    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 581 Posters 6.7m Views 583 Watching
      @leranong
      While we wait for Fredo to reply...
      Being unable to read installed files is often a clue to an incorrect installation of SketchUp.
      You don't need to reinstall it, but do the following... which will not impact on any customization thus far...
      Close SketchUp.
      Find its installer exe file [usually in your Downloads folder]
      Select its icon, right-click > context-menu > 'Run as administrator'
      When prompted by the dialog that will open choose 'Repair'.
      When if is completed, retry SketchUp and see if the problems are gone.
      Installing a complex app by double-click its installer's exe file to 'Run' it, is not the same as doing it as I describe; even if you have admin powers the results will vary unpredictably - often messing up permissions.
      Also make sure you have the latest versions of Fredo's exensions, his LibFredo, and the SketchUcation Tools [for licensing] installed and SketchUp restarted to sync everything...
        leranong Newcomers
        @tig said:
        @leranong
        Close SketchUp.
        Thank you for trying to help me, appreciate it. But it doesn't work for me, the problem is repeated - these files can't be opened. I did what you said and also tried to uninstall everything and reinstall - but nothing helps. It seems that the only way is to reinstall my Windows))))))
        • fredo6F Offline
          This seems to be a Sketchup problem, already reported by users and independent from LibFredo6.
          Usually, it is related to permissions.
          A clean installation of Sketchup with admin rights is what is recommended.
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v14.3a - 30 Mar 24
            LibFredo6 14.3a includes changes related to:
            • Future compatibility
            • Various bug fixes and adjustments
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v14.3b - 31 Mar 24
              LibFredo6 14.3b includes changes related to:
              • Correction for Check Plugins for Update (due to the migration of the Sketchucation forum)
              S 1 Reply Last reply Reply Quote 0
                santiagoyagogil @fredo6
                Buenas, de manera repentina me han dejado de funcionar los complementos de Fredo.
                He podido averiguar que no se cargan las Libfredo, las he instalado de nuevo varias veces
                pero no consigo que funcione. Me sale este mensaje en la consola de ruby
                Que instalado varias veces le LibFedro y el Sketchup. Pero sigo igual.
                Algunas idea de como solucionarlo.
                fredo6F 1 Reply Last reply Reply Quote 0
                • fredo6F Offline
                  fredo6 @santiagoyagogil
                  @santiagoyagogil
                  You seem to have problems with the loading of binaries.
                  I suggest that you go to the Plugin directory and delete the Fredo6_!LibFredo6 folder. Then, resinstall LibFredo6 v14.3b.
                  For Sketchucation ExtensionStore, I also suggest that you upgrade to version 4.4.0, even if you run SU2023.
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v14.3d - 21 Apr 24
                    LibFredo6 14.3d includes changes related to:
                    • Correction for bugs for LordOfTheToolbars
                      Buenas Fredo.
                      El problemo lo tenia en dos equipos. en uno de ellos lo he solucionado dando todos los perminos a la carpeta y archico donde me daba el error de acceso denegado
                      Pero en otro equipo de un compañero. Le sigue saliendo el Libfredo6 binary not loaded. Aunque si que le carga el resto de extensiones de Fredo. Pero no puede
                      ejecutarlas.
                      Que puede ser que no carge las libfredo6 Binary? donde esta ese archivo?
                      Saludos
                      TIGT 1 Reply Last reply Reply Quote 0
                        TIG Moderator @santiagoyagogil
                        @santiagoyagogil
                        If the previously posted massage, it says 'Access denied' - so then the file is there, but access to 'run' it is stopped by your permissions for that folder.
                        I suggest you open the C:/Users/santi/AppData/Local/Temp folder and right-click > context-menu > Properties > Security > Edit and ensure that all entries listed have 'Full control' permissions set.
                        These should trickle down to all enclosed files and subfolders.
                        Apply to all and close.
                        It might take a few minutes.
                        Try SketchUp again...
                        Si el mensaje publicado anteriormente dice "Acceso denegado", entonces el archivo está ahí, pero el acceso para "ejecutarlo" está detenido por sus permisos para esa carpeta.
                        Le sugiero que abra la carpeta C:/Users/santi/AppData/Local/Temp y haga clic derecho > menú contextual > Propiedades > Seguridad > Editar y asegúrese de que todas las entradas enumeradas tengan configurados los permisos de "Control total".
                        Estos deberían llegar a todos los archivos y subcarpetas adjuntos.
                        Aplicar a todos y cerrar.
                        Puede que tarde unos minutos.
                        Prueba SketchUp de nuevo...
                        • fredo6F Offline
                          fredo6 @TIG
                          @santiagoyagogil
                          it might also be a problem of Sketchup installation.
                          Did you install with 'Run as Administrator'?
                          S 1 Reply Last reply Reply Quote 1
                            Gracias . Solucionado.
                            Era un tema de permisos. al final al poner todas las entradas de permisos en "on" de la carperta Temp se ha solucionado el problema.
                            Saludos
                            [Thank you . Solved.
                            It was a permissions issue. In the end, setting all the permissions entries to "on" in the Temp folder solved the problem.]
                            • N Offline
                              nekobus76
                              Hi. I'm having a similar problem and getting this message:
                              Also, all of the Fredo6 plugin icons have disappeared!
                              Thanks for your help!
                              • fredo6F Offline
                                Did you install LibFredo6 (latest version)?
                                N 1 Reply Last reply Reply Quote 0
                                • N Offline
                                  nekobus76 @fredo6
                                  @fredo6 I believe so, I installed v14.3d
                                  • N Offline
                                    nekobus76 @nekobus76
                                    UPDATE: I have no idea why but when I checked the settings in Sketchucation it was set to not load LibFredo and a couple of other plugins that I've been having issues with as well... It's strange because this is a recently installed Sketchup 2024 and I haven't touched those settings. Oh well, now I can use your plugins again!
                                    @fredo6 Thanks for making my life easier for the many years I've been using Sketchup!
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v14.4a - 10 May 24
                                      LibFredo6 14.4a includes changes related to:
                                      • Bug fixing for Curviloft Along Path (see this post)
                                      • New extension Fredo Layport
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v14.4c - 18 May 24
                                        LibFredo6 14.4c includes changes related to:
                                        • Bug fixing for FredoCorner (see this post)
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v14.4d - 20 May 24
                                          LibFredo6 14.4d includes changes related to:
                                          • Bug fixing for a side-effect introduced in v14.c which impacts JointPushPull. See this post.
                                          I 1 Reply Last reply Reply Quote 0
                                          • I Offline
                                            igortrem Newcomers @fredo6
                                            @fredo6 said in [Plugin Library] LibFredo6 - v14.4d - 20 May 24:
                                            Hi there,
                                            Just purchased license for Fredo6 round corner for my Sketchup 2024, and it's asking to install Extension Store. Cas somebody can guide me? Can't find it.
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 102
                                            • 111
                                            • 112
                                            • 100 / 112
