    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v14.6a - 18 Sep 24
      LibFredo6 14.6a includes changes related to:
      • ThruPaint v2.5a
      • New plugins
      • U Offline
        unit611
        Hi. I've tinkered with my computer profile a bit, and ended up destroying my original profile. I had to use a recover program to repair the profile.
        After that, my fredo license wouldn't work with the sketchucation message showing "error A04". I repaired sketchup, but the problem wasn't solved. I even went ahead and bought a second license for the same plug-in, but it still said I had to revalidate. How do I revalidate my license in this situation?
        • Rich O BrienR Online
          Rich O Brien Moderator @unit611
          @unit611 said in [Plugin Library] LibFredo6 - v14.6a - 18 Sep 24:
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          U 1 Reply Last reply Reply Quote 0
          • U Offline
            unit611 @Rich O Brien
            @Rich-O-Brien
            the console says
            Fredo6 Plugins Information on 2024-09-27 08:42:14 +0900
            • Platform: x64-mswin64_140 - Ruby: 2.7.7
            • Sketchup: 23.1.340
            • LibFredo6: v14.6a
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.4.1
            • SCFLicense: v6.4a - 74
            • Fredo6 Plugins
              Curviloft v2.0a
              Curvizard v2.5a
              FredoCorner v2.7a
              FredoScale v3.6a
              JointPushPull v4.8a
              ToolsOnSurface v2.6a
              TopoShaper v2.7a
              VisuHole v1.5a
              Signature File: absent
            would this help?
              @unit611 The last line shows that there is no signature file.
              This may be because your SketchUp install does not have the correct system read/write permissions.
              To remedy that you need to repair your SketchUp install. You'll find info on how to do that if you press F1 with SketchUp open.
              If you visit this path in your Windows Explorer...
              C:\Users\SomeName\AppData\Local\SCF Licenses
              What do you see?
              • U Offline
                @Rich-O-Brien
                There's two files, SCFLicenseLog and SCFLicenseSignature-DO NOT MODIFY OR DELETE.
                I've already tried repairing sketchup via sketchup unistaller, but it didn't seem to do anything.
                  Please delete SCFLicenseSignature-DO NOT MODIFY OR DELETE.txt file with SketchUp closed
                  Open SketchUp and run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output here
                  • U Offline
                    @Rich-O-Brien
                    Fredo6 Plugins Information on 2024-09-28 01:11:53 +0900
                    • LibFredo6: v14.6a
                    • Fredo6 Plugins
                      Curviloft v2.0a
                      Curvizard v2.5a
                      FredoCorner v2.7a
                      FredoScale v3.6a
                      JointPushPull v4.8a
                      TopoShaper v2.7a
                      VisuHole v1.5a
                    It still says the signature file is absent. Is there something wrong with the folder I saved my licenses?
                    TIGT 1 Reply Last reply Reply Quote 0
                    • TIGT Online
                      TIG Moderator @unit611
                      @unit611
                      The reason that Rich suggested you closed SketchUp and then did the Repair to your SketchUp installation using 'Run as administrator' context-menu on the installer's exe file, is that an incorrect installation [e.g. if you double-clicked the exe to just 'run' it] can cause weird and unpredictable issues - often revolving around permissions to read and write files etc...
                      That licenses signature file is made when you license your first extension.
                      It's added to as you license more extensions.
                      Have you got a set of license files saved somewhere on your computer ?
                      You need to validate each of these extensions in turn, extension by extension, using the Tools menu submenu item for each extension.
                      After you've validated all of them they should all work.
                      You might need to restart SketchUp to sync everything...
                      U 2 Replies Last reply Reply Quote 0
                      • U Offline
                        unit611 @TIG
                        @TIG
                        I tried uninstalling and reinstalling sketchup, but it seems like I should try again with deleting every sketchup-related files I can get my hands on. Maybe then I should try as you suggested.
                        On the other hand, is a pop-up window saying "B03" also an error?
                        Rich O BrienR TIGT 2 Replies Last reply Reply Quote 0
                          @TIG
                          • TIGT Online
                            @unit611
                            I did not tell you to uninstall SketchUp - a simple 'Repair' will suffice.
                            Do not delete files randomly - it'll break something somewhere.
                            When you install SketchUp are you using 'Run as administrator' ?
                            The B03 pop up window probably relates to SketchUcation licensing errors.
                            After a proper installation AND a validation of the various licenses, there should be no more errors.
                            Do as Rich says about outputting your SCF settings - doing it before AND after the fixes would help...
                            • U Offline
                              unit611 @TIG
                              @TIG
                              I did what Rich-O-Brien said, running th repair as administrator, with the sketchup closed. But nothing's changed. It keeps showing B03 when I first click on "activate license", and A04 when I apply my license file, which is in my "C:-users-profile name-desktop" route.
                              Has it got to do with me recently changing the PC's name? I've been using the rubies for a while before I changed my desktop's name in the windows system setting.
                              • TIGT Online
                                @unit611
                                Giving us all of the info is helpful - not in dribs-and-drabs...
                                The A04 error tells us that the license signature file is somehow incorrect - i.e. not [necessarily] the license file itself
                                If you have changed your PC name you do need to delete your signature file and redo things, so that the validations then point to the correct signature file.
                                Changing your PC's name [or Windows user-name] can also cause weird issues, if you have not followed the naming conventions - e.g. use only ASCII letters and numbers, with a limited number of other punctuation characters... there are already threads about this...
                                W 2 Replies Last reply Reply Quote 0
                                • W Offline
                                  wskim Newcomers @TIG
                                  @TIG
                                  Sorry about that I'll try as you say
                                  • W Offline
                                    @TIG
                                    I changed my PC name back to english only and it worked. I guess it was because I used non-conventional letters, as you said.
                                    thanks for all the help
                                    • E Offline
                                      erikcoleman1992
                                      Hello,
                                      I am currently trying to install Round corner and it says I need to update to fred06 v14.6. do I have to uninstall the old version to update to the new one or is there an easier way?? or am I missing something completely!?
                                      any information would be appreciated trying to do a school project rn and i need that bevel tool!
                                        Rich O Brien Moderator @erikcoleman1992
                                        @erikcoleman1992 Install Sketchucation Tools 4.4.1
                                        Sketchucation Tools | SketchUcation
                                        (sketchucation.com)
                                        Then use that to install/update extensions.
                                        Restart SketchUp to complete installations fully.
                                        Fredo's extension require Libfredo to fully function
                                        • I Offline
                                          IsaiARQJ
                                          Hola, quiero pagar la licencia ara uso del Lib Fredo6 perpetuo pero no encuentro la forma ni estรก claro como hacer el pago de la licencia. Me pueden resolver el problema ?
                                          • TIGT Online
                                            TIG Moderator @IsaiARQJ
                                            @IsaiARQJ
                                            LibFredo6 is a free library used by many of his extensions - some of those are paid.
                                            So you do need alicense for that library.
                                            LibFredo6 es una colecciรณn gratuita que utilizan muchas de sus extensiones; algunas de ellas son de pago.
                                            Por lo tanto, necesitas una licencia para esa biblioteca.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 109
                                            • 110
                                            • 15 / 110
