    Curviloft and sketchup 2024 problem
    42 Posts 7 Posters 6.7k Views 6 Watching
    • fredo6F
      fredo6 @alexpacio2013
      @alexpacio2013
      Do not waste time to resinstall.
      This seems to be a problem in Curviloft, which very strangely is prsent in SU2023 and SU2024 and was never signaled.
      I have to investigate....
      alexpacio2013A 1 Reply Last reply
      • alexpacio2013A
        alexpacio2013 @fredo6
        @fredo6
        I don't want to alarm you but I'm telling you that there is also a problem with Fredo corner which in the 2024 version behaves in a very strange way, look at the differences between 2022 and 2024.
        Those at Trimble definitely don't give you a hand but without your plugins I can't work with sketchupSketchUp_SmWdeB0kCV.jpg
        fredo6F 1 Reply Last reply
        • fredo6F
          @alexpacio2013
          Many thanks for signaling these problems.
          Definitely, SU2023 / SU2024 have introduced a change that is impacting some algorithms.
          Would you mind to send me the model for FredoCorner.
          • alexpacio2013A
            @fredo6
            do you have a private email to give me, or can I put the files on googledrive for you?
            My email is roberto. bolletta[@]gmail. com
            • alexpacio2013A
              alexpacio2013
              This post is deleted!
              • alexpacio2013A
                alexpacio2013
                files skp
                • alexpacio2013A
                  alexpacio2013
                  link files
                  • alexpacio2013A alexpacio2013 deleted this topic on
                  • alexpacio2013A alexpacio2013 restored this topic on
                  • fredo6F
                    The issue should be fixed with LibFredo6 v14.4a, just published.
                    alexpacio2013A 4 Replies Last reply
                    • alexpacio2013A
                      @fredo6
                      Now there is no longer the error that prevented us from moving forward but the result is wrong look at the result 2024 is deformed, it is not correct, while with 2022 the object is perfectly formed
                      • alexpacio2013A
                        alexpacio2013 @alexpacio2013
                        • alexpacio2013A
                          @fredo6
                          For information I tried to insert the squares perpendicular to each node manually and then instead of using the follow me I used And as you can see the finished shape is correct so it is an axis problem at each node. Always with su 2024 and the library you updated
                          • fredo6F
                            @alexpacio2013
                            Could you send me the model so that I investigate.
                            • alexpacio2013A
                              @fredo6
                              I have some good news to give you, with the new library it seems to work very well even with 2024. I hadn't restarted sketchup, which is why it wasn't working well. Now I've done some tests and everything seems to work correctly.
                              • fredo6F
                                @alexpacio2013
                                Many thanks for your support. I prefer this, because I actually fixed a problem with a more robust algorithm. In SU2024, for whatever reason, the old method suffered from precision versus SU2022.
                                • alexpacio2013A
                                  @fredo6
                                  Congratulations for your fast support, now only one miracle is missing, Lordofthetoolbars compatible with su2024, for me it is indispensable, try to convince the people at trimble to solve the problem.
                                  Thank you
                                  • alexpacio2013A
                                    @fredo6 said in Curviloft and sketchup 2024 problem:
                                    the problem remains with the Fredo Corner, which in the 2024 version behaves very strangely, look at the differences between 2022 and 2024.
                                    Perhaps a different algorithm is needed here too.
                                    • alexpacio2013A
                                      • fredo6F
                                        @alexpacio2013
                                        For FredoCorner, it must be something else. The fix I made is only for Curviloft.
                                        This is why I asked for the skp file of the FredoCorner case.
                                        • alexpacio2013A
                                          @fredo6
                                          Try the same object with Fredocorner on sketchup 2022 and sketchup 2024.
                                          here is the file
                                          Fredocorner.skp
                                          • fredo6F
                                            @alexpacio2013
                                            Many thanks.
                                            I am not at home before Wednesday. So, I'll have a look tomorrow.
                                            • 2 / 3
