    D5 Render Work
    95 Posts 12 Posters 16.1k Views 12 Watching
    • ntxdaveN
      ntxdave
      @marked001 said:
      Its all the software! Very easy to get good results.
      I meant coming up with the model itself. I don’t seem to be able to design something like this. Yes, once designed the render engines are making it somewhat easier to come up with good renders.
      I like your results. πŸ‘ πŸ‘
      Press F1...thank me later
      • marked001M
        marked001
        Well I definitely do not design the majority of the stuff I post. Some when its conceptual and there isn't actually a design or when we're working through a design. But for the most part, these are all other's designs.. in case that wasn't clear.
        http://www.revision21vis.com
        instagram: revi21on
        • ntxdaveN
          ntxdave
          Thanks for the reply. Where do you find stuff like this (and your other neat scenes/models)?
          • marked001M
            marked001
            99% of this stuff is paid work so comes from the architect, designer, broker, etc. Sometimes its just a plan and some photo reference of what they want, sometimes plans and elevations and complete finishes.
            instagram: revi21on
            • ntxdaveN
              ntxdave
              OK, now I understand. πŸ˜„ πŸ˜„
              • Bryan KB
                That cafe is excellent! πŸ‘
                • marked001M
                  marked001
                  Thanks Bryan.
                  Here are some conceptual images for a set build of a high end upper west side apartment for a tv show. They're a weird format because that's the aspect ratio the show is being shot in.
                  instagram: revi21on
                  • L
                    Beautiful Mark great style and modelling, and I like that aspect ratio. cinematographic πŸ‘
                    • marked001M
                      marked001
                      Its definitely odd to try to use indoors and see as much as you can. 2:1...I guess its a compromise between 4:3 and 16:9
                      instagram: revi21on
                      • Bryan KB
                        Those set mock-ups turned out really good! πŸ‘
                          Very nicely done, worth a raise. πŸ‘
                          • marked001M
                            marked001
                            Its Union work.. so a raise is out of the question for a few years.. haha.
                            Object moved
                            (www.usa829.org)
                            instagram: revi21on
                            • marked001M
                              marked001
                              quick one from friday afternoon. addition to an existing house.
                              One thing I like over Lumion, with D5 is that this is straight out of D5 with no post processing. Obviously I 'should' probably spend a little time, but sometimes there just isn't time available. But with Lumion I was always forced to do some post processing to get it where I want it.
                              instagram: revi21on
                              • ntxdaveN
                                ntxdave
                                I really like this one. πŸ‘ πŸ‘ πŸ‘
                                • marked001M
                                  marked001
                                  A couple more from last week from the show I'm working on.
                                  instagram: revi21on
                                    @marked001 said:
                                    Thanks! A couple more from last week from the show I'm working on.
                                    The lighting is great. Everything is great. But the lighting is really nice.
                                    The subtle noise patterns really breaks up the textured walls.
                                    • ntxdaveN
                                      ntxdave
                                      Very well done. So good they look like photos. πŸ‘ πŸ‘ πŸ‘
                                      • marked001M
                                        marked001
                                        Yeah, the light is great. That's all from D5 because this is totally lit by the sun.
                                        instagram: revi21on
                                        • Gus RG
                                          Gus R
                                          These look great Marked. I see you're keeping busy.
                                          www.instagram.com/gusrobatto/
                                          www.facebook.com/gusrobatto
                                          • marked001M
                                            marked001
                                            I have been keeping very busy so far this year.. no complaints.
                                            Here's a quick quick one... client paying out of pocket just to use in their portfolio so not much money.
                                            instagram: revi21on
                                            • 2 / 5
