    2.2k Posts 482 Posters 854.1k Views 487 Watching
      da800429 Newcomers @Rich O Brien
      @Rich-O-Brien
      I don't want a refund
      I just want to solve the problem with you
      I sent the video to support@sketchucation.com
        Rich O Brien Moderator @da800429
        @da800429 I replied via email. But for others I'll post here.
        The error was a communication issue with our server. This occurs when either the network environment your device is connected has strict rules or you are running some piece of software that detects something with SketchUp is trying to connect to a server.
        The remedy is to whitelist our server by either using the following address
        *.sketchucation.com
        Or using our IP addresses
        178.63.47.155
        144.76.69.227
        D 1 Reply Last reply Reply Quote 0
          @Rich-O-Brien
          My network uses WIFI. I turned off the firewall and couldn't add the license normally.
          I don't know how to join the whitelist, can you teach me?
            @da800429 It is likely there is hardware or software running protective measures that see the licensing system as a threat.
            Your other option is to tether your device to your phone's network and try that.
            For whitelisting if you are running Defender you could try adding a custom rule
            https://answers.microsoft.com/en-us/windows/forum/all/add-ip-address-and-url-to-windows-defender/5a96cd4c-aa36-414d-aa7a-2d14b6a6dc79
            Have you tried repairing your SketchUp install?
            Attention Required! | Cloudflare
            (help.sketchup.com)
            In some instances that may cause the error.
            If none of the above fix it then we will refund.
              LOAR @Rich O Brien
              @Rich-O-Brien @da800429 I had this same error, which was quite frustrating for a while. Eventually I closed all the sketchup windows I had open and only opened one model. Then the validation worked. So maybe it's something to do with multiple models being open that gets in the way of validation? Hope this helps
              • V Offline
                vitalisvitalis Newcomers
                hi,I just brought a fredo scaLE but bit aasks for license,what to do?
                  Rich O Brien Moderator @vitalisvitalis
                  @vitalisvitalis said in SCFLicense: Extension Licensing on Sketchucation:
                  Following activation guide https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                    g_petinati
                    Hi Fredo. I'm having an issue with my FREDO CORNER license.
                    I get the message that "License Seats Exceeded".
                    I reinstalled Sketchup, and did not release the license from the old installation. Is there a way to correct this issue?
                    Thank you.
                      labaruss
                      Hi Fredo and others. Since I change the name of my computer the license fail of your tools. What shuld I do ? Thank you.
                      fredo6F 1 Reply Last reply Reply Quote 0
                        labaruss
                        This post is deleted!
                        • fredo6F Offline
                          fredo6 @labaruss
                          @labaruss
                          You can manage your licenses at this page, My Licenses at Sketchucation.
                            titty456
                            @Rich-O-Brien
                            I have purchased curviloft, but I encounter a problem with A04. How to solve it?
                            Fredo6 Plugins Information on 2024-05-03 18:38:51 +0800
                            • Platform: x64-mswin64_140 - Ruby: 2.7.2
                            • Sketchup: 23.0.397
                            • LibFredo6: v14.3d
                            • LibFredo6 Binary loaded
                            • Sketchucation ExtensionStore: 4.4.1
                            • SCFLicense: v6.4a - 74
                            • Fredo6 Plugins
                              Curviloft v1.9b
                              JointPushPull v4.4e
                              Signature File: 2024-05-03 18:31:59 +0800
                            TIGT 1 Reply Last reply Reply Quote 0
                              TIG Moderator @titty456
                              @titty456
                              An A04 error means it can't decode the signature file.
                              Have you tried deleting that file and redoing it again ?
                              Do you have any non-ASCII characters in your computer's user-name ?
                              In case it's a permissions issue have you installed SketchUp properly ?
                              You can 'Repair' it thus...
                              Log out of SketchUp.
                              Find the installer's exe file - usually in your Downloads folder.
                              Select the exe file's icon, right-click > context-menu > Run as administrator.
                              When prompted choose 'Repair'.
                              Reboot your computer and retry SketchUp.
                              Installing a complex app by double-clicking its icon is not the same - even if you are an admin.
                              Doing that can lead to all kinds of unpredictable issues - often relating to reading/writing files...
                                titty456
                                @TIG Thank you for your help!
                                My problem solved because my computer's name have non-ASCII characters.
                                thank you!
                                  arkxell
                                  Hello. I changed the name of my computer and now I can't use the paid plugins. And the problem is that I no longer remember the original name of the PC. How should I proceed?
                                  • fredo6F Offline
                                    fredo6 @arkxell
                                    @arkxell
                                    The best is to go to your My Licenses on Sketchucation page (just sign in) and release the licenses.
                                    If the release seat button is not available, then tell me.
                                    • X Offline
                                      xxetq Newcomers
                                        manoukkuijper Newcomers
                                        I just bought it, why isn't it working?
                                          TIG Moderator @manoukkuijper
                                          @manoukkuijper
                                          You need to help us a bit more than this...
                                          You just bought what ?
                                          Let's assume it's a Fredo6 extension ??
                                          Have you downloaded/installed 'it' ?
                                          Have you downloaded/installed the latest LibFredo6, which it also needs ?
                                          Have you installed the SketchUcation Tools which will work the licensing code ?
                                          Have you restarted your computer to sync everything ?
                                          Have you read and understood the guidance for buying and saving your license file[s] onto your computer ?
                                          Have you tried to validate that license for the extension in it's submenu item under the Tools menu ?
                                          There's a lot you haven't told us...
                                          Please help us to help you...
                                            shamsa_amir @Gus R
                                            @Gus-R said in SCFLicense: Extension Licensing on Sketchucation:
                                            this morn
                                            hello , how can i get fredo ?
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 109
                                            • 110
                                            • 92 / 110
