    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 15.3k Views 11 Watching
    • L
      @jo-ke said:
      I am testing Sketchup diffusion.
      I took an old model and let it go through the new app sketchup diffusion. the result is quite good but the quality looks a bit like a sketch. I took the Picture to stable diffusion and developped it further with image2image and realistic vision. The result is really great...
      I find it interesting that the sketchup dufusion and stable diffusion gave a very similar treatment to both images. For instance the sky is almost identical as is the lighting. The only difference I can see is the material mapping and roughness. I wonder why this is?
        rv1974
        @rich o brien said:
        @jo-ke said:
        not yet, but I am trying to get better results with combining different methods. But I am still not happy with it.
        Have you tried ComfyUI yet jo-ke? It might help you dial it in but the learning curve is high.
        If you are not familiar there is a ton of stuff on Youtube plus theres a great site https://comfyworkflows.com/ where the images shared contain the metadata of how they were made.
        What are benefits of Comfy (in comparison to A1111)?
          rv1974
          @solo said:
          So, this whole AI thing may be more than a fad? πŸ’š
          So far the only use (from all this AI craze) I see is 3D people enhancement in stills.
            rv1974
            @rich o brien said:
            @jo-ke said:
            In the End: I get the best results with renderings. Here: Twinmotion
            Rolling up your sleeves and getting your hands dirty still looks best. Diffusion can help you in terms of direction to take with lighting and colour palette. But for a final result I still believe you need human creativity.
            But AI will get there and it will be interesting to see how the likes of Vray, D5, TwinMotion etc respond.
            These shots are though. Really nice output.
            Meanwhile Chaos implemented DLSS 3.5 thing in Vantage - and it it really makes wonders
              Its node based so its easier to follow logic if your comfortable in node based environments.
              If not stick with A1111.
              • jo-keJ
                jo-ke
                The Sketchup Diffusion Output is the Stable diffusion input. That is the reason both look similar but stable diffusion img2img devellops it a bit further to a better result.
                http://www.zz7.de
                  rv1974
                  interesting observation on AI:
                  • jo-keJ
                    jo-ke
                    overlay in photoshop:
                    -sketchtup
                    -skectchupdiffusion
                    -rayscaper
                    nice result
                    http://www.zz7.de
                    • P
                      -sketchtup
                      -skectchupdiffusion
                      -rayscaper
                      nice result
                      Really nice! (I’m sorry, I accidentally downvoted, the buttons are too small for my thick thumbs).
                      jo-keJ 1 Reply Last reply
                      • jo-keJ
                        jo-ke @pixelcruncher
                        further development in stable diffusion
                        sketchupdiffusion
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          I am using sketchup diffusion to build textures of buildings.
                          At first I am looking for sketches of fassades.
                          then I import it to Sketchup, define the colors in the promt and render it.
                          then I project the texture on my object and model the rest.
                          This is very fast and effective.
                          http://www.zz7.de
                          • jo-keJ
                            jo-ke
                            a funny weekend project.
                            some years ago, I was 3D scanned and they made a small 3D Modell of my body.
                            I scaned the small figure in3D and made a Sketchup modell of it.
                            The I renderd it in Sketchup diffusion and put it in stable diffusion img2img.
                            upscaling with my Lora and a reActor Faceswap.
                            nice result....
                            su view:
                            su diffusion:
                            stable diffusion:
                            http://www.zz7.de
                            Reply Quote 2
                            • jo-keJ
                              jo-ke
                              quick tutorial to show how I use Sketchup Diffusion:
                              At first look for a drawing of a building, then texture a cube with it, and set the view to front view. then start Sketchup Diffusion. I typed for promt: "fassade of an old building, dirty beige sandstone" and hit "generate".
                              then I took the best one and hit "add scene". then I took the sketchup function "project texture" to exchange the drawing with the AI texture.
                              the cube is textured
                              some work on geometrie.... finished in less then 5 minutes....
                              and a quick render in Twilight Render
                              http://www.zz7.de
                              • jo-keJ
                                jo-ke
                                playing some more.
                                again the 3D figures...
                                su view
                                sketchup diffusion to stablediffusion, lora and ReActor Faceswap
                                not to bad
                                http://www.zz7.de
                                • jo-keJ
                                  jo-ke
                                  new playing arround:
                                  at first I asked Midjourney to create a unique seamless texture for a modern building
                                  jo3d3_seamless_pattern_photorealistic_texture_of_a_modern_germa_749a0d27-4cc5-4394-9d11-f3d4c2e96615.png
                                  then I created a scene in SU and hit render in Sketchup diffusion.
                                  result was a nice AI render of the scene
                                  then I took the render to kreaAI and a little postpro in Photoshop
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    but a solid render with twinmotion is still better!
                                    and retouched with KreaAI
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      I am still trying to make the best out of sketchup diffusion.
                                      I hope they will develop it further....
                                      When merging su and su diffusion the result comes out quite nice....
                                      su view:
                                      su diffusion:
                                      merged them both in photoshop "hard light"
                                      background enhancment with kreaAI:
                                      http://www.zz7.de
                                      Reply Quote 2
                                      • jo-keJ
                                        jo-ke
                                        just 5 clicks and 2 minutes work to produce a nightshot:
                                        http://www.zz7.de
                                        Reply Quote 2
                                          Rich O Brien Moderator @jo-ke
                                          @jo-ke I gotta admit I'm not a fan of AI. I know there's no escaping it. I just find it hard to say wow or well done.
                                          I don't know what to say. Its a timesaver.
                                          • jo-keJ
                                            jo-ke
                                            new try.
                                            I took a picture of my fathers car of the 60ties. and ran it through meshy.ai to get a sketchup- model of it.
                                            then I rendered it with sketchup diffusion and modification in krea.ai, merged and little correction in Photoshop.
                                            everything took less then 10 minutes.
                                            http://www.zz7.de
                                            Reply Quote 3
                                            • 3 / 5
