    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • fredo6F
      Did you install LibFredo6 (latest version)?
      N 1 Reply Last reply
      • N
        nekobus76 @fredo6
        @fredo6 I believe so, I installed v14.3d
        • N
          nekobus76 @nekobus76
          UPDATE: I have no idea why but when I checked the settings in Sketchucation it was set to not load LibFredo and a couple of other plugins that I've been having issues with as well... It's strange because this is a recently installed Sketchup 2024 and I haven't touched those settings. Oh well, now I can use your plugins again!
          @fredo6 Thanks for making my life easier for the many years I've been using Sketchup!
          • fredo6F
            NEW RELEASE: LibFredo6 v14.4a - 10 May 24
            LibFredo6 14.4a includes changes related to:
            • Bug fixing for Curviloft Along Path (see this post)
            • New extension Fredo Layport
            • fredo6F
              NEW RELEASE: LibFredo6 v14.4c - 18 May 24
              LibFredo6 14.4c includes changes related to:
              • Bug fixing for FredoCorner (see this post)
              • fredo6F
                NEW RELEASE: LibFredo6 v14.4d - 20 May 24
                LibFredo6 14.4d includes changes related to:
                • Bug fixing for a side-effect introduced in v14.c which impacts JointPushPull. See this post.
                I 1 Reply Last reply
                • I
                  igortrem Newcomers @fredo6
                  @fredo6 said in [Plugin Library] LibFredo6 - v14.4d - 20 May 24:
                  Hi there,
                  Just purchased license for Fredo6 round corner for my Sketchup 2024, and it's asking to install Extension Store. Cas somebody can guide me? Can't find it.
                  TIGT 1 Reply Last reply
                    TIG Moderator @igortrem
                    @igortrem
                    For Fredo's extensions you need to install the latest version, and those for LibFredo6, and the SketchUcation Tools, which includes our ExtensionStore which handles the licensing...
                    Restart after installing to sync everything.
                    There are links in the extension's page about licensing procedures...
                    These are extensions all available from the PluginStore
                    [link to it via the 'ruby' icon in the top-bar of this page]...
                    https://sketchucation.com/pluginstore
                    https://sketchucation.com/pluginstore?pln=RoundCorner
                    https://sketchucation.com/pluginstore?pln=LibFredo6
                    https://sketchucation.com/pluginstore?pln=SketchUcationTools
                    If you have the ExtensionStore loaded you can find and install any of the plugins/extensions available in our PluginStore, but more conveniently it will AutoInstall them, without the need to download any RBZ files and manually install them, and later on it will remind you of available updates etc...
                    • fredo6F
                      NEW RELEASE: LibFredo6 v14.5a - 23 May 24
                      LibFredo6 14.5a includes changes related to:
                      • For Fredo Layport v1.1
                      • fredo6F
                        NEW RELEASE: LibFredo6 v14.5b - 24 May 24
                        LibFredo6 14.5b includes changes related to:
                        • small technical adjustment
                          JuanDAniel12343211232 Newcomers @fredo6
                          @fredo6 said in [Plugin Library] LibFredo6 - v14.5b - 24 May 24:
                          etchup version: SU2017 and above (for Mac M1, SU2021 and above)
                          Platform: Windows and Mac OSX
                          Usage: Free
                          M 1 Reply Last reply
                            massrequiem @JuanDAniel12343211232
                            @fredo6: I ran into this while in the process of updating the extensions for 2024.
                            • Y
                              youppi
                              Hello,
                              I have a problem with icons that no longer appear in the configuration menus (see screenshot) in Fredo6 extensions such as FredoTools, JointPushPull, LordOfTheToolbars...
                              I use SketchUp v2020 and LibFredo6 v14.5b.
                              Any idea where this might be coming from?
                              fredo6F 1 Reply Last reply
                              • fredo6F
                                fredo6 @youppi
                                @youppi
                                Did you do anything special before it happens?
                                Could you invoke the menu Window > LibFredo6 Settings.... > Fredo6 Plugins Information for Sketchucation support, to see what is the status of your plugins.
                                Y 1 Reply Last reply
                                • Y
                                  youppi @fredo6
                                  @fredo6
                                  This is what is written in the Console Ruby :
                                  Fredo6 Plugins Information on 2024-06-08 23:47:38 +0200
                                  • Platform: x64-mingw32 - Ruby: 2.5.5
                                  • Sketchup: 20.2.172
                                  • LibFredo6: v14.5b
                                  • LibFredo6 Binary loaded
                                  • Sketchucation ExtensionStore: 4.4.1
                                  • SCFLicense: v6.4a - 74
                                  • Fredo6 Plugins
                                    JointPushPull v4.8a - licensed FULL
                                    Signature File: 2020-12-11 09:04:28 +0100
                                    ClothWorks: 2022-11-30 12:22:30 +0100
                                    Curviloft: 2022-11-30 13:03:02 +0100
                                    Curvizard: 2022-11-30 13:03:16 +0100
                                    FredoScale: 2022-11-30 13:03:37 +0100
                                    JointPushPull: 2022-11-30 12:36:32 +0100
                                    RoundCorner: 2022-11-30 13:03:59 +0100
                                    ToolsOnSurface: 2022-11-30 13:04:40 +0100
                                    TopoShaper: 2022-11-30 13:04:53 +0100
                                    VisuHole: 2022-11-30 13:05:04 +0100
                                    "Add help menu!"
                                    "create new"
                                    "created"
                                    #Sketchup::Menu:0x00000110fbc93670
                                  • fredo6F
                                    fredo6 @youppi
                                    @youppi
                                    Thanks.
                                    Did it happen suddenly? or after you did an installation?
                                    Before calling the Quick Launcher of Joint PushPull, can you leave the Ruby open to see if there are errors.
                                      adams_1127
                                      This does not work on 2024 sketchup. It does not load properly. Is there a catch?
                                        TIG Moderator @adams_1127
                                        @adams_1127
                                        Please explain what you mean.
                                        LibFredo6 does not 'work' at all - it simply adds functions that are used by many other Fredo6 extensions.
                                        If you have the latest versions of the LibFredo6, the related Fredo6 extensions and the SketchUcation Tools [for the licensing] installed - and SketchUp is restarted so that everything is synced, then things should work...
                                        If you are having specific issues, then please explain them clearly, so that Fredo can help...
                                        • F
                                          Finito86 Newcomers
                                          Hi, i've tried with SU 21, 23 and 24 but few are the extensions that works fine. The most important LibFredo6 i want to work. Afte several investigation i found out that the extensions SU cant load (even being installed and correctly identify by the Extension Manager) because this ones are installed with a file format RBE and the ones that does works are installes with a files format RBS.
                                          Now i'm not a scripter but on sketchucation web it shows an example of how should be instaled and states .rb files....i dont have rb files just rbe.
                                          Can someone help me here? I leave a copy of the error from skech up aswell screenshots from my computer1.jpg 2.jpg 3.jpg 4.jpg
                                          Informe de errores de extensión
                                          SketchUp: 24.0.553
                                          OS: Windows 11
                                          Ruby: 3.2.2
                                          Extensión: Fredo6 AdditionalPluginFolders (v5.4a - 27 Sep 20)
                                          Error: Failed to load file (Failed to read RBE/RBS file.)
                                          C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:140:in register_extension'
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:140:in register_execute' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:618:in module:AdditionalPluginFolders6'
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:29:in `<top (required)>'
                                          Extensión: [unknown]
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/DM_Bevel.rb:4:in `<top (required)>'
                                          Extensión: Fredo6 LibFredo6 (1.0)
                                          C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:66:in register_extension'
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:66:in process' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                                          Extensión: SketchUcation (4.4.1)
                                          C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:181:in register_extension'
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:181:in <module:SCF>' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:17:in <top (required)>'
                                          C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/habitat_site_context.rb:6:in <module:HabitatSiteContext>' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/habitat_site_context.rb:4:in <top (required)>'
                                          • fredo6F
                                            The best would be to upgrade first the plugins to their latest versions:
                                            • LibFredo6
                                            • The plugins like RoundCorner, ....
                                            F 4 Replies Last reply
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 102
                                            • 113
                                            • 114
                                            • 100 / 114
