    Fredo6 Toposhaper Error
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    15 Posts 5 Posters 451 Views 5 Watching
      Chip_Cookie
      Dear All, and @fredo6
      I am getting an error when invoking TopoShaper.
      My setup: Macbook pro M2, Sonoma 14.5, Sketchup pro 2024 v0.554, latest versions of Fredo6 library and TopoShaper.
      The error file is reads:
      Date: 04-Jul-24 08:16:04 - SU2024.0
      An error occurred in CLEANSING
      The operation is fully aborted
      cannot hide layer that is a part of the active path
      body_lib6tool.rbe:: 2566 -- visible=
      body_lib6tool.rbe:: 2566 -- block in switch_to_temp_layer
      body_lib6tool.rbe:: 2565 -- each
      body_lib6tool.rbe:: 2565 -- switch_to_temp_layer
      toposhapertool.rbe:: 1393 -- change_view
      toposhapertool.rbe:: 1360 -- set_preview_working
      toposhapertool.rbe:: 546 -- cleansing_processing
      toposhapertool.rbe:: 525 -- after_selection
      toposhapertool.rbe:: 495 -- notify_edge_picked
      body_lib6edgepicker.rbe:: 541 -- call
      body_lib6edgepicker.rbe:: 541 -- notify_action
      body_lib6edgepicker.rbe:: 584 -- terminate_current_selection
      toposhapertool.rbe:: 660 -- execute_validate
      toposhapertool.rbe:: 389 -- handle_initial_selection
      toposhapertool.rbe:: 321 -- activate
      toposhapertool.rbe:: 133 -- select_tool
      toposhapertool.rbe:: 133 -- action__mapping
      data6.rb:: 65 -- call
      data6.rb:: 65 -- launch_action
      lib6plugin.rbe:: 244 -- launch_action
      bootstrap_toposhaper.rbe:: 83 -- launch_action
      bootstrap_toposhaper.rbe:: 149 -- block in startup
      lib6plugin.rbe:: 1463 -- command_invoke
      lib6plugin.rbe:: 1443 -- block (2 levels) in build_config_commands
      lib6traductor.rbe:: 1468 -- block in add_command
      The topo lines were imported into Sketchup from a dwg file. I would attach the files, but I can't see to do that.
      Anyone have any ideas? If not, how do I send Fredo6 the error report?
      Thanks,
      Tom
      Rich O BrienR Dave RD 2 Replies Last reply Reply Quote 0
      • fredo6F Offline
        fredo6 @Chip_Cookie
        @Chip_Cookie
        Use Toposhaper from outside the group not inside.
        C 1 Reply Last reply Reply Quote 2
          Rich O Brien Moderator @Chip_Cookie
          @Chip_Cookie If you @fredo6 he'll see it. If you want to share a file you could try a cloud hosting
          C 1 Reply Last reply Reply Quote 0
            Dave R @Chip_Cookie
            @Chip_Cookie one thing you could try while waiting for Fredo is to remove the tags from the geometry in the import .dwg. Make sure all of the edges areuntagged.
              Chip_Cookie @Dave R
              @Dave-R
              Unfortunately, I still get the error:
              I will do the @tag thing.
                Chip_Cookie @Rich O Brien
                @Rich-O-Brien said in Fredo6 Toposhaper Error:
                Maybe this works:
                Dropbox
                (www.dropbox.com)
                Dave RD fredo6F 2 Replies Last reply Reply Quote 0
                  Dave R @Chip_Cookie
                  @Chip_Cookie I ran TopoShaper on your contours and got this.
                  It's in SU2024. What steps did you take when you ran it?
                  149 Big Hill from DWG Contours Scaled topo.skp
                    Chip_Cookie
                    One more thing, the native Sandbox tool 'from contours' works fine.
                    • fredo6F Offline
                      fredo6 @Chip_Cookie
                      @Chip_Cookie
                        Chip_Cookie @fredo6
                        @fredo6 @Dave-R ,
                        My mistake was not having the contour group as the outermost container. I had two groups, Contours group and Plat group, inside another group I called Survey. If I select (but don't enter) the Contour group within Survey and try to apply TopoShaper it fails. If I explode Survey, then select Contour, it works great.
                        Thank you both for your help.
                        • Rich O BrienR Rich O Brien marked this topic as a question on
                        • F Offline
                          frankpondesign
                          Dear Fredo, I have been trying for 2 days now to get Toposhaper to work in Sketchup and keep getting the the same error messsage "cannot hide layer that is a part of the active path". You have said a few times in various forums that you have to use Toposhaper from outside the group not inside, but I do not understand what you exactly mean with this.
                          I import contour lines from autocad cilvil 3d to sketchup as a dwg file. (these contour work fine in Sandbox). I then put the contours in a seperate group. Then I select the contours in that group and start Toposhaper, it then works for a while and then I get the mentioned error message.
                          Toposhaper has worked on 2-3 occissions, but it never was clear to me why it worked in tose cases. I could never replicate it afterwards.
                          fredo6F 1 Reply Last reply Reply Quote 1
                          • fredo6F Offline
                            fredo6 @frankpondesign
                            @frankpondesign
                            You might be inside the group.
                            Go outside, select the group and call TopoShaper. This should work.
                            • F Offline
                              frankpondesign
                              Sorry for being ignorant but I do not understand what you mean by being in the group?
                              I have created a group with only the contour lines in it. How do I selct that group without being in it?
                              • F Offline
                                frankpondesign
                                Dropbox
                                (www.dropbox.com)
                                This is a videao of what I am doing, maybe that helps....
                                • fredo6F Offline
                                  Just click on the group. Toposhaper will pick what is inside.
                                  • F Offline
                                    frankpondesign
                                    It does, but then I get the error message, see the video......
