    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • I
      igortrem Newcomers @fredo6
      @fredo6 said in [Plugin Library] LibFredo6 - v14.4d - 20 May 24:
      NEW RELEASE: LibFredo6 v14.4d - 20 May 24
      LibFredo6 14.4d includes changes related to:
      • Bug fixing for a side-effect introduced in v14.c which impacts JointPushPull. See this post.
      Hi there,
      Just purchased license for Fredo6 round corner for my Sketchup 2024, and it's asking to install Extension Store. Cas somebody can guide me? Can't find it.
      TIGT 1 Reply Last reply
        TIG Moderator @igortrem
        @igortrem
        For Fredo's extensions you need to install the latest version, and those for LibFredo6, and the SketchUcation Tools, which includes our ExtensionStore which handles the licensing...
        Restart after installing to sync everything.
        There are links in the extension's page about licensing procedures...
        These are extensions all available from the PluginStore
        [link to it via the 'ruby' icon in the top-bar of this page]...
        https://sketchucation.com/pluginstore
        https://sketchucation.com/pluginstore?pln=RoundCorner
        https://sketchucation.com/pluginstore?pln=LibFredo6
        https://sketchucation.com/pluginstore?pln=SketchUcationTools
        If you have the ExtensionStore loaded you can find and install any of the plugins/extensions available in our PluginStore, but more conveniently it will AutoInstall them, without the need to download any RBZ files and manually install them, and later on it will remind you of available updates etc...
        • fredo6F
          NEW RELEASE: LibFredo6 v14.5a - 23 May 24
          LibFredo6 14.5a includes changes related to:
          • For Fredo Layport v1.1
          • fredo6F
            NEW RELEASE: LibFredo6 v14.5b - 24 May 24
            LibFredo6 14.5b includes changes related to:
            • small technical adjustment
              JuanDAniel12343211232 Newcomers @fredo6
              @fredo6 said in [Plugin Library] LibFredo6 - v14.5b - 24 May 24:
              etchup version: SU2017 and above (for Mac M1, SU2021 and above)
              Platform: Windows and Mac OSX
              Usage: Free
              M 1 Reply Last reply
                massrequiem @JuanDAniel12343211232
                @fredo6: I ran into this while in the process of updating the extensions for 2024.
                • Y
                  youppi
                  Hello,
                  I have a problem with icons that no longer appear in the configuration menus (see screenshot) in Fredo6 extensions such as FredoTools, JointPushPull, LordOfTheToolbars...
                  I use SketchUp v2020 and LibFredo6 v14.5b.
                  Any idea where this might be coming from?
                  fredo6F 1 Reply Last reply
                  • fredo6F
                    fredo6 @youppi
                    @youppi
                    Did you do anything special before it happens?
                    Could you invoke the menu Window > LibFredo6 Settings.... > Fredo6 Plugins Information for Sketchucation support, to see what is the status of your plugins.
                    Y 1 Reply Last reply
                    • Y
                      youppi @fredo6
                      @fredo6
                      This is what is written in the Console Ruby :
                      Fredo6 Plugins Information on 2024-06-08 23:47:38 +0200
                      • Platform: x64-mingw32 - Ruby: 2.5.5
                      • Sketchup: 20.2.172
                      • LibFredo6: v14.5b
                      • LibFredo6 Binary loaded
                      • Sketchucation ExtensionStore: 4.4.1
                      • SCFLicense: v6.4a - 74
                      • Fredo6 Plugins
                        JointPushPull v4.8a - licensed FULL
                        Signature File: 2020-12-11 09:04:28 +0100
                        ClothWorks: 2022-11-30 12:22:30 +0100
                        Curviloft: 2022-11-30 13:03:02 +0100
                        Curvizard: 2022-11-30 13:03:16 +0100
                        FredoScale: 2022-11-30 13:03:37 +0100
                        JointPushPull: 2022-11-30 12:36:32 +0100
                        RoundCorner: 2022-11-30 13:03:59 +0100
                        ToolsOnSurface: 2022-11-30 13:04:40 +0100
                        TopoShaper: 2022-11-30 13:04:53 +0100
                        VisuHole: 2022-11-30 13:05:04 +0100
                        "Add help menu!"
                        "create new"
                        "created"
                        #Sketchup::Menu:0x00000110fbc93670
                      • fredo6F
                        fredo6 @youppi
                        @youppi
                        Thanks.
                        Did it happen suddenly? or after you did an installation?
                        Before calling the Quick Launcher of Joint PushPull, can you leave the Ruby open to see if there are errors.
                          adams_1127
                          This does not work on 2024 sketchup. It does not load properly. Is there a catch?
                            TIG Moderator @adams_1127
                            @adams_1127
                            Please explain what you mean.
                            LibFredo6 does not 'work' at all - it simply adds functions that are used by many other Fredo6 extensions.
                            If you have the latest versions of the LibFredo6, the related Fredo6 extensions and the SketchUcation Tools [for the licensing] installed - and SketchUp is restarted so that everything is synced, then things should work...
                            If you are having specific issues, then please explain them clearly, so that Fredo can help...
                            • F
                              Finito86 Newcomers
                              Hi, i've tried with SU 21, 23 and 24 but few are the extensions that works fine. The most important LibFredo6 i want to work. Afte several investigation i found out that the extensions SU cant load (even being installed and correctly identify by the Extension Manager) because this ones are installed with a file format RBE and the ones that does works are installes with a files format RBS.
                              Now i'm not a scripter but on sketchucation web it shows an example of how should be instaled and states .rb files....i dont have rb files just rbe.
                              Can someone help me here? I leave a copy of the error from skech up aswell screenshots from my computer1.jpg 2.jpg 3.jpg 4.jpg
                              Informe de errores de extensión
                              SketchUp: 24.0.553
                              OS: Windows 11
                              Ruby: 3.2.2
                              Extensión: Fredo6 AdditionalPluginFolders (v5.4a - 27 Sep 20)
                              Error: Failed to load file (Failed to read RBE/RBS file.)
                              C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:140:in register_extension'
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:140:in register_execute' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:618:in module:AdditionalPluginFolders6'
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/!AdditionalPluginFolders.rb:29:in `<top (required)>'
                              Extensión: [unknown]
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/DM_Bevel.rb:4:in `<top (required)>'
                              Extensión: Fredo6 LibFredo6 (1.0)
                              C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:66:in register_extension'
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:66:in process' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                              Extensión: SketchUcation (4.4.1)
                              C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:181:in register_extension'
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:181:in <module:SCF>' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/SketchUcation.rb:17:in <top (required)>'
                              C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/habitat_site_context.rb:6:in <module:HabitatSiteContext>' C:/Users/Finito/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/habitat_site_context.rb:4:in <top (required)>'
                              • fredo6F
                                The best would be to upgrade first the plugins to their latest versions:
                                • LibFredo6
                                • The plugins like RoundCorner, ....
                                F 4 Replies Last reply
                                • F
                                  Finito86 Newcomers @fredo6
                                  @fredo6 they are already updated.
                                  Check it up in this picture. Even further the sketch up suggest to download the latest version of fredo6....and gives me the option to redirect theweb site to sketchucation where the lates version is. Still the same place i downloaded in the first time. Every time i start up the sketch up is says to update the fredo version and keeps insisting to install the same version onces and again.
                                  • F
                                    • F
                                      • F
                                        • LibFredo6
                                        Done, i dont understand why it ask me to update the libfredo6 when i installed the latest version, the same happens with other extensions.
                                        Here are the extensions i downloaded and wont work.
                                          TIG Moderator @Finito86
                                          @Finito86
                                          You say you have 'installed' these extensions...
                                          But you published a screenshot showing the downloaded RBZ files for these extensions, not the installed extensions themselves.
                                          You need to actually install an RBZ file's contents into your Plugins folder.
                                          Use the Extensions > Extensions Manager dialog to Install... them [but see below for an even easier way...]
                                          Restart SketchUp to sync everything after the installation[s].
                                          Most of Fredo's extensions will also require his LibFredo6 installing as that provides many 'behind-the-scenes' functions...
                                          Note that you will need the latest SketchUcationTools installing, to run for any licensing...
                                          But, if you install the SketchUcationTools there are several very helpful additional tools created in SketchUp - e.g. the ExtensionStore - a dialog which let's you AutoInstall extensions directly from our PluginStore, sidestepping the RBZ part download altogether.
                                          • F
                                            Finito86 Newcomers @TIG
                                            @TIG Hi, yes, i did not upload the picture to show the plugins installed, so here it is.
                                            Please notice the sketchucation is also installed and still the same problem not showing on the software.
                                            The plugins of Truebend, Randomtools and 1001bit_freeware are also installed with the same process by using the Extension Manager. They do appear on the software and i can use them with no problem.
                                            fredo6F TIGT 2 Replies Last reply
                                            • 99
                                            • 100
                                            • 101
                                            • 102
                                            • 103
                                            • 113
                                            • 114
                                            • 101 / 114
