    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.3m Views 585 Watching
    • U
      unit611 @Rich O Brien
      @Rich-O-Brien
      There's two files, SCFLicenseLog and SCFLicenseSignature-DO NOT MODIFY OR DELETE.
      I've already tried repairing sketchup via sketchup unistaller, but it didn't seem to do anything.
        Rich O Brien Moderator @unit611
        @unit611 said in [Plugin Library] LibFredo6 - v14.6a - 18 Sep 24:
        Please delete SCFLicenseSignature-DO NOT MODIFY OR DELETE.txt file with SketchUp closed
        Open SketchUp and run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output here
        U 1 Reply Last reply
        • U
          @Rich-O-Brien
          Fredo6 Plugins Information on 2024-09-28 01:11:53 +0900
          • Platform: x64-mswin64_140 - Ruby: 2.7.7
          • Sketchup: 23.1.340
          • LibFredo6: v14.6a
          • LibFredo6 Binary loaded
          • Sketchucation ExtensionStore: 4.4.1
          • SCFLicense: v6.4a - 74
          • Fredo6 Plugins
            Curviloft v2.0a
            Curvizard v2.5a
            FredoCorner v2.7a
            FredoScale v3.6a
            JointPushPull v4.8a
            ToolsOnSurface v2.6a
            TopoShaper v2.7a
            VisuHole v1.5a
            Signature File: absent
          It still says the signature file is absent. Is there something wrong with the folder I saved my licenses?
          TIGT 1 Reply Last reply
            TIG Moderator @unit611
            @unit611
            The reason that Rich suggested you closed SketchUp and then did the Repair to your SketchUp installation using 'Run as administrator' context-menu on the installer's exe file, is that an incorrect installation [e.g. if you double-clicked the exe to just 'run' it] can cause weird and unpredictable issues - often revolving around permissions to read and write files etc...
            That licenses signature file is made when you license your first extension.
            It's added to as you license more extensions.
            Have you got a set of license files saved somewhere on your computer ?
            You need to validate each of these extensions in turn, extension by extension, using the Tools menu submenu item for each extension.
            After you've validated all of them they should all work.
            You might need to restart SketchUp to sync everything...
            U 2 Replies Last reply
            • U
              unit611 @TIG
              @TIG
              I tried uninstalling and reinstalling sketchup, but it seems like I should try again with deleting every sketchup-related files I can get my hands on. Maybe then I should try as you suggested.
              On the other hand, is a pop-up window saying "B03" also an error?
              Rich O BrienR TIGT 2 Replies Last reply
                @TIG
                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  @unit611
                  I did not tell you to uninstall SketchUp - a simple 'Repair' will suffice.
                  Do not delete files randomly - it'll break something somewhere.
                  When you install SketchUp are you using 'Run as administrator' ?
                  The B03 pop up window probably relates to SketchUcation licensing errors.
                  After a proper installation AND a validation of the various licenses, there should be no more errors.
                  Do as Rich says about outputting your SCF settings - doing it before AND after the fixes would help...
                  • U
                    unit611 @TIG
                    @TIG
                    I did what Rich-O-Brien said, running th repair as administrator, with the sketchup closed. But nothing's changed. It keeps showing B03 when I first click on "activate license", and A04 when I apply my license file, which is in my "C:-users-profile name-desktop" route.
                    Has it got to do with me recently changing the PC's name? I've been using the rubies for a while before I changed my desktop's name in the windows system setting.
                      @unit611
                      Giving us all of the info is helpful - not in dribs-and-drabs...
                      The A04 error tells us that the license signature file is somehow incorrect - i.e. not [necessarily] the license file itself
                      If you have changed your PC name you do need to delete your signature file and redo things, so that the validations then point to the correct signature file.
                      Changing your PC's name [or Windows user-name] can also cause weird issues, if you have not followed the naming conventions - e.g. use only ASCII letters and numbers, with a limited number of other punctuation characters... there are already threads about this...
                      W 2 Replies Last reply
                      • W
                        wskim Newcomers @TIG
                        @TIG
                        Sorry about that I'll try as you say
                        • W
                          @TIG
                          I changed my PC name back to english only and it worked. I guess it was because I used non-conventional letters, as you said.
                          thanks for all the help
                          • E
                            erikcoleman1992
                            Hello,
                            I am currently trying to install Round corner and it says I need to update to fred06 v14.6. do I have to uninstall the old version to update to the new one or is there an easier way?? or am I missing something completely!?
                            any information would be appreciated trying to do a school project rn and i need that bevel tool!
                              Rich O Brien Moderator @erikcoleman1992
                              @erikcoleman1992 Install Sketchucation Tools 4.4.1
                              Sketchucation Tools | SketchUcation
                              (sketchucation.com)
                              Then use that to install/update extensions.
                              Restart SketchUp to complete installations fully.
                              Fredo's extension require Libfredo to fully function
                              • I
                                IsaiARQJ
                                Hola, quiero pagar la licencia ara uso del Lib Fredo6 perpetuo pero no encuentro la forma ni está claro como hacer el pago de la licencia. Me pueden resolver el problema ?
                                  TIG Moderator @IsaiARQJ
                                  @IsaiARQJ
                                  LibFredo6 is a free library used by many of his extensions - some of those are paid.
                                  So you do need alicense for that library.
                                  LibFredo6 es una colección gratuita que utilizan muchas de sus extensiones; algunas de ellas son de pago.
                                  Por lo tanto, necesitas una licencia para esa biblioteca.
                                  • N
                                    natas_ha
                                    I bought the licence and installed the rbz file but nothing is happening. When I open Sketchup it constantly telling me that I need to install the LibFredo plug in but I already did it. How to continue with this?
                                      Rich O Brien Moderator @natas_ha
                                      @natas_ha
                                      Libfredo is a helper library for many of Fredo's other extensions. On its own it serves no real purpose
                                        TIG Moderator @natas_ha
                                        @natas_ha
                                        Which of Fredo's extensions did you license ?
                                        Do you have the latest version of his helper extension LibFredo6 installed ?
                                        Did you restart to sync everything ?
                                        Also do you also have the latest version of the SketchUcation tools installed - for the licensing...
                                        If none of this helps repost and someone will ask you for more details...
                                        N 1 Reply Last reply
                                        • N
                                          natas_ha @TIG
                                          @TIG FredoCorner_v2.7a this extension and I bought the Perpetual licence. I installed the rbz file and nothing is happening. It gives me constantly this:Screenshot 2024-11-08 150415.jpg
                                          Dave RD 1 Reply Last reply
                                            Dave R @natas_ha
                                            @natas_ha are you sure you bought the license for FredoCorner and not RoundCorner? Many people have gotten confused and tried to use the license for one on the other. They are different extensions and require different licenses.
                                            Did you install LibFredo6 using the Sketchucation ExtensionStore and then restart SketchUp?
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 112
                                            • 113
                                            • 104 / 113
