    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 656.2k Views 155 Watching
    • W Offline
      wharfedale1976 @TIG
      @TIG
      @fredo6
      The same problem just happened to me.
      While other licensed Fredo plugins ran, two plugins (joint push-pull and round-corner plugins) gave errors.
      I didn't change the computer name or move the license files.
      The interesting thing is that other Fredo plugins work.
      How should I go about fixing this problem?
      Thanks and Regards
      alt text
      alt text
      alt text
      alt text
      TIGT 1 Reply Last reply Reply Quote 0
      • W Offline
        wharfedale1976 @TIG
        @TIG
        @fredo6
        Thanks and Regards
        fredo plugins licence.png lisans hatası.png joint push pull.png round corner.png
        • Rich O BrienR Online
          Rich O Brien Moderator @wharfedale1976
          @wharfedale1976
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          W 2 Replies Last reply Reply Quote 0
          • W Offline
            wharfedale1976 @Rich O Brien
            @Rich-O-Brien
            Fredo6 Plugins Information on 2024-03-23 23:29:13 +0300
            • Platform: x64-mswin64_140 - Ruby: 2.7.7
            • Sketchup: 23.1.340
            • LibFredo6: v14.2a
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.3.1
            • SCFLicense: v6.1a - 72
            • Fredo6 Plugins
              Curviloft v1.9b
              Curvizard v2.4b
              FredoPortrait v2.8a
              FredoScale v3.5a
              FredoSketch v1.3a
              FredoSpline v2.5a
              FredoTools v4.4a
              JointPushPull v4.7a
              MoveAlignMe v1.2a
              RoundCorner v3.3a
              ToolsOnSurface v2.5a
              TopoShaper v2.6a
              VisuHole v1.4b
              Signature File: 2024-01-27 16:19:01 +0300
              Curviloft: 2024-01-27 16:19:12 +0300
              Curvizard: 2024-01-27 16:20:12 +0300
              FredoScale: 2024-01-27 16:20:42 +0300
              FredoSpline: 2024-01-27 16:21:06 +0300
              ToolsOnSurface: 2024-01-27 16:21:51 +0300
              TopoShaper: 2024-01-27 16:22:07 +0300
              VisuHole: 2024-01-27 16:22:18 +0300
              "Add help menu!"
              "create new"
              (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
            "created"
            • W Offline
              @Rich-O-Brien
              I deleted the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file located in the \SCF Licenses folder. And when I reinstalled the licenses of the two plugins that gave the license error, the problem was solved.
              Thank you
                TIG Moderator @wharfedale1976
                @wharfedale1976
                Do you have the latest versions downloaded and installed for those Extensions, LibFredo6 and the latest SketchUcation Tools [for the licensing] ?
                Please post the errors that you got.
                If it says to delete the Signature file have you done that ??
                Have you then tried re-validating the licenses etc ?
                  wharfedale1976 said in [Plugin][$] JointPushPull Interactive - v4.4e - 02 Jun 19:
                  @TIG I believe he rectified the issue by deleting the signature as prompted.
                  • fredo6F Offline
                    NEW RELEASE: JointPushPull Interactive v4.8a - 30 Mar 24
                    JointPushPull Interactive 4.8a is a major release including:
                    • adjustments for future compatibility
                    IMPORTANT: JointPushPull 4.8a requires LibFredo6 14.3 or above
                    See plugin home page of JointPushPull for Download of JointPushPull.
                    Main Post of the JointPushPull thread on this forum
                      Dandelliones
                      hellow!!! i have the same problem, i reinstalled the sketchup in my pc and i cant RELEASE SEATS of the jointpushpull too
                      TIGT D Rich O BrienR 3 Replies Last reply Reply Quote 0
                        TIG Moderator @Dandelliones
                        @Dandelliones
                        Have you installed the latest versions of the SketchUcation toolset [v4.4.0], LibFredo and the Fredo extension itself ?
                        These have been updated for the latest SketchUp version etc...
                        Have you restarted SketchUp afterwards ?
                        Have you then tried managing your licenses yourself with the menu item
                        Extensions/SketchUcation/SCFLicense: My Licenses at SketchUcation...
                          g.petinati @fredo6
                          @fredo6 Hi Fredo.
                          I purchased a license of Joint Push Pull Interactive and installed it, but I can't make it work.
                          I even tried to replicate the videos, but to no avail.
                          I select the faces via JPP, but when I move the mouse away from the model, to access the toolbar, all faces are unselected. Also, the icon to apply the changes never turns green...
                          Any idea of what I may be doing wrong?
                          By the way, all your plugins are awesome.
                            Dandelliones @Dandelliones
                            @Dandelliones Yes, i do... but in my licenses managing it does not let me release the seats
                              @Dandelliones
                              OK I'll try to get someone else to resolve this...
                              @Rich-O-Brien
                                Rich O Brien Moderator @Dandelliones
                                @Dandelliones Device ID SQ.... which you activated on 01/04/24 must be using an old version of Sketchucation Tools. Please upgrade to newest version
                                Sketchucation Tools | SketchUcation
                                (sketchucation.com)
                                Once you update and restart SketchUp go to Tools > Fredo Collection > JPP > License and click the Seats button.
                                Then visit https://sketchucation.com/webshop/my-licences.php and the release checkbox will be available
                                H 1 Reply Last reply Reply Quote 0
                                  Medness
                                  This post is deleted!
                                    Medness
                                      Medness
                                      Hi, I have purchased licenses of JointPushPull, Curviloft and TopoShaper. When I install these plugins, the activation of Curviloft and TopoShaper goes fine, but JointPushPull gets an error:
                                      When I check my SketchUcation v4.4.0 licenses:
                                      I don't even have it listed
                                        Rich O Brien Moderator @Medness
                                        @Medness You have multiple account and purchased JPP on another account.
                                        Login to that account and release seats
                                        M 1 Reply Last reply Reply Quote 0
                                          Medness @Rich O Brien
                                          @Rich-O-Brien said in [Plugin][$] JointPushPull Interactive - v4.8a - 30 Mar 24:
                                          I registered all plugins to the same email address. Where can I see for which account I got the JPP plugin? Can the accounts be merged?
                                          Rich O BrienR fredo6F 2 Replies Last reply Reply Quote 0
                                            @Medness Asking where to email license files is not the same as logging into a separate account and puchasing.
                                            I can purchase licenses and ask to send them any email address for convenience. But the license files have to be associated to a user account.
                                            In your instance you have multiple accounts so login to Medness1000 and you'll see JPP there
                                            Merging is not possible.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 30
                                            • 31
                                            • 15 / 31
