    Fredo6 Toposhaper Error
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    15 Posts 5 Posters 1.2k Views 5 Watching
    • C
      Chip_Cookie @Rich O Brien
      @Rich-O-Brien said in Fredo6 Toposhaper Error:
      If you want to share a file you could try a cloud hosting
      Maybe this works:
      Dropbox - 400
      (www.dropbox.com)
      Dave RD fredo6F 2 Replies Last reply
        Dave R @Chip_Cookie
        @Chip_Cookie I ran TopoShaper on your contours and got this.
        It's in SU2024. What steps did you take when you ran it?
        149 Big Hill from DWG Contours Scaled topo.skp
        • C
          Chip_Cookie
          One more thing, the native Sandbox tool 'from contours' works fine.
          • fredo6F
            fredo6 @Chip_Cookie
            @Chip_Cookie
            Use Toposhaper from outside the group not inside.
            C 1 Reply Last reply
            Reply Quote 2
            • C
              Chip_Cookie @fredo6
              @fredo6 @Dave-R ,
              My mistake was not having the contour group as the outermost container. I had two groups, Contours group and Plat group, inside another group I called Survey. If I select (but don't enter) the Contour group within Survey and try to apply TopoShaper it fails. If I explode Survey, then select Contour, it works great.
              Thank you both for your help.
              • Rich O BrienR Rich O Brien marked this topic as a question on
              • F
                frankpondesign
                Dear Fredo, I have been trying for 2 days now to get Toposhaper to work in Sketchup and keep getting the the same error messsage "cannot hide layer that is a part of the active path". You have said a few times in various forums that you have to use Toposhaper from outside the group not inside, but I do not understand what you exactly mean with this.
                I import contour lines from autocad cilvil 3d to sketchup as a dwg file. (these contour work fine in Sandbox). I then put the contours in a seperate group. Then I select the contours in that group and start Toposhaper, it then works for a while and then I get the mentioned error message.
                Toposhaper has worked on 2-3 occissions, but it never was clear to me why it worked in tose cases. I could never replicate it afterwards.
                fredo6F 1 Reply Last reply
                • fredo6F
                  fredo6 @frankpondesign
                  @frankpondesign
                  You might be inside the group.
                  Go outside, select the group and call TopoShaper. This should work.
                  • F
                    frankpondesign
                    Sorry for being ignorant but I do not understand what you mean by being in the group?
                    I have created a group with only the contour lines in it. How do I selct that group without being in it?
                    • F
                      frankpondesign
                      Dropbox - 400
                      (www.dropbox.com)
                      This is a videao of what I am doing, maybe that helps....
                      • fredo6F
                        Just click on the group. Toposhaper will pick what is inside.
                        • F
                          frankpondesign
                          It does, but then I get the error message, see the video......
