    Curviloft and sketchup 2024 problem
    42 Posts 7 Posters 5.5k Views 6 Watching
    • alexpacio2013A
      alexpacio2013 @fredo6
      @fredo6
      I have some good news to give you, with the new library it seems to work very well even with 2024. I hadn't restarted sketchup, which is why it wasn't working well. Now I've done some tests and everything seems to work correctly.
      fredo6F 1 Reply Last reply
      • fredo6F
        fredo6 @alexpacio2013
        @alexpacio2013
        Many thanks for your support. I prefer this, because I actually fixed a problem with a more robust algorithm. In SU2024, for whatever reason, the old method suffered from precision versus SU2022.
        alexpacio2013A 1 Reply Last reply
        • alexpacio2013A
          @fredo6
          Congratulations for your fast support, now only one miracle is missing, Lordofthetoolbars compatible with su2024, for me it is indispensable, try to convince the people at trimble to solve the problem.
          Thank you
          • alexpacio2013A
            @fredo6 said in Curviloft and sketchup 2024 problem:
            The issue should be fixed with LibFredo6 v14.4a, just published.
            the problem remains with the Fredo Corner, which in the 2024 version behaves very strangely, look at the differences between 2022 and 2024.
            Perhaps a different algorithm is needed here too.
            • alexpacio2013A
              • fredo6F
                @alexpacio2013
                For FredoCorner, it must be something else. The fix I made is only for Curviloft.
                This is why I asked for the skp file of the FredoCorner case.
                • alexpacio2013A
                  @fredo6
                  Try the same object with Fredocorner on sketchup 2022 and sketchup 2024.
                  here is the file
                  Fredocorner.skp
                  • fredo6F
                    @alexpacio2013
                    Many thanks.
                    I am not at home before Wednesday. So, I'll have a look tomorrow.
                    • E
                      ermod Newcomers
                      I am a licensed user, but I constantly receive this warning and I cannot use extensions.''Trial Period Expired: curvilot
                      Trial period has expired since Mon 13 Mar 2023
                      You now need to get a License to continue using the extension.
                      what should ı do? also how is the update done?
                      Rich O BrienR TIGT 2 Replies Last reply
                        Rich O Brien Moderator @ermod
                        @ermod said in Curviloft and sketchup 2024 problem:
                        Update Sketchucation Tools
                        https://sketchucation.com/plugin/696-sketchucationtools
                        Update Libfredo
                        https://sketchucation.com/pluginstore?pln=LibFredo6
                        Update Curviloft
                        https://sketchucation.com/pluginstore?pln=Curviloft
                        If you launch our ExtensionStore in SketchUp and click the bell icon it will list all extensions you need to update in you have installed them using it.
                        If not just click the Paste icon and type eg: pln=curviloft
                          TIG Moderator @ermod
                          @ermod
                          You need to buy a inexpensive license.
                          There are link buttons and help-page links in the warning dialog.
                          Then install the latest versions of the extension, LibFredo6 and the SketchUcation Tools [for the licensing].
                          Restart SketchUp to sync everything, then validate the license on your computer...
                          • alexpacio2013A
                            @fredo6
                            For information, round with corner, it also works perfectly on SketchUp 2024
                            • fredo6F
                              @alexpacio2013
                              The problem should be fixed with the new version LibFredo6 v14.4c, just published.
                              Many thanks for signaling the bug and providing the model.
                              Reply Quote -2
                              • alexpacio2013A
                                @alexpacio2013
                                Perfect, thanks for the quick resolution of the problem
                                • 2 / 3
