    Rayscaper Learning-Practice
    53 Posts 4 Posters 6.8k Views 4 Watching
      Rich O Brien Moderator @ntxdave
      @ntxdave said in Rayscaper Learning-Practice:
      Are things like this included anywhere in the documentation?
      I don't know I have yet to look at docs.
      • ntxdaveN
        ntxdave @ntxdave
        @Rich-O-Brien Thanks Rick, I appreciate this. Are things like this included anywhere in the documentation?
        Sorry about the typo Rich. I tried to edit it but could not do that after I had submitted it. I thought there was a way to do that.
        Press F1...thank me later
          I don't know I've not yet looked at the docs. There's plenty of reading material online surrounding the topic though.
          https://creativecloud.adobe.com/learn/substance-3d-designer/web/the-pbr-guide-part-1
          That's a good introduction to PBR
          • pixelcruncherP
            pixelcruncher Extension Creator @Rich O Brien
            @ntxdave
            There's documentation here: https://rayscaper.com/manual/materials/#metal-material - Let me know if you have any feedback.
            You can access the documentation via the Help menu:
            The most feature-rich material in Rayscaper is the Disney material: https://rayscaper.com/manual/materials/#disney-material-pbr-material. This is a real PBR (physically based rendering) material.
            Cheers,
            Thomas
            • ntxdaveN
              ntxdave
              Is there any chance that Rayscaper is going to work with Lindale so that it is one of the render applications available in the Skatter plugin?
              • ntxdaveN
                ntxdave
                Does anyone have any examples of exterior renders they have done with Rayscaper?
                • pixelcruncherP
                  pixelcruncher Extension Creator @ntxdave
                  @ntxdave I’m not familiar with the Skatter plugin from Lindale, but does it not work with Rayscaper?
                  I assume it would just create component instances and then spread them around according to some brushes. Correct me if I’m wrong.
                  • pixelcruncherP
                    @ntxdave I don’t have any outdoor renders, so if you do please share 😁 most renders were done by @Rich-O-Brien and @majid and they were focusing on interiors.
                    ntxdaveN 1 Reply Last reply
                    • ntxdaveN
                      ntxdave @pixelcruncher
                      @pixelcruncher OK, was just curious if anyone had any to share. I have not tried any yet.
                      I have the Skatter plugin where you can add bushes and etc to models and it does not support Rayscaper.
                      Would like to see some though if anyone has any.
                      majidM 1 Reply Last reply
                      • majidM
                        majid @ntxdave
                        @ntxdave
                        Maybe an alternate solution works.
                        Make a component composed of two components, one very simple as a line (this would be our place holder), and the object you want to scatter. Separate their tag (layer) and hide the "complicated object's" layer (tag).
                        Now it is time to scatter the simple (placeholder) one.
                        It could be done using "component spray" plugin, I think.
                        It must render fine in RS, I guess.
                        • ntxdaveN
                          ntxdave
                          Well, here is my first attempt at an external render. Many things to work on but I have to admit I am a little surprised at how this went on my first try.
                          • pixelcruncherP
                            @ntxdave that’s a great first attempt! The windows could use some glass.
                            • ntxdaveN
                              @pixelcruncher Yes, I totally agree about the windows. I did try the glass on the roof. but I did a bad job. I might find another simpler model to try to adjust the glass and then come back to this one.
                              Rayscaper has a ton of options which makes the learning process kind of hard at times. From that point of view, while Twilight Render may not have had as many options, the user interface, at least is some aspects was a little simpler and easier to learn. Hope you do not take this as negative comments. I do not mean it that way.
                              The other issue I have is that there is no way to use Rayscaper with animations. I think this is becoming very popular these days and I hope it is something you plan for the future.
                              Again, I really appreciate your feedback/comments. πŸ‘
                              • ntxdaveN
                                ntxdave @ntxdave
                                • ntxdaveN
                                  ntxdave
                                  Some more learning 😁
                                  Here is my latest render. Some progress I think but one thing I am still struggling a little with is setting the scene in SketchUp so that it will produce the view I want in the render.
                                  Reply Quote 2
                                  • pixelcruncherP
                                    It was not taken as negative! It's all good feedback. I understand it's not easy to use, it's something we should work on by improving the UI. But when I remember Twilight Render, it has a ton more options and features than Rayscaper. Is that not the case?
                                    @ntxdave Can you clarify so I understand better and see how we can improve this?
                                    You should be able to match the exact view you have in SketchUp in Rayscaper:
                                    • ntxdaveN
                                      @pixelcruncher said in Rayscaper Learning-Practice:
                                      Maybe I have not done a good comparison of the two systems. I do find the UI in Twilight Render somewhat easier to comprehend and use. I will try to do some more detailed analysis and give you some more specific feedback about the features that I have found a little more complicated to use.
                                      I have tried this option but had some problems when dropping the HDRI background and matching it to my model. Again, I will do some more experimenting and try to be more specific.
                                      • ntxdaveN
                                        ntxdave @ntxdave
                                        Here is what I see:
                                        While I like the result, to me the image in Rayscaper does not match what I see in SketchUp. Maybe me expectations are a little off. I just need to be able to understand what to expect. I had to go back into SketchUp and adjust the view in order to get something I was satisfied with in Rayscaper. I was not able to get something where I could see the entire building in Rayscaper. πŸ˜€
                                        • pixelcruncherP
                                          You are right, that doesn't match at all! That's a bug. I will have a look at it.
                                          To work around this, you can manually increase the horizontal field-of-view (FOV) of your camera:
                                          • Navigate to the camera tab.
                                          • Tick the "Override FOV" button.
                                          • Increase the FOV slider to make the view wider.
                                          • ntxdaveN
                                            ntxdave
                                            OK, that works and I will do some more "playing around". πŸ‘ πŸ‘
                                            • 1 / 3
