    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.8m Views 343 Watching
    • fredo6F Offline
      @dgannonennis said:
      When box stretching is it possible to input a measurement if you know the value rather than trying to stretch to the exact value?
      You can show the dimension dialog by pressing TAB.
        betofg90
        I want to pay fredo pluggins bundle but im using a cracked sketchup, there's gonna be any problem or not?
          Seb1986
          Hi guys and girls is it possible to change the dimensions from Pixels to mm in the Fredoscale extensions??
          I am trying to drag a cabinet from 900mm wide to 955mm the ideal way to do this I would just type in 55mm and it would move it the extra 55mm but this is in pixels and isn't as easy.
            Show us a screenshot of what you are seeing. Sizing any geometry in pixels doesn't make any sense in SketchUp. Which tool are you using to change the dimensions of the cabinet? When I use Box Scaling I can just enter the desired final dimension.
            Share the .skp file so we can see what you are working with.
            Which version of SketchUp Pro are you using?
              kostiaarh
              Hello dear Fredo. Can I ask you to make a small edit to your plugin? Could we have more than 2 (3,4,5...N) scale planes in the plugin?
                antonblam
                Hello Fredo.
                I don't know if it happens to anyone else.
                I have an issue with the box scaling. I scale some geometry by a factor of 0 to make it flat - although it does the job of flattening, suddenly I can't select my geometry by cursor anymore, just by ctrl+A. I see the geometry where it should be, but for some reason I can't select it.
                Is this a known problem? Is there a fix for that? I checked the version and I have the latest one (3.5a).
                Thanks a lot in advance.
                • fredo6F Offline
                  This is not really supported. By the way, you may get the issue with the native scaling.
                  • fredo6F Offline
                    NEW RELEASE: FredoScale v3.6a - 01 Apr 24
                    Requirements:
                    • LibFredo6 v14.3b.
                    • Sketchucation PluginStore v4.4.0.
                    FredoScale 3.5a includes changes for:
                    • Future compatibility
                    Home Page of FredoScale for information and Download.
                    Main post of this FredoScale thread.
                    S 1 Reply Last reply Reply Quote 0
                      seryaul @fredo6
                      @fredo6
                      Boa tarde, fiz a doação de $12, ainda não recebi o e-mail com a ativação do plugin.
                      Aguardo resposta.
                        rutpin
                        Hello, I installed the latest plugin but it does not appear in the menu list
                        TIGT R 2 Replies Last reply Reply Quote 0
                          TIG Moderator @rutpin
                          @rutpin
                          After you downloaded the RBZ did you install it from the Extension Manager dialog ?
                          Or are you using the SketchUcation Tools' ExtensionStore³ to auto-install it without an RBZ ?
                          Do you have the latest LibFredo6 installed as well ?
                          Do you also have the SketchUcation Tools installed [needed for any licensing] ?
                          Have you restarted SketchUp after the installations to sync everything ??
                            rutpin @rutpin
                            TIG Yes
                              Rich O Brien Moderator @rutpin
                              @rutpin
                              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                DomV12
                                Hello, all the Fredo extensions work correctly for me but when I want to use FredoScale it tells me that the license has expired. Can someone give me a hand with this?
                                  Rich O Brien Moderator @DomV12
                                  @DomV12 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                  D 1 Reply Last reply Reply Quote 0
                                    DomV12 @Rich O Brien
                                    @Rich-O-Brien You mean this? :
                                    Fredo6 Plugins Information on 2024-07-16 09:33:05 -0400
                                    • Sketchup: 24.0.484
                                    • LibFredo6: v14.5c
                                    • LibFredo6 Binary loaded
                                    • Sketchucation ExtensionStore: 4.4.1
                                    • SCFLicense: v6.4a - 74
                                    • Fredo6 Plugins
                                      Curviloft v2.0a
                                      FredoScale v3.6a
                                      FredoTools v4.5c
                                      Signature File: 2024-07-15 11:59:27 -0400
                                      @DomV12 Please retrieve your license files from https://sketchucation.com/webshop/my-licences.php
                                      Follow the guide on how to activate: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                      Report back with error messages.
                                      If you are unable to license it may be your SketchUp install does not have full permissions to read/write folders. Please repair your SketchUp install and then re-try steps above.
                                        ratthakorn33
                                        Hi! Fredo.
                                        I have a purchase license bundle of fredo2022 but i can't use plugin please help
                                          Rich O Brien Moderator @ratthakorn33
                                          @ratthakorn33 said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
                                          Hi! Fredo.
                                          Close SketchUp
                                          Perform the steps in the dialog and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt at C:\Users\SomeName\AppData\Local\SCF Licenses
                                          Start SketchUp and activate license
                                          R 1 Reply Last reply Reply Quote 0
                                            ratthakorn33 @Rich O Brien
                                            @Rich-O-Brien It actually works. Thankyou
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 55 / 58
