    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 883.3k Views 166 Watching
      Do you also have the current version of the Sketchucation Extension Store installed?
      • I
        i5963c Extension Creator
        Hi, I think so. I have version 4.3.1. Not sure if it's really the most recent version?
        I don't recall how I installed it. The SketchUcation store (and also this site) lacks indeed a bit of userfriendlyness in my view. Difficult to navigate as far as I'm able to do.
        By the way, I also have the Fredo6 bundle installed (via the SketchUcation store) and that works fine. I installed this bundle half a year ago (together with the most up-to-date version of the SketchUcation store at that time). The ClothWorks extension (that I acquired some days ago) dates from before this date, so I would assume that my actual SketchUcation store version must be compatible with the (older) ClothWorks extension?
          @i5963c said:
          Hi, I think so.....
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          • I
            Hello, please find the requested info below.
            Fredo6 Plugins Information on 2024-01-19 17:33:54 +0100
            • Platform: x64-mingw32 - Ruby: 2.2.4
            • Sketchup: 17.2.2555
            • LibFredo6: v14.2a
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.3.1
            • SCFLicense: v6.1a - 72
            • Fredo6 Plugins
              Curviloft v1.9b - licensed FULL
              Curvizard v2.4b - licensed FULL
              FredoScale v3.5a - licensed FULL
              JointPushPull v4.7a - licensed FULL
              MatSim v1.2b
              MoveAlignMe v1.2a
              RoundCorner v3.3a - licensed FULL
              ToolsOnSurface v2.5a - licensed FULL
              Signature File: 2023-05-29 20:03:34 +0200
              ClothWorks: 2024-01-19 15:51:06 +0100
              Curviloft: 2023-05-29 20:45:27 +0200
              Curvizard: 2023-05-29 20:45:50 +0200
              FredoScale: 2023-05-29 20:47:48 +0200
              JointPushPull: 2023-05-29 20:48:02 +0200
              RoundCorner: 2023-05-29 20:46:08 +0200
              ToolsOnSurface: 2023-05-29 20:46:39 +0200
              TopoShaper: 2023-05-29 20:47:11 +0200
              VisuHole: 2023-05-29 20:47:28 +0200
              That's looks fine to me.
              So when you run a simulation you are unable to box select the pins and get the gizmo to appear?
              Can you email clothworks@sketchucation.com so Anton can chime in. I can't test as I don't have that older version of SketchUp.
              But it works for me on 2022/2023
              • I
                Just a quick update. As suggested, I contacted the author of the extension.
                He informed me that the selection of the pins (in order to compress them with the Gizmo) requires that the simulation is running. Actually, this was the solution for my problem!
                May be relevant if other users would face the same problem.
                • B
                  bazinit
                  Seem to be having an issue with the Clothworks UI not opening when clicked, the simulation can still run but I can't make any fine adjustments.
                  Has anyone else had this issue or know what I can do to fix it? I'm running Sketchup 2023 and used Clothworks a couple of weeks ago for a project and the UI worked perfectly. It still seems to work in SketchUp 2022 but I don't want to be switching between the 2 often as it slows workflow down significantly and is quite annoying.
                  Any help is much appreciated!
                  Cheers
                    sashapepperspray
                    Is clothworks going to be updated to work with sketchup 2024?
                    (I get the following error when i try loading it
                    Error: NoMethodError (undefined method exists?' for File:Class) c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:71:in block in require_all’
                    c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in each' c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in require_all’
                    c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/main.rbe:746:in <main>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval’
                    C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load’
                    C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in register_extension' C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in module:ClothWorks’
                    C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:7:in module:AMS' C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:6:in <top (required)>’)
                    TIGT 1 Reply Last reply
                      TIG Moderator @sashapepperspray
                      @sashapepperspray
                      The method File.exists? has long been deprecated, but worked.
                      In the latest Ruby version it doesn’t - File.exist? - works in v2024 and older versions as well.
                      Many developers are working to adjust their code accordingly.
                      Have patience and post any instances in an affected extension's thread - as there are 100s of 1000s of line of code with the tiniest corrections needing to be found and change, then the extension re-encrypted and signed…
                      Many authors have already fixed their extensions, so look regularly to see if there’s already an update available…
                      Reply Quote 2
                      • EdsonE
                        Edson
                        Since I installed Sketchup 2024 I keep getting a message to the effect that ClothWorks has to be updated to run on it. Could you possibly do it? Thanks.
                        Edson
                        http://www.mahfuz.arq.br
                        B 1 Reply Last reply
                        • B
                          burakberlin @Edson
                          @Edson same here, i would appreciate the update for SU 2024.
                          best,
                          burak
                            a4jp.com @Anton_S
                            @Anton_S Any updates for SketchUp 2024?
                              dbrazina
                              I have just upgraded to Sketchup 2024 and Clothworks plugin will not load. I get the following error messages. I have uninstalled and reinstalled the plugin.
                              Extension Errors Report
                              SketchUp: 24.0.484
                              OS: Windows 11
                              Ruby: 3.2.2
                              Extension: ClothWorks (1.7.7a)
                              Error: NoMethodError (undefined method exists?' for File:Class) c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:71:in block in require_all'
                              c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in each' c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in require_all'
                              c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/main.rbe:746:in <main>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval'
                              C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load'
                              C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in register_extension' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in module:ClothWorks'
                              C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:7:in <module:AMS>' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:6:in <top (required)>'
                              Rich O BrienR TIGT 2 Replies Last reply
                                Rich O Brien Moderator @dbrazina
                                @dbrazina said in [Plugin] ClothWorks v1.7.7 - 2 May 2022:
                                Its not yet compatible with SketchUp 2024. The developer is aware and plans a release ASAP
                                  TIG Moderator @dbrazina
                                  @dbrazina
                                  The error relates to
                                  File.exists?()
                                  this method was deprecated long ago and replaced with
                                  File.exist?()
                                  which is grammatically incorrect in English, but hey Ruby is international !
                                  The older version had worked for many years 'in tandem', but it's now been removed from the newest Ruby version which ships with v2024.
                                  So this now breaks older scripts that still include it...
                                  It's relatively easy to fix - I found 2 instances that needed fixing in the various SketchUcation tools scripts when I was preparing them for this current version !
                                  Another issue that the ClothWorks developer faces is that his code relies on some functions within some .so/.bundle files for different OSs, so he will need to compile new versions of these for compatibility with v2024's Ruby version...
                                  • jo-keJ
                                    jo-ke
                                    I hope, it will be updated.
                                    http://www.zz7.de
                                      Anton_S
                                      Hi all, the ClothWorks is now updated for SU2024. Thank you for your patience!
                                      F X 2 Replies Last reply
                                      Reply Quote 5
                                      • F
                                        FlawinneF
                                        I receive an error message when importing a license.
                                        18-Apr-24 19:13:56 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                                        18-Apr-24 19:00:51 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                                        18-Apr-24 18:59:02 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                                        18-Apr-24 18:58:45 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                                          TIG Moderator @FlawinneF
                                          @FlawinneF
                                          Have you got the newest version of the SketchUcation Tools installed ?
                                          It handles the licensing system.
                                          You can also login to you own licenses on this site using the link in the Extensions > SketchUcation submenu... My Licenses at SketchUcation...
                                          https://sketchucation.com/webshop/my-licences.php
                                          There you can manage all of your licenses...
                                          F 1 Reply Last reply
                                          • F
                                            FlawinneF @TIG
                                            @TIG thank you, it's activated
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 34 / 36
