    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 651.6k Views 161 Watching
      Anton_S
      ClothWorks
      ClothWorks is a cloth simulator for SketchUp for draping cloth and wires over components of any shape and size and also for simulating curtains and flags.
      Workflow functionalities include:
      • Quadrilateral, Equilateral, and Adaptive grids for converting face or a set of faces within a group/component into a grid of faces, with a desired grid padding. Additional edge purging options allow for removing the generated grid. Grid options are for manipulating cloth.
      • Split Edges for dividing an edge or a set of edges within a group/component into segments, with a desired edge padding. Weld Edges allows for merging the split edges. Edge options are for manipulating wires.
      • Loop Subdivision and Laplacian Smoothing options for subdividing and smoothing the resulting, simulated cloth or wires, while preserving texture UVQ coordinates.
      • Drape and Undrape for renewing and resetting (respectively) cloth, wire, and pin transformations. Toggling drapery is, particularly, useful for when changing the texture of the cloth.
      • Record and Export for recording simulation and exporting the animation into a sequence of images, SKP files, OBJ files, and various other formats. A third-party software, such as MakeAVI, can be used to combine a sequence of exported images into a video file.
      To get started, refer to and download the ClothWorks Manual.
      To install ClothWorks, you can refer to the ClothWorks Installation Guide.
      To buy and activate your license, please refer to the ClothWorks License Guide.
      Video Tutorials
      Platform and SketchUp Requirements
      • Window 7+ / Mac OS X 10.8+
      • SketchUp 2016 to 2024
      • SketchUcationTools v4.4.0 or later, for licensing and unlocking features. Note: The latest version of the extension must be installed for licensing to work properly!
      Installation Instructions
      ClothWorks can be installed via the SketchUcationTools extension or manually, from Plugin Store.
      You can also download at Google Drive
      Refer to the following steps for installing manually:
      1. Download ams_ClothWorks_vX.Y.Z.rbz.
      2. Navigate to your plugins folder (see Extension Folder Location section for details).
      3. Extract ams_ClothWorks_vX.Y.Z.rbz and copy the content into the plugins folder, so that the plugins folder contains ams_ClothWorks folder and ams_ClothWorks.rb file:
        …\SketchUp\Plugins
        • ams_ClothWorks
        • ams_ClothWorks.rb
      Uninstallation Instructions
      Refer to the steps below to uninstall the extension:
      1. Close SketchUp.
      2. Navigate to your plugins folder (see the Extension Folder Location section for details).
      3. Delete ams_ClothWorks folder and ams_ClothWorks.rb file.
      On Windows, the plugins folder is located at, either:
      %appdata%\SketchUp\SketchUp 20##\SketchUp\Plugins
      On Mac OS X, the plugins folder is located at:
      ~/Library/Application Support/SketchUp 20##/SketchUp/Plugins
      Licensing
      Licensing unlocks four features:
      1. Loop Subdivision – smoothens cloth by increasing resolution, meanwhile preserving texture coordinates
      2. Laplacian Smoothing – smoothens cloth by balancing vertices
      3. Movable Pins – allows transforming pinned cloth while in simulation
      4. Adaptive Grid – generates grids for complex faces and 3d geometry
      ClothWorks licensing depends on SketchUcationTools, version 4.4.0 or later. The latest version of the extension must be installed for licensing to work properly!
      With SketchUcationTools (v4.4.0+) installed, a licence file can be obtained and/or activated by accessing:
      (Menu) Extensions β†’ ClothWorks β†’ License…
      Within the licensing dialog:
      1. Click on the Obtain Licence button to purchase your licence. This will navigate you to SketchUcation PayPal purchasing page. Ensure to specify your email address correctly, so that the purchased licence file is shipped to the correct address.
      2. Upon receiving your licence, download the file and save it to your computer.
      3. To activate your licence, click on the Validate Licence button and select your purchased licence file. This will unlock all the features.
      At any given time, a purchased licence can be activated on up to three devices.
      For detailed instructions on activating your licence, please refer to ClothWorks License Guide.
      If you purchased a ClothWorks license and have not received an email with your license file, within the next 10 minutes, or experience any other licensing problems, please contact clothworks@sketchucation.com. Include your SketchUcation username in the email.
      If you are looking to obtain a new copy of your license file purchased earlier, please also send an email to clothworks@sketchucation.com and include your SketchUcation username in the description.
      Important Notes:
      Verify that the simulation works, and does not crash, prior to purchasing a licence.
      In case your license seat count becomes full, please refer to the Known Issue section, in ClothWorks License Guide on resetting your license.
      Known Issues and Limitations
      • Avoid using the undo command after a simulation. Each frame of simulation is treated as a single operation, which clutters the undo stack. To undo the cloth layout, make use of the Toggle Draped option, accessible from the ClothWorks toolbar or menu.
      • Self-collision is not perfect and may allow for self-overlaps. In case self-overlaps occur, applying smoothing options after the simulation, especially Laplacian smoothing, can eliminate overlaps.
      • Only top-level groups and components are assignable a cloth, a collider, or a pin type. All nested groups/components of a collider and a pin are included in the simulation.
      Useful Tops
      • Before starting the simulation, ensure that Outliner and Components inspectors are closed or collapsed. When these dialogs are open or expanded, there tends to be an extreme lag.
      • If self-collision is turned on, cloth thickness must not be greater than cloth grid spacing. If the thickness is greater than grid spacing, cloth geometry will clutter out due to overlaps with neighboring particles.
      • Increasing the update timestep, say from 1/420 to 1/180, makes cloth weaker. If possible, avoid increasing the update timestep. On the counter-note, decreasing the update timestep, say from 1/420 to 1/1200, makes the cloth significantly stiffer.
      • Overlaps with colliding opponents may also occur. To prevent overlaps when draping over a collider, reduce gravity, increase viscosity, and/or increase the thickness of the collider. To prevent overlaps with other cloth objects, increase the thickness of either to minimize the occurrence.
      • After performing simulation and finalizing the draping, that is subdividing and texturing, you can reduce file size by clearing drape history:
        (Menu) Extensions β†’ ClothWorks β†’ Clear Draped and Purge
      A 1 Reply Last reply Reply Quote 0
      • fredo6F Offline
        Anton,
        I watched the videos...
        Simply stunning, really...!
        Congratulation for this masterpiece of work.
        • BoxB Offline
          I guess I'm too quick, it's not showing up in sketchucation tools.
          Ok, you can download it manually from the Extension store but not from within Sketchup.
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            \o/
            • BoxB Offline
              After just a few minutes with it, Brilliant, bloody brilliant.
              • Rich O BrienR Online
                Pretty amazing alright! I love the smoothing and subdivision. You can work quite easily with low-medium poly cloths and then up the resolution.
                • jujuJ Offline
                  juju
                  ClothWorks can be installed via SketchUcationTools extension or manually, from ExtensionStore.
                  Refer to the steps below for installing manually:
                    %(#70ad47)[…\SketchUp\Plugins\
                  ams_ClothWorks
                  ams_ClothWorks.rb]
                  1. Close SketchUp.
                  • %appdata%\SketchUp\SketchUp 20##\SketchUp\Plugins
                  • %programdata%\SketchUp\SketchUp 20##\SketchUp\Plugins
                  > Library > Application Support > SketchUp 20## > SketchUp > Plugins
                  Do the regular extension installation/uninstallation functions of SU2018pro not work, ie. via Extension Manager?
                    Works fine.
                      Anton_S
                      Juju, it's not yet at official ExtensionManager, but will be there if soon.
                        kenancakir
                        Thank you, you did a great job.. I installed it on sketchup 2017 and works fine..
                          Oh boy! This is cool!
                            Think of all your lovely tables covered with a dirty table cloth πŸ˜›
                              Indeed! This was my first attempt. Rendering in KT now.
                                Bravo to Anton! πŸ‘
                                • N Offline
                                  nlipovac
                                  Anton, you deliver it as promised! It looks great.
                                  I was wondering will v2 comes with something like force modifier in Blender,
                                  for pillows and similar?
                                  • boofredlayB Offline
                                    boofredlay
                                    Bravo!
                                    • FrederikF Offline
                                      Frederik
                                      Congratulation! This sure is a great plugin...! πŸ‘
                                      I went ahead an purchased a license...
                                      Not primary because I believe I have that much use of this plugin, but because I also want to support plugin developers...
                                      15,00 USD is a a bargain for such a great plugin, however, I ended up paying 23,37 USD for this plugin...?!? Why...???
                                      The VAT in Denmark is 25%, but that should give a final price of 18,75 USD...
                                      Why should I pay the remaining 4,62 USD...???
                                      Cheers
                                      Kim Frederik
                                        boofredlay
                                        I am seeing the same thing.
                                        Click Obtain License and see $15 for the plugin.
                                        Click Buy This and see $19 for the plugin.
                                        Then get $23.37 which is $19 plus 23% sales tax (Ireland).
                                          It is showing the incorrect price on the buy page. Fixing now.
                                          It is $19 if you are Premium not $15. Sorry about that.
                                          VAT is applied if your PayPal account is not business verified. This is EU law to apply tax.
                                            boofredlay
                                            Thanks Rich. πŸ‘
                                            • 34
                                            • 35
                                            • 1 / 35
