    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • F
      Fer18
      I need The Pluggin
      TIGT 1 Reply Last reply
        TIG Moderator @Fer18
        @Fer18
        Your posts makes little sense !
        If you need LibFredo6 download/install it from the PluginStore.
        If you need some other Plugin [aka an Extension] then post in its thread - OR explain yourself better - we are not mind-readers...
          miiraka Newcomers
          thank you so much
            DESIGN7
            I am using Sketchup 2024 Pro version on a PC computer.
            I have downloaded LibFredo6-v14.5f:
            • the logo appears in Extension Manager but only as a grey (ghost) logo
            • does NOT appear in Extension Warehouse
            I have viewed the 15 minute video several times and still cannot figure out how to get access to the App. the video covers so many topics.
            Is there a simple set by step guide - text or video that show how to install LibFredo6?
              TIG Moderator @DESIGN7
              @DESIGN7
              As explained in the thread's first post: LibFredo6 is NOT a standalone plugin.
              It will appear in the native Extension Manager and should be 'active', but it does little else.
              It will have an entry in a Tools submenu if properly installed...
              It's used as a Lib[rary] to support most of Fredo's extensions.
              You need to install these separately...
              Have you restarted SketchUp after this installation so that everything is synced ?
              It will not appear in the Extension Warehouse - essentially because that is not the sole repository of good extensions.
              Several authors, like Fredo and myself, choose to provide our extensions solely through the SketchUcation PluginStore / ExtensionStore³...
              Some other developers publish on both platforms, while some others even use just their own web-sites to offer downloads...
              • fredo6F
                NEW RELEASE: LibFredo6 v14.6a - 18 Sep 24
                LibFredo6 14.6a includes changes related to:
                • ThruPaint v2.5a
                • New plugins
                • U
                  unit611
                  Hi. I've tinkered with my computer profile a bit, and ended up destroying my original profile. I had to use a recover program to repair the profile.
                  After that, my fredo license wouldn't work with the sketchucation message showing "error A04". I repaired sketchup, but the problem wasn't solved. I even went ahead and bought a second license for the same plug-in, but it still said I had to revalidate. How do I revalidate my license in this situation?
                    Rich O Brien Moderator @unit611
                    @unit611 said in [Plugin Library] LibFredo6 - v14.6a - 18 Sep 24:
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    U 1 Reply Last reply
                    • U
                      unit611 @Rich O Brien
                      @Rich-O-Brien
                      the console says
                      Fredo6 Plugins Information on 2024-09-27 08:42:14 +0900
                      • Platform: x64-mswin64_140 - Ruby: 2.7.7
                      • Sketchup: 23.1.340
                      • LibFredo6: v14.6a
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 4.4.1
                      • SCFLicense: v6.4a - 74
                      • Fredo6 Plugins
                        Curviloft v2.0a
                        Curvizard v2.5a
                        FredoCorner v2.7a
                        FredoScale v3.6a
                        JointPushPull v4.8a
                        ToolsOnSurface v2.6a
                        TopoShaper v2.7a
                        VisuHole v1.5a
                        Signature File: absent
                      would this help?
                        @unit611 The last line shows that there is no signature file.
                        This may be because your SketchUp install does not have the correct system read/write permissions.
                        To remedy that you need to repair your SketchUp install. You'll find info on how to do that if you press F1 with SketchUp open.
                        If you visit this path in your Windows Explorer...
                        C:\Users\SomeName\AppData\Local\SCF Licenses
                        What do you see?
                        • U
                          @Rich-O-Brien
                          There's two files, SCFLicenseLog and SCFLicenseSignature-DO NOT MODIFY OR DELETE.
                          I've already tried repairing sketchup via sketchup unistaller, but it didn't seem to do anything.
                            Please delete SCFLicenseSignature-DO NOT MODIFY OR DELETE.txt file with SketchUp closed
                            Open SketchUp and run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output here
                            • U
                              @Rich-O-Brien
                              Fredo6 Plugins Information on 2024-09-28 01:11:53 +0900
                              • LibFredo6: v14.6a
                              • Fredo6 Plugins
                                Curviloft v2.0a
                                Curvizard v2.5a
                                FredoCorner v2.7a
                                FredoScale v3.6a
                                JointPushPull v4.8a
                                TopoShaper v2.7a
                                VisuHole v1.5a
                              It still says the signature file is absent. Is there something wrong with the folder I saved my licenses?
                                TIG Moderator @unit611
                                @unit611
                                The reason that Rich suggested you closed SketchUp and then did the Repair to your SketchUp installation using 'Run as administrator' context-menu on the installer's exe file, is that an incorrect installation [e.g. if you double-clicked the exe to just 'run' it] can cause weird and unpredictable issues - often revolving around permissions to read and write files etc...
                                That licenses signature file is made when you license your first extension.
                                It's added to as you license more extensions.
                                Have you got a set of license files saved somewhere on your computer ?
                                You need to validate each of these extensions in turn, extension by extension, using the Tools menu submenu item for each extension.
                                After you've validated all of them they should all work.
                                You might need to restart SketchUp to sync everything...
                                U 2 Replies Last reply
                                • U
                                  unit611 @TIG
                                  @TIG
                                  I tried uninstalling and reinstalling sketchup, but it seems like I should try again with deleting every sketchup-related files I can get my hands on. Maybe then I should try as you suggested.
                                  On the other hand, is a pop-up window saying "B03" also an error?
                                  Rich O BrienR TIGT 2 Replies Last reply
                                    @TIG
                                      @unit611
                                      I did not tell you to uninstall SketchUp - a simple 'Repair' will suffice.
                                      Do not delete files randomly - it'll break something somewhere.
                                      When you install SketchUp are you using 'Run as administrator' ?
                                      The B03 pop up window probably relates to SketchUcation licensing errors.
                                      After a proper installation AND a validation of the various licenses, there should be no more errors.
                                      Do as Rich says about outputting your SCF settings - doing it before AND after the fixes would help...
                                      • U
                                        unit611 @TIG
                                        @TIG
                                        I did what Rich-O-Brien said, running th repair as administrator, with the sketchup closed. But nothing's changed. It keeps showing B03 when I first click on "activate license", and A04 when I apply my license file, which is in my "C:-users-profile name-desktop" route.
                                        Has it got to do with me recently changing the PC's name? I've been using the rubies for a while before I changed my desktop's name in the windows system setting.
                                          @unit611
                                          Giving us all of the info is helpful - not in dribs-and-drabs...
                                          The A04 error tells us that the license signature file is somehow incorrect - i.e. not [necessarily] the license file itself
                                          If you have changed your PC name you do need to delete your signature file and redo things, so that the validations then point to the correct signature file.
                                          Changing your PC's name [or Windows user-name] can also cause weird issues, if you have not followed the naming conventions - e.g. use only ASCII letters and numbers, with a limited number of other punctuation characters... there are already threads about this...
                                          W 2 Replies Last reply
                                          • W
                                            wskim Newcomers @TIG
                                            @TIG
                                            Sorry about that I'll try as you say
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 113
                                            • 114
                                            • 103 / 114
