    2.1k Posts 465 Posters 654.9k Views 470 Watching
      Dave R @rendyinterior
      @rendyinterior said in SCFLicense: Extension Licensing on Sketchucation:
      I'm installing my sketchup 2022 in drive D:. can that cause the error?
      That could cause other errors with running SketchUp.
        rendyinterior Newcomers @Rich O Brien
        @Rich-O-Brien
        I browse through the shop. the duration show unlimited is it means the licenses don't expire? if I get bundle of 8, I will be receiving 8 licenses and can use it on 3 devices?
          Rich O Brien Moderator @rendyinterior
          @rendyinterior
          Yes
          Yes
            LukasP
            Hello, I would like to ask for advice on how to activate the license for the purchased RoundCorner Perpetual License plugin. Unfortunately, I had to reinstall Windows, and when I tried to activate the purchased plugin again, I received the following error message (see screenshot).
            Thank you very much for your help.
              LukasP
                Does your device name use non-alphanumeric characters like é áó ú ?
                If so rename your device using only alphanumeric characters.
                Go to C:\Users\SomeName\AppData\Local\SCF Licenses and delete the signature file
                Open SketchUp and activate license.
                  LukasP @Rich O Brien
                  @Rich-O-Brien
                  Thank you very much for your quick reply. The advice was helpful. Thank you very much and have a nice day
                    jameskorten @fredo6
                    @fredo6 I have a license for the following Lib Fredo plug-ins: RoundCorner, JointPushPull, Curviloft, FredoScale, TopoShaper, Curvizard, VisuHole & ToolsOnSurface, however having recently got a new machine, it won't allow me to validate RoundCorner in SketchUp 2025 on my new machine. I get a message saying Error in the License Validation Response from SketchUcation: License seats exceeded. I have deactivated the plug-ins on my old machine and deleted some of the older versions of SketchUp on my home machine yet I still get the same message. I have re-started bot machines but still no luck. How do I sort this issue so I can use the plug-ins on my new machine please?
                      You can release seats at https://sketchucation.com/webshop/my-licences.php if your old device was using updated extensions.
                      For more info: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                        MARTIN Michel
                        Bonjour,
                        comment faire pour télécharger la dernière version de Extension de la boutique Sketchucation , v4.3.0 ou ultérieure. ?
                          Here: https://sketchucation.com/plugin/696-sketchucationtools
                          • N Offline
                            Noddi17
                            Hello,
                            I'm experiencing an issue when trying to validate the license for the RoundCorner plugin in SketchUp.
                            Each time I try to activate the license, I receive the following error:
                            "Error in the License Validation
                            Request to Sketchucation: ERROR_A04
                            Wrong Signature File - You may have changed the computer name
                            It is advised to erase the Signature file and revalidate"
                            To resolve this, I have already tried the following:
                            • Deleted the signature file from the SCFlicensing folder
                            • Changed my computer name to English and restarted
                            • Reinstalled SketchUp
                            • Made sure my internet connection is stable
                            Despite all these attempts, I still receive the same error, and the plugin does not activate.
                            Could you please help me fix this issue?
                            Thank you in advance for your support.
                            TIGT 1 Reply Last reply Reply Quote 1
                              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                TIG Moderator @Noddi17
                                Please note that Fredo's 'RoundCorner' is a different extension to 'FredoCorner'.
                                They have their own licenses.
                                You cannot license one of them with a license file that is for the other one...
                                • 102
                                • 103
                                • 104
                                • 105
                                • 106
                                • 106 / 106
