    Rayscaper Learning-Practice
    53 Posts 4 Posters 5.9k Views 4 Watching
      Rich O Brien Moderator @ntxdave
      @ntxdave said in Rayscaper Learning-Practice:
      Are things like this included anywhere in the documentation?
      I don't know I've not yet looked at the docs. There's plenty of reading material online surrounding the topic though.
      https://creativecloud.adobe.com/learn/substance-3d-designer/web/the-pbr-guide-part-1
      That's a good introduction to PBR
      • pixelcruncherP
        pixelcruncher Extension Creator @Rich O Brien
        @ntxdave
        There's documentation here: https://rayscaper.com/manual/materials/#metal-material - Let me know if you have any feedback.
        You can access the documentation via the Help menu:
        The most feature-rich material in Rayscaper is the Disney material: https://rayscaper.com/manual/materials/#disney-material-pbr-material. This is a real PBR (physically based rendering) material.
        Cheers,
        Thomas
        • ntxdaveN
          ntxdave
          Is there any chance that Rayscaper is going to work with Lindale so that it is one of the render applications available in the Skatter plugin?
          Press F1...thank me later
          • ntxdaveN
            ntxdave
            Does anyone have any examples of exterior renders they have done with Rayscaper?
            • pixelcruncherP
              pixelcruncher Extension Creator @ntxdave
              @ntxdave Iโ€™m not familiar with the Skatter plugin from Lindale, but does it not work with Rayscaper?
              I assume it would just create component instances and then spread them around according to some brushes. Correct me if Iโ€™m wrong.
              • pixelcruncherP
                @ntxdave I donโ€™t have any outdoor renders, so if you do please share ๐Ÿ˜ most renders were done by @Rich-O-Brien and @majid and they were focusing on interiors.
                ntxdaveN 1 Reply Last reply
                • ntxdaveN
                  ntxdave @pixelcruncher
                  @pixelcruncher OK, was just curious if anyone had any to share. I have not tried any yet.
                  I have the Skatter plugin where you can add bushes and etc to models and it does not support Rayscaper.
                  Would like to see some though if anyone has any.
                  majidM 1 Reply Last reply
                  • majidM
                    majid @ntxdave
                    @ntxdave
                    Maybe an alternate solution works.
                    Make a component composed of two components, one very simple as a line (this would be our place holder), and the object you want to scatter. Separate their tag (layer) and hide the "complicated object's" layer (tag).
                    Now it is time to scatter the simple (placeholder) one.
                    It could be done using "component spray" plugin, I think.
                    It must render fine in RS, I guess.
                    • ntxdaveN
                      ntxdave
                      Well, here is my first attempt at an external render. Many things to work on but I have to admit I am a little surprised at how this went on my first try.
                      • pixelcruncherP
                        @ntxdave thatโ€™s a great first attempt! The windows could use some glass.
                        • ntxdaveN
                          @pixelcruncher Yes, I totally agree about the windows. I did try the glass on the roof. but I did a bad job. I might find another simpler model to try to adjust the glass and then come back to this one.
                          Rayscaper has a ton of options which makes the learning process kind of hard at times. From that point of view, while Twilight Render may not have had as many options, the user interface, at least is some aspects was a little simpler and easier to learn. Hope you do not take this as negative comments. I do not mean it that way.
                          The other issue I have is that there is no way to use Rayscaper with animations. I think this is becoming very popular these days and I hope it is something you plan for the future.
                          Again, I really appreciate your feedback/comments. ๐Ÿ‘
                          • ntxdaveN
                            ntxdave @ntxdave
                            • ntxdaveN
                              ntxdave
                              Some more learning ๐Ÿ˜
                              Here is my latest render. Some progress I think but one thing I am still struggling a little with is setting the scene in SketchUp so that it will produce the view I want in the render.
                              Reply Quote 2
                              • pixelcruncherP
                                It was not taken as negative! It's all good feedback. I understand it's not easy to use, it's something we should work on by improving the UI. But when I remember Twilight Render, it has a ton more options and features than Rayscaper. Is that not the case?
                                @ntxdave Can you clarify so I understand better and see how we can improve this?
                                You should be able to match the exact view you have in SketchUp in Rayscaper:
                                • ntxdaveN
                                  @pixelcruncher said in Rayscaper Learning-Practice:
                                  Maybe I have not done a good comparison of the two systems. I do find the UI in Twilight Render somewhat easier to comprehend and use. I will try to do some more detailed analysis and give you some more specific feedback about the features that I have found a little more complicated to use.
                                  I have tried this option but had some problems when dropping the HDRI background and matching it to my model. Again, I will do some more experimenting and try to be more specific.
                                  • ntxdaveN
                                    ntxdave @ntxdave
                                    Here is what I see:
                                    While I like the result, to me the image in Rayscaper does not match what I see in SketchUp. Maybe me expectations are a little off. I just need to be able to understand what to expect. I had to go back into SketchUp and adjust the view in order to get something I was satisfied with in Rayscaper. I was not able to get something where I could see the entire building in Rayscaper. ๐Ÿ˜€
                                    • pixelcruncherP
                                      You are right, that doesn't match at all! That's a bug. I will have a look at it.
                                      To work around this, you can manually increase the horizontal field-of-view (FOV) of your camera:
                                      • Navigate to the camera tab.
                                      • Tick the "Override FOV" button.
                                      • Increase the FOV slider to make the view wider.
                                      • ntxdaveN
                                        ntxdave
                                        OK, that works and I will do some more "playing around". ๐Ÿ‘ ๐Ÿ‘
                                        • ntxdaveN
                                          ntxdave
                                          Just rendered another of my models with Rayscaper. I think this one will need a little more practice but thought I would share anyway.
                                          • pixelcruncherP
                                            @ntxdave Good progress.
                                            The background HDRI looks a bit pixelated with the resolution you are using. I recommend using a high-resolution image. If this is a PolyHaven HDRI shipped with Rayscaper, you can configure Rayscaper to use higher resolution HDRIs:
                                            • Open the Rayscaper settings via the menu File > Settings....
                                            • Configure the PolyHaven HDRI size in the settings dialog.
                                            • Save the settings.
                                            • Restart SketchUp (I will remove the required restart in future versions).
                                            Happy Rendering!
                                            Cheers,
                                            Thomas
                                            • 1 / 3
