    [Plugin Library] LibFredo6 - v15.8c - 28 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      fredo6 @TIG
      @santiagoyagogil
      it might also be a problem of Sketchup installation.
      Did you install with 'Run as Administrator'?
      S 1 Reply Last reply Reply Quote 1
        santiagoyagogil @fredo6
        Gracias . Solucionado.
        Era un tema de permisos. al final al poner todas las entradas de permisos en "on" de la carperta Temp se ha solucionado el problema.
        Saludos
        [Thank you . Solved.
        It was a permissions issue. In the end, setting all the permissions entries to "on" in the Temp folder solved the problem.]
        • N Offline
          nekobus76
          Hi. I'm having a similar problem and getting this message:
          Also, all of the Fredo6 plugin icons have disappeared!
          Thanks for your help!
          • fredo6F Offline
            Did you install LibFredo6 (latest version)?
            N 1 Reply Last reply Reply Quote 0
            • N Offline
              nekobus76 @fredo6
              @fredo6 I believe so, I installed v14.3d
              • N Offline
                nekobus76 @nekobus76
                UPDATE: I have no idea why but when I checked the settings in Sketchucation it was set to not load LibFredo and a couple of other plugins that I've been having issues with as well... It's strange because this is a recently installed Sketchup 2024 and I haven't touched those settings. Oh well, now I can use your plugins again!
                @fredo6 Thanks for making my life easier for the many years I've been using Sketchup!
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v14.4a - 10 May 24
                  LibFredo6 14.4a includes changes related to:
                  • Bug fixing for Curviloft Along Path (see this post)
                  • New extension Fredo Layport
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v14.4c - 18 May 24
                    LibFredo6 14.4c includes changes related to:
                    • Bug fixing for FredoCorner (see this post)
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v14.4d - 20 May 24
                      LibFredo6 14.4d includes changes related to:
                      • Bug fixing for a side-effect introduced in v14.c which impacts JointPushPull. See this post.
                      I 1 Reply Last reply Reply Quote 0
                      • I Offline
                        igortrem Newcomers @fredo6
                        @fredo6 said in [Plugin Library] LibFredo6 - v14.4d - 20 May 24:
                        Hi there,
                        Just purchased license for Fredo6 round corner for my Sketchup 2024, and it's asking to install Extension Store. Cas somebody can guide me? Can't find it.
                        TIGT 1 Reply Last reply Reply Quote 0
                          TIG Moderator @igortrem
                          @igortrem
                          For Fredo's extensions you need to install the latest version, and those for LibFredo6, and the SketchUcation Tools, which includes our ExtensionStore which handles the licensing...
                          Restart after installing to sync everything.
                          There are links in the extension's page about licensing procedures...
                          These are extensions all available from the PluginStore
                          [link to it via the 'ruby' icon in the top-bar of this page]...
                          https://sketchucation.com/pluginstore
                          https://sketchucation.com/pluginstore?pln=RoundCorner
                          https://sketchucation.com/pluginstore?pln=LibFredo6
                          https://sketchucation.com/pluginstore?pln=SketchUcationTools
                          If you have the ExtensionStore loaded you can find and install any of the plugins/extensions available in our PluginStore, but more conveniently it will AutoInstall them, without the need to download any RBZ files and manually install them, and later on it will remind you of available updates etc...
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v14.5a - 23 May 24
                            LibFredo6 14.5a includes changes related to:
                            • For Fredo Layport v1.1
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v14.5b - 24 May 24
                              LibFredo6 14.5b includes changes related to:
                              • small technical adjustment
                                JuanDAniel12343211232 Newcomers @fredo6
                                @fredo6 said in [Plugin Library] LibFredo6 - v14.5b - 24 May 24:
                                etchup version: SU2017 and above (for Mac M1, SU2021 and above)
                                Platform: Windows and Mac OSX
                                Usage: Free
                                M 1 Reply Last reply Reply Quote 0
                                  massrequiem @JuanDAniel12343211232
                                  @fredo6: I ran into this while in the process of updating the extensions for 2024.
                                  • Y Offline
                                    youppi
                                    Hello,
                                    I have a problem with icons that no longer appear in the configuration menus (see screenshot) in Fredo6 extensions such as FredoTools, JointPushPull, LordOfTheToolbars...
                                    I use SketchUp v2020 and LibFredo6 v14.5b.
                                    Any idea where this might be coming from?
                                    fredo6F 1 Reply Last reply Reply Quote 0
                                    • fredo6F Offline
                                      fredo6 @youppi
                                      @youppi
                                      Did you do anything special before it happens?
                                      Could you invoke the menu Window > LibFredo6 Settings.... > Fredo6 Plugins Information for Sketchucation support, to see what is the status of your plugins.
                                      Y 1 Reply Last reply Reply Quote 0
                                      • Y Offline
                                        youppi @fredo6
                                        @fredo6
                                        This is what is written in the Console Ruby :
                                        Fredo6 Plugins Information on 2024-06-08 23:47:38 +0200
                                        • Platform: x64-mingw32 - Ruby: 2.5.5
                                        • Sketchup: 20.2.172
                                        • LibFredo6: v14.5b
                                        • LibFredo6 Binary loaded
                                        • Sketchucation ExtensionStore: 4.4.1
                                        • SCFLicense: v6.4a - 74
                                        • Fredo6 Plugins
                                          JointPushPull v4.8a - licensed FULL
                                          Signature File: 2020-12-11 09:04:28 +0100
                                          ClothWorks: 2022-11-30 12:22:30 +0100
                                          Curviloft: 2022-11-30 13:03:02 +0100
                                          Curvizard: 2022-11-30 13:03:16 +0100
                                          FredoScale: 2022-11-30 13:03:37 +0100
                                          JointPushPull: 2022-11-30 12:36:32 +0100
                                          RoundCorner: 2022-11-30 13:03:59 +0100
                                          ToolsOnSurface: 2022-11-30 13:04:40 +0100
                                          TopoShaper: 2022-11-30 13:04:53 +0100
                                          VisuHole: 2022-11-30 13:05:04 +0100
                                          "Add help menu!"
                                          "create new"
                                          "created"
                                          #Sketchup::Menu:0x00000110fbc93670
                                        • fredo6F Offline
                                          fredo6 @youppi
                                          @youppi
                                          Thanks.
                                          Did it happen suddenly? or after you did an installation?
                                          Before calling the Quick Launcher of Joint PushPull, can you leave the Ruby open to see if there are errors.
                                            adams_1127
                                            This does not work on 2024 sketchup. It does not load properly. Is there a catch?
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 108
                                            • 109
                                            • 27 / 109
