    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 14.8k Views 11 Watching
    • jo-keJ Offline
      jo-ke
      new test: merging Twilghtrender and sketchup diffusion
      Twilightrender
      sketchup diffusion
      both merged
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        and another one.
        It really gives a touch of reality
        Twilght
        SD
        merge
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          and another one with rayscaper
          rayscaper
          merge
          http://www.zz7.de
          • jo-keJ Offline
            jo-ke
            new test
            sketchup diffusion
            upscale with stable diffusion
            http://www.zz7.de
            • ntxdaveN Offline
              ntxdave
              Very interesting results. πŸ‘ πŸ‘
              Press F1...thank me later
                It's very cool to see the interplay of accurate rendering and stable diffusion. Are you already using this technique for client renders, or is it just experimentation?
                Cheers,
                Thomas
                • jo-keJ Offline
                  jo-ke
                  and another one sketchup to controlnet- stable diffusion
                  http://www.zz7.de
                  • jo-keJ Offline
                    jo-ke
                    Cheers,
                    Thomas
                    not yet, but I am trying to get better results with combining different methods. But I am still not happy with it.
                    http://www.zz7.de
                    • Rich O BrienR Online
                      Have you tried ComfyUI yet jo-ke? It might help you dial it in but the learning curve is high.
                      If you are not familiar there is a ton of stuff on Youtube plus theres a great site https://comfyworkflows.com/ where the images shared contain the metadata of how they were made.
                      • jo-keJ Offline
                        jo-ke
                        yes, but after an update ComyUI does not work anymore. I am more familiar with automatic1111
                        In the End: I get the best results with renderings. Here: Twinmotion
                        http://www.zz7.de
                        • jo-keJ Offline
                          jo-ke
                          twinmotion + stablediffusion gives the perfect imperfections...
                          I love this combination
                          http://www.zz7.de
                            Rolling up your sleeves and getting your hands dirty still looks best. Diffusion can help you in terms of direction to take with lighting and colour palette. But for a final result I still believe you need human creativity.
                            But AI will get there and it will be interesting to see how the likes of Vray, D5, TwinMotion etc respond.
                            These shots are though. Really nice output.
                              @jo-ke said:
                              I am testing Sketchup diffusion.
                              I took an old model and let it go through the new app sketchup diffusion. the result is quite good but the quality looks a bit like a sketch. I took the Picture to stable diffusion and developped it further with image2image and realistic vision. The result is really great...
                              I find it interesting that the sketchup dufusion and stable diffusion gave a very similar treatment to both images. For instance the sky is almost identical as is the lighting. The only difference I can see is the material mapping and roughness. I wonder why this is?
                              • R Do not disturb
                                rv1974
                                What are benefits of Comfy (in comparison to A1111)?
                                • R Do not disturb
                                  rv1974
                                  @solo said:
                                  So, this whole AI thing may be more than a fad? πŸ’š
                                  So far the only use (from all this AI craze) I see is 3D people enhancement in stills.
                                  • R Do not disturb
                                    rv1974
                                    Meanwhile Chaos implemented DLSS 3.5 thing in Vantage - and it it really makes wonders
                                      Its node based so its easier to follow logic if your comfortable in node based environments.
                                      If not stick with A1111.
                                      • jo-keJ Offline
                                        jo-ke
                                        The Sketchup Diffusion Output is the Stable diffusion input. That is the reason both look similar but stable diffusion img2img devellops it a bit further to a better result.
                                        http://www.zz7.de
                                        • R Do not disturb
                                          rv1974
                                          interesting observation on AI:
                                          • jo-keJ Offline
                                            jo-ke
                                            overlay in photoshop:
                                            -sketchtup
                                            -skectchupdiffusion
                                            -rayscaper
                                            nice result
                                            http://www.zz7.de
                                            • 3 / 5
