    RayScaper
    rayscaper
    86 Posts 9 Posters 17.6k Views 8 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @majid
      @majid Just one side of the plane is enough. Do you have an example render or example scene so I can take a look?
      Cheers,
      Thomas
      majidM 1 Reply Last reply
      • majidM
        majid @pixelcruncher
        @pixelcruncher Thanks Thomas, and how may I exactly match the sun's direction with the direction-light?
        • pixelcruncherP
          @majid Are you referring to the SketchUp sun direction? As configured here:
          If so, I can add an option to match the directional light to the SketchUp sun.
          • majidM
            @pixelcruncher
            Okay,
            So right now the Directioonal light, works independently, am I right?
            Then there would be fine if it matches the sketchup sun position by default and having an option to detach it from tje sunlight, IMO
            • pixelcruncherP
              @majid said in RayScaper:
              @pixelcruncher
              Okay,
              Correct, they are working independently but I will add the option to sync those.
                Rich O Brien Moderator @pixelcruncher
                @pixelcruncher I hope its a toggleable feature. Having full control over sun position is important for artistic control.
                Plus the ability to add more than one directional light is also important. So I would not like that support for SketchUp sun position removes that ability too.
                Maybe a 4th light that represent SketchUp sun or if I right click a Di-Light I can set it to SketchUp position.
                • pixelcruncherP
                  pixelcruncher Extension Creator @Rich O Brien
                  @Rich-O-Brien Yes, it would be optional. IIRC, we discussed this a while ago, i.e., having the artistic freedom to do whatever you want with directional lights, so I definitely don't want to take away that freedom.
                  This was my thinking: have a context menu on the directional light that says sync with SketchUp sun position or have a tick box in the directional light config sync from Sketchup. Then, it would track it in real-time. Option two would be the logical path to quickly support sun animations for shadow studies.
                    @pixelcruncher said in RayScaper:
                    Both sound solid. I used 2 directional light in my Table Lamp scene. Having multiple Di-Lights for me is important to really match real world shadowing effects that a single light cannot achieve.
                    As long a SketchUp Sun support doesn't impact the flexibility I'm happy to see it.
                    My preference if lights is getting discussed would be Area Light support
                    • pixelcruncherP
                      @Rich-O-Brien said in RayScaper:
                      Rich, is there something that doesn't work when adding emissions to a plane? Or do you want something simpler than configuring the light-emitting material?
                      edit: Because for example, the material preview scene for Rayscaper, which you created has an area light πŸ™‚
                        Geometry that emits light also blocks light and cast a shadows. Area Lights should behave like your Point and Directional and only cast light and cause shadows. I shouldn't see an area light in the render viewport.
                        • pixelcruncherP
                          @Rich-O-Brien Gotcha, would the equivalent be allowing emission from transparent geometry? Although I can see how it's easy to have a dedicated rectangular area light for this,
                            @pixelcruncher The issue without still have the plane in SketchUp would be it blocking your view.
                            Your point and directional components are great because they are not intrusive. So a similar setup to that would be perfect....
                            • pixelcruncherP
                              Thanks for explaining, will put it on my features list.
                              • majidM
                                The other day I was plating with "Plastic" shader and here are some of the images.
                                The engine material settings seem promising as even in very dark hues you can see the color.
                                ntxdaveN majidM 2 Replies Last reply
                                • ntxdaveN
                                  ntxdave @majid
                                  @majid πŸ‘ πŸ‘
                                  That looks good. Wish I could do some testing as well.
                                  Press F1...thank me later
                                  • majidM
                                    majid @majid
                                    @ntxdave Do you mind checking if this link works, please?
                                    https://3dwarehouse.sketchup.com/model/70a9083d-d1d9-464c-aea8-69895402c4ef/RayScraper-material-test-scene-Unofficial
                                    ntxdaveN 2 Replies Last reply
                                    • ntxdaveN
                                      ntxdave @majid
                                      @majid
                                      I meant, wish I could try RayScaper. 😞
                                      • ntxdaveN
                                        ntxdave @majid
                                        @majid
                                        I meant, I wish I could try RayScaper. I am running SU 2020 😞
                                        Reply Quote -1
                                        • pixelcruncherP
                                          @majid Thanks for sharing those material experiments. They look very realistic.
                                          I'm making the Rayscaper material editor more intuitive and less nested so that users won't be daunted by all the material settings. @Rich-O-Brien gave me some great feedback on this. This update should land this week.
                                          Cheers,
                                          Thomas
                                          • majidM
                                            majid @ntxdave
                                            @ntxdave So, RS does not work on prior versions?
                                            @pixelcruncher Good news and progress!
                                            • 2 / 5
