    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 14.8k Views 11 Watching
    • jo-keJ Offline
      jo-ke
      and another one this a clay style for shadows
      sketchup diffusion clay
      result in photoshop
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        and another compared to twinmotion
        merge su and sd
        twinmotion
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          new test: merging Twilghtrender and sketchup diffusion
          Twilightrender
          sketchup diffusion
          both merged
          http://www.zz7.de
          • jo-keJ Offline
            jo-ke
            and another one.
            It really gives a touch of reality
            Twilght
            SD
            merge
            http://www.zz7.de
            • jo-keJ Offline
              jo-ke
              and another one with rayscaper
              rayscaper
              merge
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                new test
                sketchup diffusion
                upscale with stable diffusion
                http://www.zz7.de
                • ntxdaveN Offline
                  ntxdave
                  Very interesting results. πŸ‘ πŸ‘
                  Press F1...thank me later
                    It's very cool to see the interplay of accurate rendering and stable diffusion. Are you already using this technique for client renders, or is it just experimentation?
                    Cheers,
                    Thomas
                    • jo-keJ Offline
                      jo-ke
                      and another one sketchup to controlnet- stable diffusion
                      http://www.zz7.de
                      • jo-keJ Offline
                        jo-ke
                        Cheers,
                        Thomas
                        not yet, but I am trying to get better results with combining different methods. But I am still not happy with it.
                        http://www.zz7.de
                        • Rich O BrienR Online
                          Have you tried ComfyUI yet jo-ke? It might help you dial it in but the learning curve is high.
                          If you are not familiar there is a ton of stuff on Youtube plus theres a great site https://comfyworkflows.com/ where the images shared contain the metadata of how they were made.
                          • jo-keJ Offline
                            jo-ke
                            yes, but after an update ComyUI does not work anymore. I am more familiar with automatic1111
                            In the End: I get the best results with renderings. Here: Twinmotion
                            http://www.zz7.de
                            • jo-keJ Offline
                              jo-ke
                              twinmotion + stablediffusion gives the perfect imperfections...
                              I love this combination
                              http://www.zz7.de
                                Rolling up your sleeves and getting your hands dirty still looks best. Diffusion can help you in terms of direction to take with lighting and colour palette. But for a final result I still believe you need human creativity.
                                But AI will get there and it will be interesting to see how the likes of Vray, D5, TwinMotion etc respond.
                                These shots are though. Really nice output.
                                  @jo-ke said:
                                  I am testing Sketchup diffusion.
                                  I took an old model and let it go through the new app sketchup diffusion. the result is quite good but the quality looks a bit like a sketch. I took the Picture to stable diffusion and developped it further with image2image and realistic vision. The result is really great...
                                  I find it interesting that the sketchup dufusion and stable diffusion gave a very similar treatment to both images. For instance the sky is almost identical as is the lighting. The only difference I can see is the material mapping and roughness. I wonder why this is?
                                  • R Do not disturb
                                    rv1974
                                    What are benefits of Comfy (in comparison to A1111)?
                                    • R Do not disturb
                                      rv1974
                                      @solo said:
                                      So, this whole AI thing may be more than a fad? πŸ’š
                                      So far the only use (from all this AI craze) I see is 3D people enhancement in stills.
                                      • R Do not disturb
                                        rv1974
                                        Meanwhile Chaos implemented DLSS 3.5 thing in Vantage - and it it really makes wonders
                                          Its node based so its easier to follow logic if your comfortable in node based environments.
                                          If not stick with A1111.
                                          • jo-keJ Offline
                                            jo-ke
                                            The Sketchup Diffusion Output is the Stable diffusion input. That is the reason both look similar but stable diffusion img2img devellops it a bit further to a better result.
                                            http://www.zz7.de
                                            • 3 / 5
