_su927_800.jpg
                      Tutorial 65 - Cable and Glass Railing (13:26 min.)
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.8.7b - 01.29.2025
                        • Fixed a bug with the baluster options.
                        • Enabled a zero stringer option for floating stairs.
                        design.medeek.com
                        • medeekM
                          medeek
                          Just a few more loose ends before I jump back to the Floor plugin.
                          I would like to enable landing treads for winders, but things get a little interesting when the min. winder length is set to zero. Does this look okay?
                          design.medeek.com
                            In my UK jurisdiction, and I suspect many more, you are not allowed 'winders' but 'tapered treads'.
                            The calculation of the dimensions is convoluted.
                            The minimum 'going' is 50mm [2"] and any tapering tread at the centerline must have a 'going' measured square to the nosing equal to all the other non-tapering treads.
                            For non-domestic wider stairs the measurements are taken measured in from the sides - about 1/3 each.
                            The 'going' is not the 'tread' dimension - the overhang of the nosing is taken off the tread size, so it's the 'plan' dimension.
                            When you get to anything other than a simple staircase it can become very complicated to 'automate'.
                            In the UK a helical stair [aka 'spiral'] even has a set of alternative British Standard staircase rules which differ significantly from the usual stair Building Regs - you need to tell the local inspector which one you're using otherwise you could fail.
                            I've mentioned before about the handrail requirements in the regs to extend 300mm [12"] beyond the top and bottom nosings in many situations, and the landing's going the be 300mm longer than the stair width.
                            Also, staggering the nosings by one going as the stair turns at a half-landing [or top] means that the handrail transitions smoothly without any need for a vertical portion to make it work...
                            • gullfoG
                              gullfo
                              for some reason, many "metric" countries are using different building codes and material sizes from the others. whenever i start a studio design for someone - first check - get all the building codes and material sizing for that country established before beginning the actual design work. early on (~20 years ago) i made the mistake of assuming all metric countries were "standardized"... then after doing all the construction docs, during review the builder pointed out all the wrong dimensions on the materials, code-prohibited practices or confused one etc etc... needless to say another 3 weeks to fix it all...
                              Glenn
                              http://www.runnel.com
                              • medeekM
                                medeek
                                The lifetime licensing options are now permanently listed on the website:
                                404 - File or directory not found.
                                (design.medeek.com)
                                design.medeek.com
                                • gullfoG
                                  gullfo
                                  Q: does the 5 year "lifetime" license mean it expires after 5 years? or just the free updates are no longer available for use after the 5 years? i.e. i get free updates on the products for 5 years, but after 5 years, no more free updates but the software continues to be useable?
                                  Glenn
                                  medeekM 1 Reply Last reply
                                  • medeekM
                                    medeek
                                    Version 3.8.8 - 02.06.2025
                                    • Added landing treads, tread covers, carpet and stair runners for a winders.
                                    • Added an SIP wall framing option for all wall types.
                                    • Added five additional SIP parameters into the wall Draw and Edit menus.
                                    Tutorial 66 - SIP Walls (8:03 min.)
                                    design.medeek.com
                                    • medeekM
                                      medeek @gullfo
                                      @gullfo
                                      The licenses will continue to work forever, but no free updates after the five years.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.8.8b - 02.06.2025
                                        • Added the option for closed stringers.
                                        design.medeek.com
                                        Reply Quote 2
                                        • medeekM
                                          medeek
                                          Version 3.8.9 - 02.09.2025
                                          • Added preview thumbnails for handrail fittings to the draw and edit menus of the stair tool.
                                          • Fixed a bug with adjacent winders/landings for landing treads and covers.
                                          • Fixed a minor bug with materials for handrail fittings.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.9.0 - 02.11.2025
                                            • Enabled zero size intermediate posts (balusters) for glass railing.
                                            • Fixed a bug with floor level winders/landings for landing treads and covers.
                                            design.medeek.com
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 80
                                            • 81
                                            • 71 / 81
