    RayScaper
    rayscaper
    86 Posts 9 Posters 15.7k Views 8 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @majid
      @majid said in RayScaper:
      @pixelcruncher
      Okay,
      So right now the Directioonal light, works independently, am I right?
      Then there would be fine if it matches the sketchup sun position by default and having an option to detach it from tje sunlight, IMO
      Correct, they are working independently but I will add the option to sync those.
        Rich O Brien Moderator @pixelcruncher
        @pixelcruncher I hope its a toggleable feature. Having full control over sun position is important for artistic control.
        Plus the ability to add more than one directional light is also important. So I would not like that support for SketchUp sun position removes that ability too.
        Maybe a 4th light that represent SketchUp sun or if I right click a Di-Light I can set it to SketchUp position.
        • pixelcruncherP
          pixelcruncher Extension Creator @Rich O Brien
          @Rich-O-Brien Yes, it would be optional. IIRC, we discussed this a while ago, i.e., having the artistic freedom to do whatever you want with directional lights, so I definitely don't want to take away that freedom.
          This was my thinking: have a context menu on the directional light that says sync with SketchUp sun position or have a tick box in the directional light config sync from Sketchup. Then, it would track it in real-time. Option two would be the logical path to quickly support sun animations for shadow studies.
            @pixelcruncher said in RayScaper:
            Both sound solid. I used 2 directional light in my Table Lamp scene. Having multiple Di-Lights for me is important to really match real world shadowing effects that a single light cannot achieve.
            As long a SketchUp Sun support doesn't impact the flexibility I'm happy to see it.
            My preference if lights is getting discussed would be Area Light support
            • pixelcruncherP
              @Rich-O-Brien said in RayScaper:
              Rich, is there something that doesn't work when adding emissions to a plane? Or do you want something simpler than configuring the light-emitting material?
              edit: Because for example, the material preview scene for Rayscaper, which you created has an area light πŸ™‚
                Geometry that emits light also blocks light and cast a shadows. Area Lights should behave like your Point and Directional and only cast light and cause shadows. I shouldn't see an area light in the render viewport.
                • pixelcruncherP
                  @Rich-O-Brien Gotcha, would the equivalent be allowing emission from transparent geometry? Although I can see how it's easy to have a dedicated rectangular area light for this,
                    @pixelcruncher The issue without still have the plane in SketchUp would be it blocking your view.
                    Your point and directional components are great because they are not intrusive. So a similar setup to that would be perfect....
                    • pixelcruncherP
                      Thanks for explaining, will put it on my features list.
                      majidM 1 Reply Last reply
                      • majidM
                        majid @pixelcruncher
                        The other day I was plating with "Plastic" shader and here are some of the images.
                        The engine material settings seem promising as even in very dark hues you can see the color.
                        ntxdaveN majidM 2 Replies Last reply
                        • ntxdaveN
                          ntxdave @majid
                          @majid πŸ‘ πŸ‘
                          That looks good. Wish I could do some testing as well.
                          Press F1...thank me later
                          • majidM
                            majid @majid
                            @ntxdave Do you mind checking if this link works, please?
                            https://3dwarehouse.sketchup.com/model/70a9083d-d1d9-464c-aea8-69895402c4ef/RayScraper-material-test-scene-Unofficial
                            ntxdaveN 2 Replies Last reply
                            • ntxdaveN
                              ntxdave @majid
                              @majid
                              I meant, wish I could try RayScaper. 😞
                              • ntxdaveN
                                ntxdave @majid
                                @majid
                                I meant, I wish I could try RayScaper. I am running SU 2020 😞
                                Reply Quote -1
                                • pixelcruncherP
                                  @majid Thanks for sharing those material experiments. They look very realistic.
                                  I'm making the Rayscaper material editor more intuitive and less nested so that users won't be daunted by all the material settings. @Rich-O-Brien gave me some great feedback on this. This update should land this week.
                                  Cheers,
                                  Thomas
                                  • majidM
                                    majid @ntxdave
                                    @ntxdave So, RS does not work on prior versions?
                                    @pixelcruncher Good news and progress!
                                    • pixelcruncherP
                                      @majid
                                      Right now, Rayscaper requires SketchUp 2021 or higher.
                                      • majidM
                                        majid
                                        This is rather an old model... Yet I liked the result.
                                        pixelcruncherP tuna1957T 2 Replies Last reply
                                        Reply Quote 4
                                        • pixelcruncherP
                                          @majid
                                          Superb render, Majid! I like the result as well.
                                          This scene is a classic in computer graphics. It's the atrium of the Sponza Palace, which exists in Dubrovnik, Croatia (wiki). If you are a Game of Thrones fan, Dubrovnik is also where they filmed all the scenes in King's Landing.
                                          • G
                                            gerdfa
                                            We get an error when we start sketchup 2024
                                            SCFLicense is install
                                            SketchUp: 24.0.483
                                            OS: Ventura
                                            Ruby: 3.2.2
                                            Erweiterung: Rayscaper (0.9.10 Beta)
                                            Fehler: LoadError (cannot load such file -- /users/XXX/library/application support/sketchup 2024/sketchup/plugins/rayscaper/installed/Mac/3.2.2/0.9.10 Beta/resources/SUEX_Rayscaper_SetDllDirectory)
                                            <internal:/Applications/SketchUp 2024/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/3.2.2/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:/Applications/SketchUp 2024/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/3.2.2/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:85:in require'
                                            /users/XXX/library/application support/sketchup 2024/sketchup/plugins/rayscaper/main.rbe:94:in <module:Rayscaper>' /users/XXX/library/application support/sketchup 2024/sketchup/plugins/rayscaper/main.rbe:5:in <main>'
                                            /Applications/SketchUp 2024/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in eval' /Applications/SketchUp 2024/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in require'
                                            /Applications/SketchUp 2024/SketchUp.app/Contents/Resources/Tools/extensions.rb:197:in load' /Users/XXX/Library/Application Support/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in register_extension'
                                            /Users/XXX/Library/Application Support/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:18:in <module:Rayscaper>' /Users/XXX/Library/Application Support/SketchUp 2024/SketchUp/Plugins/rayscaper.rb:6:in <top (required)>'
                                            • 2 / 5
