    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.3k Views 170 Watching
    • B
      bazinit
      Seem to be having an issue with the Clothworks UI not opening when clicked, the simulation can still run but I can't make any fine adjustments.
      Has anyone else had this issue or know what I can do to fix it? I'm running Sketchup 2023 and used Clothworks a couple of weeks ago for a project and the UI worked perfectly. It still seems to work in SketchUp 2022 but I don't want to be switching between the 2 often as it slows workflow down significantly and is quite annoying.
      Any help is much appreciated!
      Cheers
        sashapepperspray
        Is clothworks going to be updated to work with sketchup 2024?
        (I get the following error when i try loading it
        Error: NoMethodError (undefined method exists?' for File:Class) c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:71:in block in require_all’
        c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in each' c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in require_all’
        c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/main.rbe:746:in <main>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval’
        C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load’
        C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in register_extension' C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in module:ClothWorks’
        C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:7:in module:AMS' C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:6:in <top (required)>’)
        TIGT 1 Reply Last reply
          TIG Moderator @sashapepperspray
          @sashapepperspray
          The method File.exists? has long been deprecated, but worked.
          In the latest Ruby version it doesn’t - File.exist? - works in v2024 and older versions as well.
          Many developers are working to adjust their code accordingly.
          Have patience and post any instances in an affected extension's thread - as there are 100s of 1000s of line of code with the tiniest corrections needing to be found and change, then the extension re-encrypted and signed…
          Many authors have already fixed their extensions, so look regularly to see if there’s already an update available…
          Reply Quote 2
          • EdsonE
            Edson
            Since I installed Sketchup 2024 I keep getting a message to the effect that ClothWorks has to be updated to run on it. Could you possibly do it? Thanks.
            Edson
            http://www.mahfuz.arq.br
            B 1 Reply Last reply
            • B
              burakberlin @Edson
              @Edson same here, i would appreciate the update for SU 2024.
              best,
              burak
                a4jp.com @Anton_S
                @Anton_S Any updates for SketchUp 2024?
                  dbrazina
                  I have just upgraded to Sketchup 2024 and Clothworks plugin will not load. I get the following error messages. I have uninstalled and reinstalled the plugin.
                  Extension Errors Report
                  SketchUp: 24.0.484
                  OS: Windows 11
                  Ruby: 3.2.2
                  Extension: ClothWorks (1.7.7a)
                  Error: NoMethodError (undefined method exists?' for File:Class) c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:71:in block in require_all'
                  c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in each' c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in require_all'
                  c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/main.rbe:746:in <main>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval'
                  C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load'
                  C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in register_extension' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in module:ClothWorks'
                  C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:7:in <module:AMS>' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:6:in <top (required)>'
                  Rich O BrienR TIGT 2 Replies Last reply
                    Rich O Brien Moderator @dbrazina
                    @dbrazina said in [Plugin] ClothWorks v1.7.7 - 2 May 2022:
                    Its not yet compatible with SketchUp 2024. The developer is aware and plans a release ASAP
                      TIG Moderator @dbrazina
                      @dbrazina
                      The error relates to
                      File.exists?()
                      this method was deprecated long ago and replaced with
                      File.exist?()
                      which is grammatically incorrect in English, but hey Ruby is international !
                      The older version had worked for many years 'in tandem', but it's now been removed from the newest Ruby version which ships with v2024.
                      So this now breaks older scripts that still include it...
                      It's relatively easy to fix - I found 2 instances that needed fixing in the various SketchUcation tools scripts when I was preparing them for this current version !
                      Another issue that the ClothWorks developer faces is that his code relies on some functions within some .so/.bundle files for different OSs, so he will need to compile new versions of these for compatibility with v2024's Ruby version...
                      • jo-keJ
                        jo-ke
                        I hope, it will be updated.
                        http://www.zz7.de
                          Anton_S
                          Hi all, the ClothWorks is now updated for SU2024. Thank you for your patience!
                          F X 2 Replies Last reply
                          Reply Quote 5
                          • F
                            FlawinneF
                            I receive an error message when importing a license.
                            18-Apr-24 19:13:56 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                            18-Apr-24 19:00:51 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                            18-Apr-24 18:59:02 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                            18-Apr-24 18:58:45 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                              TIG Moderator @FlawinneF
                              @FlawinneF
                              Have you got the newest version of the SketchUcation Tools installed ?
                              It handles the licensing system.
                              You can also login to you own licenses on this site using the link in the Extensions > SketchUcation submenu... My Licenses at SketchUcation...
                              https://sketchucation.com/webshop/my-licences.php
                              There you can manage all of your licenses...
                              F 1 Reply Last reply
                              • F
                                FlawinneF @TIG
                                @TIG thank you, it's activated
                                • F
                                  FlawinneF @Anton_S
                                  @Anton_S Why not fix the problem of the bar remaining active on Mac !!!
                                  if tb.get_last_state == TB_NEVER_SHOWN
                                    tb.show
                                  else
                                    tb.restore
                                  A 1 Reply Last reply
                                    Anton_S @FlawinneF
                                    @FlawinneF Thanks for that tip. I never knew about the get_last_state or restore. Will utilize in next release
                                      TIG Moderator @Anton_S
                                      @Anton_S
                                      I use this usually
                                      tb.show if tb.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                                      Has the same result...
                                        Anton_S @TIG
                                        Version 1.8.0 released.
                                        • Fix adaptive grid not working properly for some models on Mac OS X
                                        • Show toolbar properly on Mac OS X. Thanks @FlawinneF and @TIG
                                        • F
                                          FlawinneF @Anton_S
                                          @Anton_S
                                          Sorry I didn't, say thank you sooner, thank you for everything 🙂
                                          • X
                                            xinige @Anton_S
                                            @Anton_S Hello, Mr. Anton. I don't know when you will initiate the redevelopment of MSPhysics. As far as I know, countless people are looking forward to this project. Alternatively, you can develop a plugin that can partially implement certain functions.
                                            For example, a simulation tool that can implement simulation functions similar to fusion360 and SolidWorks may not require embedding a physics engine (I'm not sure), but only adding axes and motors, as well as collision detection. Used for designing machinery, mechanical gif diagrams, and checking the rationality of mechanical design in sketchup. I hope to receive your reply.
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 34 / 37
