    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      @seb1986 said:
      I am trying to drag a cabinet from 900mm wide to 955mm the ideal way to do this I would just type in 55mm and it would move it the extra 55mm but this is in pixels and isn't as easy.
      Show us a screenshot of what you are seeing. Sizing any geometry in pixels doesn't make any sense in SketchUp. Which tool are you using to change the dimensions of the cabinet? When I use Box Scaling I can just enter the desired final dimension.
      Share the .skp file so we can see what you are working with.
      Which version of SketchUp Pro are you using?
        kostiaarh
        Hello dear Fredo. Can I ask you to make a small edit to your plugin? Could we have more than 2 (3,4,5...N) scale planes in the plugin?
          antonblam
          Hello Fredo.
          I don't know if it happens to anyone else.
          I have an issue with the box scaling. I scale some geometry by a factor of 0 to make it flat - although it does the job of flattening, suddenly I can't select my geometry by cursor anymore, just by ctrl+A. I see the geometry where it should be, but for some reason I can't select it.
          Is this a known problem? Is there a fix for that? I checked the version and I have the latest one (3.5a).
          Thanks a lot in advance.
          • fredo6F Offline
            This is not really supported. By the way, you may get the issue with the native scaling.
            • fredo6F Offline
              NEW RELEASE: FredoScale v3.6a - 01 Apr 24
              Requirements:
              • LibFredo6 v14.3b.
              • Sketchucation PluginStore v4.4.0.
              FredoScale 3.5a includes changes for:
              • Future compatibility
              Home Page of FredoScale for information and Download.
              Main post of this FredoScale thread.
              S 1 Reply Last reply Reply Quote 0
                seryaul @fredo6
                @fredo6
                Boa tarde, fiz a doação de $12, ainda não recebi o e-mail com a ativação do plugin.
                Aguardo resposta.
                  rutpin
                  Hello, I installed the latest plugin but it does not appear in the menu list
                  TIGT R 2 Replies Last reply Reply Quote 0
                    TIG Moderator @rutpin
                    @rutpin
                    After you downloaded the RBZ did you install it from the Extension Manager dialog ?
                    Or are you using the SketchUcation Tools' ExtensionStore³ to auto-install it without an RBZ ?
                    Do you have the latest LibFredo6 installed as well ?
                    Do you also have the SketchUcation Tools installed [needed for any licensing] ?
                    Have you restarted SketchUp after the installations to sync everything ??
                      rutpin @rutpin
                      TIG Yes
                        Rich O Brien Moderator @rutpin
                        @rutpin
                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                          DomV12
                          Hello, all the Fredo extensions work correctly for me but when I want to use FredoScale it tells me that the license has expired. Can someone give me a hand with this?
                            Rich O Brien Moderator @DomV12
                            @DomV12 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                            D 1 Reply Last reply Reply Quote 0
                              DomV12 @Rich O Brien
                              @Rich-O-Brien You mean this? :
                              Fredo6 Plugins Information on 2024-07-16 09:33:05 -0400
                              • Sketchup: 24.0.484
                              • LibFredo6: v14.5c
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 4.4.1
                              • SCFLicense: v6.4a - 74
                              • Fredo6 Plugins
                                Curviloft v2.0a
                                FredoScale v3.6a
                                FredoTools v4.5c
                                Signature File: 2024-07-15 11:59:27 -0400
                                @DomV12 Please retrieve your license files from https://sketchucation.com/webshop/my-licences.php
                                Follow the guide on how to activate: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                Report back with error messages.
                                If you are unable to license it may be your SketchUp install does not have full permissions to read/write folders. Please repair your SketchUp install and then re-try steps above.
                                  ratthakorn33
                                  Hi! Fredo.
                                  I have a purchase license bundle of fredo2022 but i can't use plugin please help
                                    Rich O Brien Moderator @ratthakorn33
                                    @ratthakorn33 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                    Hi! Fredo.
                                    Close SketchUp
                                    Perform the steps in the dialog and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt at C:\Users\SomeName\AppData\Local\SCF Licenses
                                    Start SketchUp and activate license
                                    R 1 Reply Last reply Reply Quote 0
                                      ratthakorn33 @Rich O Brien
                                      @Rich-O-Brien It actually works. Thankyou
                                        RUBIYA KHAN Newcomers @Teezer
                                        @Teezer hi i cannot use it after downloading
                                        please help me
                                          Rich O Brien Moderator @RUBIYA KHAN
                                          @RUBIYA-KHAN Can you share more info?
                                            Mike Backman
                                            Hello, I have no Idea how to direct message Fredo.
                                            1st Question: How do I DM Fredo for Help?
                                            2nd Question: is the new lord of the tool bars update deal with the the fact that I need to set my external monitor as my "main screen" in order to work on in my large SU monitor. this is fine but when I go back to use my laptop on it on it own my desktop icons are a mess.
                                            3rd Question : thrupaint and LOTT is not showing up on my Sketchucation my licence page.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 56
                                            • 57
                                            • 31 / 57
