    2.3k Posts 515 Posters 2.2m Views 520 Watching
      LukasP
      Hello, I would like to ask for advice on how to activate the license for the purchased RoundCorner Perpetual License plugin. Unfortunately, I had to reinstall Windows, and when I tried to activate the purchased plugin again, I received the following error message (see screenshot).
      Thank you very much for your help.
        LukasP
          Does your device name use non-alphanumeric characters like é áó ú ?
          If so rename your device using only alphanumeric characters.
          Go to C:\Users\SomeName\AppData\Local\SCF Licenses and delete the signature file
          Open SketchUp and activate license.
            LukasP @Rich O Brien
            @Rich-O-Brien
            Thank you very much for your quick reply. The advice was helpful. Thank you very much and have a nice day
              jameskorten @fredo6
              @fredo6 I have a license for the following Lib Fredo plug-ins: RoundCorner, JointPushPull, Curviloft, FredoScale, TopoShaper, Curvizard, VisuHole & ToolsOnSurface, however having recently got a new machine, it won't allow me to validate RoundCorner in SketchUp 2025 on my new machine. I get a message saying Error in the License Validation Response from SketchUcation: License seats exceeded. I have deactivated the plug-ins on my old machine and deleted some of the older versions of SketchUp on my home machine yet I still get the same message. I have re-started bot machines but still no luck. How do I sort this issue so I can use the plug-ins on my new machine please?
                You can release seats at https://sketchucation.com/webshop/my-licences.php if your old device was using updated extensions.
                For more info: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                  MARTIN Michel
                  Bonjour,
                  comment faire pour télécharger la dernière version de Extension de la boutique Sketchucation , v4.3.0 ou ultérieure. ?
                    Here: https://sketchucation.com/plugin/696-sketchucationtools
                    • N Offline
                      Noddi17
                      Hello,
                      I'm experiencing an issue when trying to validate the license for the RoundCorner plugin in SketchUp.
                      Each time I try to activate the license, I receive the following error:
                      "Error in the License Validation
                      Request to Sketchucation: ERROR_A04
                      Wrong Signature File - You may have changed the computer name
                      It is advised to erase the Signature file and revalidate"
                      To resolve this, I have already tried the following:
                      • Deleted the signature file from the SCFlicensing folder
                      • Changed my computer name to English and restarted
                      • Reinstalled SketchUp
                      • Made sure my internet connection is stable
                      Despite all these attempts, I still receive the same error, and the plugin does not activate.
                      Could you please help me fix this issue?
                      Thank you in advance for your support.
                      TIGT 1 Reply Last reply Reply Quote 1
                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                          TIG Moderator @Noddi17
                          Please note that Fredo's 'RoundCorner' is a different extension to 'FredoCorner'.
                          They have their own licenses.
                          You cannot license one of them with a license file that is for the other one...
                            Arq Lindoro @unterluggauer
                            @unterluggauer said in SCFLicense: Extension Licensing on Sketchucation:
                            Hi Fredo, I upgrade to 4.0.0. The aktiveprocedure was a little different. OK, over again, I bought a full License. I got a new scflicense. But it doesn´t work again. My computer was always connencted to internet and I´m a skechtuo pro.
                            I pay yesterday 8,61 EUR and today 16,24 EUR without succses. Im a little bit frustrated. Usually i love your extensions 😕
                              @fredo6 might be able to comment more helpfully on that error code, but one thing springs to mind - to communicate with SketchUcation.com your firewall settings should 'whitelist' the site - otherwise the licensing falls at the first hurdle...
                                Gábor
                                @unterluggauer Have you recently changed your computer name? If yes, there are 2 possible solutions:
                                1. Change it back to the previous one or
                                2. Erase your signature file at C:\Users\username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
                                  Mesak4719
                                  It appears error_a04
                                    Gábor
                                    @Mesak4719 Have you recently changed your computer name? If yes, there are 2 possible solutions:
                                      And if you erase that file you will need to re-validate the licenses...
                                        jeromec
                                        Ok, things changed, do we get to be refund the paypal donation made, or deducted from the licence buying then ?
                                        1 Reply Last reply Reply Quote -1
                                          Donations are direct to developers PayPal. You’d need to ask whoever it is you sent a donation to.
                                            sd091688 Newcomers
                                            I recently installed round corner but when I use it it appears as per photo attached mentioned trial period expired. Asking to get license.
                                            Hope anyone can help to make it work cause I need it urgently.
                                            TYIA
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 115
                                            • 116
                                            • 106 / 116
