    RayScaper
    rayscaper
    86 Posts 9 Posters 14.8k Views 8 Watching
      They really do, no error. πŸ˜„
      • majidM
        majid
        RS is really capable of doing good renders...
        I believe car design needs me more than RS .... 😲 I have a handful of ideas that may change the car-design industry.. I have no clue how may I find my way to it...
        • P
          No RS needs you more 😎 πŸ’š
          I would love to see some concept car drawings or sketches!
          Cheers,
          Thomas
          • P
            @ntxdave said:
            Very good Majid. πŸ‘ πŸ‘ πŸ‘
            They need you on their team. πŸ˜„
            If I could afford it, I would definitely hire this super talent! But for that, I have to sell a bunch more licenses.
            majidM 1 Reply Last reply
            • ntxdaveN
              ntxdave
              Just imagine; you, Majid, Fletch, and Chris. πŸ˜†
              Press F1...thank me later
              majidM P 2 Replies Last reply
              • majidM
                majid @ntxdave
                @ntxdave Sounds great, yet this is not the time...
                • P
                  pixelcruncher Extension Creator @ntxdave
                  @ntxdave
                  Fletch has been super helpful with advice, but I'm not sure he's up for another rendering adventure after a decade of Twilight render.
                  • majidM
                    majid @pixelcruncher
                    @pixelcruncher I like in-built DOF effect of the RayScaper and it is too intuitive!
                    Compared to real-life photography that one has to know the aperture steps , etc... it is really easy, and this is really great that it had it from the very first release, without any sensible change in rendering time...
                    Is there any Bkeh effect on the road-map?
                    • majidM
                      majid
                      It seems I have a problem with thin glass material. Do I must apply it to both sides of the plane or just one side? it seems that it does not let the light in.
                      P 1 Reply Last reply
                      • P
                        pixelcruncher Extension Creator @majid
                        @majid Just one side of the plane is enough. Do you have an example render or example scene so I can take a look?
                        Cheers,
                        Thomas
                        • majidM
                          @pixelcruncher Thanks Thomas, and how may I exactly match the sun's direction with the direction-light?
                          • P
                            @majid Are you referring to the SketchUp sun direction? As configured here:
                            If so, I can add an option to match the directional light to the SketchUp sun.
                            • majidM
                              @pixelcruncher
                              Okay,
                              So right now the Directioonal light, works independently, am I right?
                              Then there would be fine if it matches the sketchup sun position by default and having an option to detach it from tje sunlight, IMO
                              • P
                                @majid said in RayScaper:
                                @pixelcruncher
                                Okay,
                                Correct, they are working independently but I will add the option to sync those.
                                  Rich O Brien Moderator @pixelcruncher
                                  @pixelcruncher I hope its a toggleable feature. Having full control over sun position is important for artistic control.
                                  Plus the ability to add more than one directional light is also important. So I would not like that support for SketchUp sun position removes that ability too.
                                  Maybe a 4th light that represent SketchUp sun or if I right click a Di-Light I can set it to SketchUp position.
                                  • P
                                    pixelcruncher Extension Creator @Rich O Brien
                                    @Rich-O-Brien Yes, it would be optional. IIRC, we discussed this a while ago, i.e., having the artistic freedom to do whatever you want with directional lights, so I definitely don't want to take away that freedom.
                                    This was my thinking: have a context menu on the directional light that says sync with SketchUp sun position or have a tick box in the directional light config sync from Sketchup. Then, it would track it in real-time. Option two would be the logical path to quickly support sun animations for shadow studies.
                                      @pixelcruncher said in RayScaper:
                                      Both sound solid. I used 2 directional light in my Table Lamp scene. Having multiple Di-Lights for me is important to really match real world shadowing effects that a single light cannot achieve.
                                      As long a SketchUp Sun support doesn't impact the flexibility I'm happy to see it.
                                      My preference if lights is getting discussed would be Area Light support
                                      • P
                                        @Rich-O-Brien said in RayScaper:
                                        Rich, is there something that doesn't work when adding emissions to a plane? Or do you want something simpler than configuring the light-emitting material?
                                        edit: Because for example, the material preview scene for Rayscaper, which you created has an area light πŸ™‚
                                          Geometry that emits light also blocks light and cast a shadows. Area Lights should behave like your Point and Directional and only cast light and cause shadows. I shouldn't see an area light in the render viewport.
                                          • P
                                            @Rich-O-Brien Gotcha, would the equivalent be allowing emission from transparent geometry? Although I can see how it's easy to have a dedicated rectangular area light for this,
                                            • 2 / 5
