    2.3k Posts 515 Posters 2.2m Views 520 Watching
    • N Offline
      November11 Newcomers
      Please tell me how to solve the problem??
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @November11
        @November11
        Follow the message's instructions on opening the folder and deleting the file.
        You might need to rename your computer...
        Your computer-name must follow the Windows rules - i.e. NO special characters in it...
        This is a range of characters that can be considered safe:
        Letters (a-z A-Z)
        Digits (0-9)
        Underscore (_)
        Hyphen (-)
        Space
        Dot (.)
        Beyond this, you just have to enforce some additional rules regarding spaces and dots. This is usually sufficient:
        Name must contain at least one letter or number (to avoid only dots/spaces)
        Name must start with a letter or number (to avoid leading dots/spaces)
        Name may not end with a dot or space
        Do you have any special characters in the computer-name OR your user-name ? - I guess you are Chinese ?
        Try fixing that and restart to see if that helps...
        Let us know how you get on...
          SergioAlbelli Newcomers
          I have purchased an license last year. And when I try to use the Freddy Roundcorner Plugin. The system says, "free trail expired"?
          Rich O BrienR TIGT 2 Replies Last reply Reply Quote 0
            Rich O Brien Moderator @SergioAlbelli
            @SergioAlbelli Please check if your extensions are updated to latest releases.
            https://sketchucation.com/plugin/696-sketchucationtools
            https://sketchucation.com/pluginstore?pln=LibFredo6
            https://sketchucation.com/pluginstore?pln=Roundcorner
            You can do this directly in SketchUp using Extensions > Sketchucation > ExtensionStore
            Restart SketchUp after updating and then follow the licensing guide to activate: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
              TIG Moderator @SergioAlbelli
              @SergioAlbelli
              In addition to Rich's useful info...
              We are assuming you have bought a license for Fredo's RoundCorner extension and not his other FredoCorner extension, whatever, then you need to save its file onto your computer and then validate it in the appropriate dialog opened from that extension's submenu in the Tools menu...
              There are pages to help you mange your licenses as listed in this thread...
              We need more info if you still can't resolve it...
                ameerproxy @Rich O Brien
                @Rich-O-Brien
                Hi Rich, i tried the the method ie: to delete SCF licence and restart and activate , that timethe licence was activated ,
                but the issue is that i am facing now is the other fredo plugins licence was deactivate , then again i need to close and do the process
                at a time only one plugin can activate and ready to use
                A 1 Reply Last reply Reply Quote 0
                  ameerproxy @ameerproxy
                  @ameerproxy
                  For MY Information, Is the plugins need internet connection even after activated the license also , Please advise
                  Thanks in advance
                    Rich O Brien Moderator @ameerproxy
                    @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                    @ameerproxy
                    Thanks in advance
                    Licenses need an internet connection to activate. After that there is only periodic checks.
                    In most cases the ruby console will output errors which would be useful to share to help us help you.
                    Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and paste the text into your reply.
                      MateusArq2024 Newcomers
                      I already bought the license but I can't validate it, due to the erroro
                        Rich O Brien Moderator @MateusArq2024
                        @MateusArq2024 Please whitelist *.sketchucation.com or switch to a less strict network.
                        M 1 Reply Last reply Reply Quote 0
                          MateusArq2024 Newcomers @Rich O Brien
                          @Rich-O-Brien thank you!
                          • Q Offline
                            QZHOU Newcomers
                            Hello,
                            what is the problem of my license, I have try many times. 5b600b653cc132d6872b4551a581adb.png 081e6864baccbdc5aefb6373b4b495f.png
                              TIG Moderator @QZHOU
                              @QZHOU
                              You need to install the latest versions of the extension, LibFredo6 and the SketchUcation toolset [for the licensing].
                              That error message says the signature-file cannot be read.
                              You may have changed your computer's name, which invalidates it.
                              It suggests you open the signature-file's folder and delete it.
                              After a restart a new signature file is made to suit the current setup.
                              The validate your license[s]...
                              Note that errors like this can also occur if your computer's name contains non-ASCII characters - going against the advise of Windows.
                              I suspect that you are Chinese - so have you got any special-characters in your computer-name ?
                              This can break licensing setups like this...
                              Try renaming your computer following these rules...
                              A-Za-z0-9 - are OK
                              The following are not OK...
                              period (.)
                              backslash (\)
                              forward slash (/)
                              colon (:)
                              asterisk (*)
                              question mark (?)
                              quotation mark (")
                              less than sign (<)
                              greater than sign (>)
                              vertical bar (|)
                              And ay other special characters or non-ASCII foreign alphabet letters will also cause issues,
                              • noorhalimmahatN Offline
                                noorhalimmahat
                                Hi Fredo. is this licences work for sketchup Pro2018?
                                  alexkhaterfredrik
                                  why do i keep getting ERROR_A0C Computer mismatch?!
                                    Rich O Brien Moderator @alexkhaterfredrik
                                    @alexkhaterfredrik said in SCFLicense: Extension Licensing on Sketchucation:
                                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                    You either renamed your device or copied license files from device to device
                                    Run the command above so we can see your setup
                                      analuiizaa
                                      Someone can help me with this?? my licese does not work!!!!
                                        Rich O Brien Moderator @analuiizaa
                                        @analuiizaa Sure, please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste the text into your reply.
                                        Or share the error messages you are encountering.
                                          djcregan
                                          HI
                                          I have sketchup 24 and a Fredoscale perpetual licence, after getting a message saying my trial was up I tried loading my licence, however it wont let me a nd say "Error in the License Validation Response from Sketchucation: License seats exceeded"
                                          I recently replaced my old work computer but I cant see how I can release the licence for it. Please help
                                            Rich O Brien Moderator @djcregan
                                            @djcregan said in SCFLicense: Extension Licensing on Sketchucation:
                                            You can manage seats at https://sketchucation.com/webshop/my-licences.php
                                            D 1 Reply Last reply Reply Quote 0
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 115
                                            • 116
                                            • 96 / 116
